Driving alongside large semi-trucks and tractor-trailers can be intimidating, especially when taking into consideration the potential risk of a crash.
However, by following some essential driving tips and understanding the causes of trucking accidents, motorists can significantly reduce their risk of collisions with commercial vehicles. Here’s a comprehensive guide to driving safely and avoiding trucking collisions on the road.
Understanding the causes of trucking collisions
Trucking collisions can occur due to various factors, including:
- Driver fatigue: Truck drivers work long hours and spend most time alone on the road. This can make truck drivers more tired than the average car driver and when paired with operating a 60,000-pound truck, mistakes can be devastating.
- Distracted driving: Phones, eating, daydreaming, and even changing the radio are all forms of distracted driving that can lead to collisions.
- Improper maintenance: If trucking companies don’t administer proper truck maintenance that aligns with the FMCSA trucking regulations, wrecks can occur from malfunctions.
- Weather: Poor weather conditions like ice, rain, wind, and snow can cause large trucks to slide or crash.
- Driving under the influence: Operating a truck while under the influence of drugs or alcohol impairs a driver’s ability to react quickly and drive accurately.
Give the truck space
Maintaining a safe following distance from trucks is crucial for avoiding rear-end collisions. Trucks require more time and distance to come to a complete stop compared to passenger vehicles, so drivers should leave ample space between their vehicle and the truck ahead.
Avoid blind spots
Trucks have larger blind spots, also known as “no-zones,” where the driver’s visibility is limited. Avoid lingering in these blind spots, especially alongside and directly behind the truck. If you can’t see the truck driver’s mirrors, they likely can’t see you.
Pass quickly and safely
When passing a truck, do so quickly and safely. Signal your intention to pass well in advance, accelerate to a safe speed, and pass the truck on the left side whenever possible. Avoid passing on the right, as trucks have larger blind spots on their passenger side.
Be cautious when trucks turn
Exercise caution when driving near trucks that are turning. Trucks have a wide turning radius, and they may swing into adjacent lanes while making a turn. Stay back and give the truck plenty of space to maneuver safely.
Stay alert
Remain vigilant and attentive while driving, especially when sharing the road with trucks. Avoid distractions such as texting, talking on the phone, or adjusting the radio. Stay focused on the task of driving and be prepared to react to changing road conditions.
Use your blinker
Always use your turn signals to indicate your intentions to other drivers, including truck drivers. Signaling your lane changes and turns allows truck drivers to anticipate your movements and adjust their driving accordingly.
Beware of poor weather
Exercise extra caution when driving in adverse weather conditions, such as rain, snow, or fog. Reduced visibility and slippery road surfaces can increase the risk of collisions, especially when sharing the road with large trucks. Slow down, increase the following distance, and avoid sudden maneuvers.
Reduce road rage
Maintain a calm and patient demeanor while driving, especially when encountering aggressive or erratic behavior from other motorists. Avoid engaging in road rage or retaliating against aggressive drivers, as this can escalate dangerous situations on the road.
Merge with caution
When merging onto highways or changing lanes near trucks, proceed with caution. Signal your intention to merge, check your blind spots, and yield to oncoming traffic, including trucks. Allow trucks plenty of space to merge safely and avoid cutting them off.
Driving safely near semi-trucks
By following these driving tips and exercising caution when sharing the road with semi-trucks, motorists can significantly reduce their risk of collisions and promote safer driving conditions for everyone. Remember to stay alert, maintain a safe distance, and respect the size and capabilities of large commercial vehicles. Safe driving practices benefit everyone on the road and help prevent tragic collisions caused by negligence or reckless behavior.
