More than 200k 2020-2022 Ford Explorer SUVs are being recalled due to an issue with the driveshaft disconnecting causing the driver to lose control.
2020-220 Ford Explorer Recall
Ford Motor Company (Ford) is recalling certain 2020-2022 Explorer vehicles. The rear axle horizontal mounting bolt may fracture and cause the driveshaft to disconnect.
A disconnected driveshaft can result in a loss of drive power or a vehicle rollaway if the parking brake is not applied. Either of these scenarios can increase the risk of a crash.
NHTSA Campaign Number: 23V675000
Manufacturer Ford Motor Company
Components POWER TRAIN
Potential Number of Units Affected 238,364
Remedy
Dealers will replace the subframe bushing and rear axle bolt. They will also inspect the rear axle cover for damage near the bolt hole location and replace with a new cover if any damage is found. Repairs will be performed free of charge. Owner notification letters are expected to be mailed November 6, 2023. Owners may contact Ford customer service at 1-8669-436-7332. Ford’s number for this recall is 23S55.
Editor’s note: This information was copied directly from the NHTSA website. If you have questions or concerns about this Ford Explorer recall, please contact Ford Motor Company directly.
