Toyota Grand Highlander vs. Highlander: A spec-by-spec comparison
June 1, 2023
Spoiler alert: The 2024 Grand Highlander is bigger than the plain old Highlander. Yes, they’re both three-row SUVs. And yes, they both have hybrid options. But they do have some key differences, so we decided to do a spec-by-spec Toyota Grand Highlander vs. Highlander comparo so you could see exactly what those differences are.
Third-row legroom
The biggest and obvious difference is going to be in the third-row legroom. The Grand Highlander adds about 5 inches of room back there – which makes it possible for “real-sized” adults to fit back there. The interesting thing, however, is front-seat legroom decreases a tad, while the second-row legroom increases a tad.
Another big win with the added length to the Grand Highlander: cargo space. Sure, there’s more general cargo volume with all seats folded flat (duh, the Grand Highlander is bigger), but some of that extra 6 inches of length went to the space behind the third row. So, you get more than 4 additional cubic feet of cargo space with the third row up. As we saw in photos during the press preview, that translates to fitting seven carry-on rollerboards back there.
Even with the additional size, heft and length, though, both Grand Highlander and Highlander are still considered midsize SUVs.
The Hybrid Max
The other big difference is the addition of the Hybrid Max powertrain. This is a spiffy and fast hybrid that provides smooth power and fun-to-drive dynamics. What it doesn’t provide: fuel economy. It’ll get 27 MPG in combined driving (if you’re lucky – we got around 21 or 22 MPG in our 2-hour test). The extra weight of the Grand Highlander means you’ll also see lower fuel economy in the gas and straight hybrid as well. Fuel economy will drop 1 to 2 MPG in combined driving depending on trim and drivetrain.
The Toyota Grand Highlander vs. Highlander specs
While those are the two biggies, there are other nuanced differences on things like the suspension and brakes. So, if you’re curious, you can dig into the specs yourself below.
2024 Toyota Grand Highlander 2023 Toyota Highlander
Horsepower Gas: 265 hp @ 6,000 rpm
Hybrid: 245 hp @ 6,000 rpm
Hybrid MAX: 362 hp @ 6,000 rpm
Torque Gas: 310 lb.-ft. @ 1,700-3,600 RPM
Hybrid MAX: 400 lb-ft. @ 2,000- 3,000 RPM
Engines Gas: 2.4-liter 4-cylinder Turbo
Hybrid: 2.5- Liter 4-Cylinder Hybrid
Hybrid MAX: 2.4-liter 4-cylinder turbo Hybrid MAX
Compression Ratio Gas: 11.0:1
Hybrid: 14:1
Hybrid MAX: 11.0:1
Gas: 11.0:1
Hybrid: 14:1
Horsepower (gas engine) Gas: 265 hp @ 6,000 rpm
Hybrid: 187 hp @ 6,000 rpm
Hybrid MAX: 265 hp @ 6,000 rpm
Torque (gas engine) Gas: 310 lb.-ft. @ 1,700-3,600 RPM
Hybrid: 177 lb-ft @ 4,300-4,500 rpm
Hybrid MAX: 332 lb-ft. @ 2,000- 3,000 RPM
Hybrid: 175 lb-ft @ 4,400 rpm
Ignition System Toyota Direct Ignition (TDI) Toyota Direct Ignition (TDI)
Fuel System D-4S D-4S
Recommended Fuel 87-octane unleaded or higher 87-octane unleaded or higher
Emission Certification SULEV 30 SULEV 30
Estimated Fuel Economy (city/highway/combined MPG) Gas XLE/Limited FWD 21/28/24
Gas XLE AWD 21/27/23
Gas Limited/Platinum AWD 20/26/22
Hybrid XLE FWD/AWD 36/32/34
Hybrid Limited AWD 35/31/33
Hybrid MAX Limited/Platinum AWD 26/27/27
Gas FWD 22/29/25
Gas AWD 21/28/24
Hybrid FWD/AWD XLE>Bronze = 36/35/36
Hybrid AWD Limited + Platinum = 35 /34/35
Net Horsepower Hybrid: 245 combined net hp
Hybrid MAX: 362 combined net hp
Hybrid: 243 combined net hp
Motor Type: Permanent Magnet Synchronous Permanent Magnet Synchronous
Battery Pack: NiMH NiMH
Battery Capacity [3hr] (Ahr) Hybrid: 5.0 Ah
Hybrid MAX: 5.0 Ah
Hybrid: 5.0 Ah
Nominal Voltage Hybrid: 259V
Hybrid MAX: 288V
Hybrid: 259V
System Voltage Hybrid: 259 V
Hybrid MAX: 288 V
Hybrid: 259 V
Drivetrain Gas: Front-Wheel Drive (FWD); Dynamic Torque Control AWD (All-Wheel Drive)
Hybrid: Electronic On-Demand AWD (All-Wheel Drive)
Hybrid MAX: Full-Time Electronic AWD (All-Wheel Drive)
Gas: Front-Wheel Drive (FWD); All-Wheel Drive (AWD); XSE, LTD, PLTM AWD = Dynamic Torque Vectoring AWD
Hybrid: L to PLTM FWD (Front-Wheel Drive); LE to PLTM Electronic On-Demand AWD
Transmission Type Gas: Direct Shift – 8AT, 8-speed Electronically Controlled automatic Transmission
Hybrid: Electronically controlled Continuously Variable Transmission (ECVT)
Hybrid MAX: Direct Shift – 6AT, 6 speed automatic transmission
Suspension Font: Independent MacPherson strut suspension with stabilizer bar
Rear: Multi-link suspension with stabilizer bar
Front: Independent MacPherson strut front suspension with stabilizer bar; trailing-wishbone suspension (XSE on gas model uses a sport-tuned MacPherson strut front suspension with stabilizer bar)
Rear: Multi-link rear suspension with stabilizer bar
Steering Type: Electric Power Steering (EPS); electric power-assisted rack-and-pinion Electric Power Steering (EPS); electric power-assisted rack-and-pinion
Turning Circle Diameter (curb- to-curb) 19.03 ft 37.4 ft.
Brakes Ventilated disc Front: Power-assisted Ventilated disc
Rear: Solid Disc (gas); Solid Disc with Electronically Controlled Braking (ECB) system and integrated regenerative braking (hybrid)
Anti-lock Brake System (ABS) Standard Standard
Wheels and Tires XLE: 18” Aluminum wheel with all season tires
Limited : 20” Aluminum wheel with all season tires
Platinum : 20” Aluminum wheel with all season tires
L/LE: 18-in. Painted Alloy
XLE: 18-in. Machined Alloy
XSE: 20-in, Machined Painted Alloy (gas only trim)
Bronze Edition: 18-in. bronze-finish alloy wheels (hybrid only trim)
Limited:: 20-in. Alloy with Chrome Finish (gas); 20-in. Alloy (hybrid)
Platinum: 20-in. Painted Alloy
Spare Tire/Wheel Temporary Temporary
Wheelbase 116.1 in. 112.2 in.
Overall Length 201.4 in. 194.9 in.
Overall Width 78.3 in. (w/o mirrors) 76.0 in.
Overall Height 70.1 in. (without antenna) 68.1 in.
Ground Clearance 8.0 in. 8.0 in.
Seating Capacity 7 or 8 7 or 8
Headroom w/ panoramic moonroof Front: 40 in.
Second: 38.5 in.
Third: 37.2 in.
Front: 38.4 in.
Second: 37.1 in.
Third: 36.1 in.
Headroom w/out panoramic moonroof Front: 41.5 in.
Second: 40.2 in.
Third: 37.2 in.
Front: 39.9 in.
Second: 39.4 in.
Third: 36.1 in.
Legroom Front: 41.7 in.
Second: 39.5 in.
Third: 33.5 in.
Front (gas/hybrid): 42.0/40.4 in.
Second (gas/hybrid): : 38.7/41.0 in.
Third (gas/hybrid): : 28/27.7 in.
Shoulder Room Front: 60.2 in.
Second: 58.8 in.
Third: 57.5 in.
Front: 59.0 in.
Second: 58.4 in.
Third: 55.0 in.
Hip Room Front: 56.5 in.
Second: 57.0 in.
Third: 45.7 in.
Front: 57.2 in.
Second: 57.0 in.
Third: 45.6 in.
Cargo Volume Front: 97.5 cu. ft.
Second: 57.9 cu. ft.
Third: 20.6 cu. ft.
Front: 84.3 cu. ft.
Second: 48.4 cu. ft.
Third: 16 cu. ft.
EPA Passenger Volume 149.0 cu. ft. (Panoramic Moonroof)
153.3 cu. ft. (Normal roof)
Gas/hybrid: 138.9/136.1 cu. ft. (Panoramic Moonroof)
Gas/hybrid: 144.5/141.3 cu. ft. (Normal roof)
EPA Class Midsize SUV Midsize SUV
Curb Weight (FWD/AWD) XLE FWD: 4,300 lbs.
Limited FWD: 4,420 lbs XLE AWD: 4,455 lbs.
Limited/Platinum AWD: 4,575 lbs. XLE Hybrid FWD: 4,455 lbs.
XLE Hybrid AWD: 4,575 lbs. Limited Hybrid AWD: 4,710 lbs.
Limited/Platinum Hybrid MAX AWD: 4,920 lbs.
Gas L FWD/AWD: 4,155/4,332 lbs.
Gas LE FWD/AWD: 4,155/4,332 lbs.
Gas XLE FWD/AWD: 4,199/4,376 lbs.
Gas XSE FWD/AWD: 4,221/4,420 lbs.
Gas LTD FWD/AWD: 4,265/4,453 lbs.
Gas PLTM FWD/AWD: 4,265/4,453 lbs.
Hybrid LE FWD/AWD: 4,330/4,465 lbs.
Hybrid XLE FWD/AWD: 4,365/4,515 lbs.
Hybrid BRONZE FWD/AWD: 4,365/4,515 lbs.
Hybrid LTD FWD/AWD: 4,430/4,595 lbs.
Hybrid PLTM FWD/AWD: 4,430/4,595 lbs.
GVWR (FWD/AWD) XLE/Limited FWD: 6,010 lbs. XLE/Limited/Platinum AWD: 6,030 lbs. XLE Hybrid FWD: 6,030 lbs.
XLE Hybrid AWD: 6,085 lbs. Limited Hybrid AWD: 6,125 lbs.
Limited/Platinum Hybrid MAX AWD: 6,340 lbs.
Gas L to Platinum: 5,870/5,970 lbs.
Hybrid LE to Platinum: 5,960/6,000 lbs.
Max Towing Capacity Hybrid: 3,500 lbs.
Gas/Hybrid MAX: 5,000 lbs.
Hybrid: 3,500 lbs.
Fuel Capacity 17.17 gal. (Hybrid/Hybrid MAX)
17.83 gal. (Gas)
Gas: 17.9
Hybrid: 17.1
There are a lot of things to consider when buying a three-row family hauler – from fuel economy all the way to whether it’ll fit in your garage. In the Toyota Grand Highlander vs. Highlander comparo, both vehicles are stylish and have comfortable ride and handling for a road trip, but the question is which one will be right for you and your family. Sure, check out the specs, but get in a solid test drive, too.
The 2024 Toyota Grand Highlander will be available in July.
