NHTSA expands Bosch CP4 fuel pump investigation, millions of vehicles affected
April 14, 2023
11 comments
Bosch CP4 fuel pump
2023 Jeep Gladiator Rubicon (Photo courtesy of Stellantis)
If you are familiar with heavy-duty diesel engines, then you are all too aware of the Bosch CP4 fuel pump, which has led to catastrophic engine failures in Ram, GM and even Ford heavy-duty trucks.
This key issue seems to be that our diesel fuel in the U.S. doesn’t have the same lubricity as diesel fuel used in Europe, causing wear between the cam and roller and generating small metal shavings that could be released into the fuel system.
The release of these metal shavings into the fuel system can cause catastrophic failure.
Probe expanded?
According to CarComplaints.com, the original CP4 failure investigation included 2019-2020 Ram 2500, Ram 3500, Ram 4500 and Ram 5500 trucks equipped with 6.7-liter Cummins engines.
With such a checkered history, the NHTSA Office of Defects Investigation has decided to expand its safety probe to include any automakers who have installed the CP4 fuel pump.
The upgraded probe now includes the 2014-2022 Ram 1500 trucks as well as 2021-22 Jeep Gladiator, 2014-20 Jeep Grand Cherokee and 2020-22 Jeep Wrangler vehicles. They are also looking at 2014-18 BMW 328D, 2014-16 BMW 535D and 2015-17 BMW X3 vehicles.
A recent AutoNews.com report says the CP4 fuel pump will be looked at again, and any vehicle with it – including many trucks and SUVs – could be recalled.
The Bosch CP4 fuel pump has been a hot topic of conversation, with a multitude of lawsuits and complaints connected to it.
What if your vehicle has the Bosch CP4 fuel pump?
If you have a vehicle with the Bosch CP4 fuel pump, you do have some options – you know, other than waiting for a lawsuit to be ruled on. GM and Ram trucks can be retrofitted with the Bosch CP3. Ford trucks can opt for a CP4.2 bypass kit from S&S Diesel Motorsport, and there is now a retrofit option here as well.
Another option to prevent failure is using an additive like LX4 Lubricity Extreme to help increase lubrication and prevent the metal shavings from forming.
While we generally have an overly litigious society, these Bosch CP4 fuel pump lawsuits have legs with many owners reporting upwards of $10k in damages. Then there’s the issue of whether some automakers knew of the problem and went forward with using the fuel pump anyway.
With at least seven active suits, spanning several states, a final resolution could take some time.
11 comments
  • Since 2007 when USEPA mandated ULSD the below question has never been answered
    The ASTM HFRR test is an abortion. A complete joke. Where does the HFRR test duplicate pressure like a modern-day diesel fuel system? Bosch CP4 pump failures prove the current ASTM lubricity test is a complete abomination
    I would like to ask you a question, in all your years of experience, has anyone ever defined for you the meaning of “Diesel Fuel Lubricity”? Beyond just the words? I have looked high and low and from here to there for even a technical definition by anybody and I have found nothing. Sulfur has no lubricating properties whatsoever.
    Or put another way. Outside of the ultra-low sulfur diesel fuel excuse. Do you know what causes diesel fuel to have poor lubricity? What is causal mechanism in the fuel that is causing the diesel fuel the poor lubricity problem?
  • 2012 F350 Powerstoke, and spent over 10,000 for complete new Fuel system due to CP4 failure, I would like to be on the list to get updates as to when Ford could reimburse us or some type of compensation.
  • .Mark Schnautz
    Then why did Marathon terminals install lubricity tanks at the terminals when they switched to UL sulfur diesel? Sulfur is a lubricant for fuel pumps.
  • I have a 2022 Ford F350 6.7 with 55000 miles on it and 2 months ago the high pressure fuel pump went out. Took it to the dealership was told not covered under warranty. Got it back back 2 weeks ago and it started flashing up on the display reduced engine power and would cut off. Took it back to dealership. They have had it going on 2 weeks and told us they don’t know what is going on and they don’t know how to fix it.
  • David Holloway
    My 2016 f-250 with 70K miles is in the shop for the second time in the last 3 years, the first one cost over $12,000 and when I pick it up this Friday, it will cost over $18,000. CP)4 pump
  • Yup. My cp4 grenaded and trashed my entire fuel system over the weekend on our way to family vacation. EVERYTHING in the fuel system has to be replaced. $14,000 repair bill. thanks Bosch.
  • Carlo Verledens
    I live in Europe Belgium ; have a grand cherokee diesel 130000 km and a failed CP4 pump , yes even with the european fuel it fails .
    if you look in germany 2nd hand car sales “Mobile.de” you can find a lot of grand cherokee ‘s diesel with broken engine all with Cp4 pumpsfailure does it is not the faulty Diesel but a faulty construction that is the reason of the failures. . now i am left with a 10 year old vehicle with no valuable at all and a big cost to repair with a bad conceived pump again …. i hate it bosch isnt worth to even make auto parts
  • Bosch should be held accountable for the cp4 pump failure. I have a 2016 GMC duramax an had the pump failure in Oct 2022 costing over $11,000 to fix and supposedly they put a upgraded version of the cp4 and here in Jan 2024 it went out also twice in less than 15 months.would like to get in on this lawsuit for this can’t afford to fix it this time. If you have a website where I can get in on suit against GM would you send to me at [email protected]
  • My 2015 duramax cp 4 let go 12000 to fix can u send the link for the lawsuit one i found didn’t include Az i would greatly appreciate it thanks
  • I have a 2023 F250 Limited. Brought it to the Ford Dealership due to a check engine Light. They suggested I change the fuel filter and had them do it. Went out of town and broke down 120 miles from home. My truck has 24K miles on it and Ford is telling me it’s not covered due to contamination in the Diesel Fuel. I filed a claim with Progressive and they say that they can’t see evidence of contamination. I have owned Ford most of my life and always buy new to avoid problems.
