2024 Jeep Wrangler 4xe specification chart
April 7, 2023
2024 Jeep Wrangler 4xe specifications chart
New 2024 Jeep® Wrangler Rubicon X 4xe
The 2024 Jeep Wrangler 4xe specification chart has all the details on the new model.
For the 2024 Jeep Wrangler 4xe, it gets some significant changes while leaving the powertrain options alone. You can read the top five things you need to know here.
Here are all the details:
2024 Jeep® Wrangler 4xe
SPECIFICATIONS
Specifications are based on the latest product information available at the time of publication.
All dimensions are in inches (millimeters) unless otherwise noted.
All dimensions measured at curb weight with standard tires and wheels.
General Information
Vehicle Type Sport-utility vehicle
Assembly Plant Toledo North Assembly Plant, Toledo, Ohio
EPA Vehicle Class Multipurpose vehicle
BODY/CHASSIS
Layout Longitudinal front engine, four-wheel drive
Construction Ladder-type frame, open steel and aluminum body
Engine: 2.0-LITER TURBO I-4
Availability Standard (all ESS)
Type and Description I-4 16-valve with direct injection, turbo charging, with throttled, cooled exhaust gas recirculation (EGR)
Displacement (cu. in. / cc) 121 cu. in. (1995 cu. cm)
Bore x Stroke 3.31 x 3.54 (84 x 90)
Valve System Chain-driven DOHC, 16 valves
Fuel Injection Direct injection
Construction Aluminum block, aluminum alloy heads
Compression Ratio 10.0:1
Power (SAE net) (hp / kW @ rpm) 270 hp (200 kW) at 5,250 rpm
Torque (SAE net) (lb.-ft. / N•m) 295 lb.-ft. (400 N•m) at 3,000 rpm
Max. Engine Speed (rpm) 5,800 rpm (electronically limited)
Fuel Requirement Minimum unleaded regular, 87 octane (R + M)/2; 91 octane or higher recommended for optimum fuel economy and performance
Fuel Tank Capacity (gallons) 17.2
Oil Capacity 5 quarts (4.7 liters)
Coolant Capacity 9.9 quarts (9.4 liters)
Emission Controls GPEC4 engine-management system with close-coupled catalyst and wide range O2 sensor
Max. Gross Trailer Weight 3,500 lbs.
EPA Fuel Economy mpg (MPGe/combined) 49/20
Assembly Plant Termoli, Italy and Trenton South Engine Plant, Trenton, Michigan
eTORQUE BELT-START GENERATOR/MOTOR
Peak Power 44 hp (33 kW)
Starting Torque 39 lb.-ft. (53 N•m)
TRANSMISSION: 8P75PH PHEV AUTOMATIC, EIGHT-SPEED OVERDRIVE
Description Plug-in hybrid automatic transmission with AC traction motor with Motor Interrupting Clutch and Integrated Launch Element; adaptive electronic control and Auto Stick driver-interactive manual control
Gear Ratios
1st 4.71
2nd 3.14
3rd 2.11
4th 1.67
5th 1.28
6th 1.00
7th 0.84
8th 0.67
Reverse 3.32
INTEGRATED TRANSMISSION TRACTION MOTOR
Peak Power 134 hp (100 kW)
Peak Torque 181 lb.-ft. (245 N•m)
HIGH VOLTAGE BATTERY
Chemistry Lithium Ion Li-NMC
Charging Modes Level 1 — 120V AC, Level 2 — 240V AC
Operating Voltage 260 – 400 VDC
Gross Capacity 17.3 kWh
Maximum Charge Rate 7.2 kW
TOTAL POWERTRAIN OUTPUT
Peak Combined Power 375 hp (280 kW) at 5,250 rpm
Peak Combined Torque 470 lb.-ft. (637 N•m) at 3,000 rpm
TRANSFER CASE: MP3022 Selec-Trac
Available Standard — Sport S 4xe, Willys 4xe, Sahara 4xe, High Altitude 4xe
Type Full-time
Operating Modes 2WD High (N/A 392); 4WD Auto; 4WD High; Neutral; 4WD Low
Low Range Ratio 2.72:1
TRANSFER CASE: MP3022OR ROCK-TRAC
Available Standard — Rubicon 4xe
Type Full-time
Operating Modes 2WD High; 4WD Auto; 4WD High; Neutral; 4WD Low
Low Range Ratio 4.0:1
Axles
Front 3rd generation Dana axles
Differential type Open or Tru-Lok electronic locking (Rubicon 4xe models)
Rear 3rd generation Dana axles
Dana 44 HD Full Float (Rubicon 4xe)
Differential type Open (Sport S 4xe, Sahara 4xe)
Trac-Lok anti-spin (High Altitude 4xe)
Tru-Lok electronic locking (Willys 4xe, Rubicon 4xe)
Axle ratios 3.73 (Sport S 4xe, Sahara 4xe, High Altitude 4xe),
4.10 (Willys 4xe, Rubicon 4xe)
ELECTRICAL SYSTEM
Architecture Powernet
DC/DC Converter Capacity 2.5 kW
Low Voltage Battery 600 CCA, maintenance free (standard)
700 CCA, maintenance free (optional)
Suspension
Front Solid axle, link coil, leading arms, track bar, coil springs, stabilizer bar
Stabilizer bar Electronic sway-bar disconnect system — (Rubicon 4xe)
Shock type Sport S 4xe, Willys 4xe, Sahara 4xe, High Altitude 4xe: High-pressure gas-charged monotube shock absorbers with MTV technology
Rubicon 4xe: High-pressure gas-charged monotube shock absorbers with MTV technology and hydraulic rebound stop
Rear Solid axle, link coil, trailing arms, track bar, coil springs, stabilizer bar
Rubicon 4xe: High-pressure gas-charged monotube shock absorbers with hydraulic rebound stop
STEERING
Type Electro-hydraulic power
Overall ratio 14.9:1
Turning diameter (curb-to-curb) (ft) 38.9
Steering Turns (lock-to-lock) 3.1
P/S Pump Electro-hydraulic
BRAKES
Type Hydro-electric anti-lock braking system with fully blended regeneration capacity
Front
Rotor size and type 12.9 x 1.1 (330 x 28) vented rotor
Caliper size and type 2 (51) twin-piston floating caliper
Rear
Rotor size and type 14 x .86 (350 x 22) vented rotor
Caliper size and type 2 (51) single-piston floating calipers
Dimensions and Capacities
Wheelbase 118.4 (3,008)
Overhang — Front 29.5 (749.8)
Overhang — Rear 40.3 (1,023)
Track — Front 64.4 (1,636)
Track — Rear 64.4 (1,636)
Overall Length (includes spare tire) 188.4 (4,785)
Overall Width 73.9 (1,877)
Overall Height 73.5 (1,868)
CLEARANCES
Clearances 245/75R17
Standard on Sport S 4xe
LT285/70R17
Standard on Willys 4xe
275/55R20
Standard on
Sahara 4xe
275/55R20
Standard on
High Altitude 4xe
LT285/70R17
Standard on
Rubicon 4xe
Approach Angle (degrees) 42.2 43.8 42.2 42.2 43.8
Breakover Angle (degrees) 22.0 22.5 22.0 22.0 22.5
Departure Angle (degrees) 35.2 35.6 35.2 35.2 35.6
Ground Clearance (inches) 10.1 10.8 10.1 10.1 10.8
Ramp Travel Index (Front Sta-bar disconnected) N/A N/A N/A N/A 770.0
Water fording (inches) 30.0 31.5 30.0 30.0 31.5
CURB WEIGHT
Curb Weight 2.0-liter PHEV (4-door)
Wrangler Sport S
Automatic Transmission (lbs./kg) 5,049 (2,290)
Wrangler Willys
Automatic Transmission (lbs./kg) 5,075 (2,302)
Wrangler Sahara
Wrangler High Altitude
Automatic Transmission (lbs./kg) 5,265 (2,388)
Wrangler Rubicon
Automatic Transmission (lbs./kg) 5,226 (2,371)
Accommodations
Seating Capacity (front/rear) 2/3
SAE Total Interior Passenger Volume,
(cu. ft. / cu. m) 103.3 (2.93)
Front
Headroom 40.8 (1,036) hardtop, 42.6 (1,083) soft top
Legroom 40.8 (1,038)
Shoulder room 55.8 (1,417)
Hip room 53.9 (1,370)
Seat travel 8.1 (206)
EPA front volume index 54.6 (1.55)
Rear
Headroom 40.3 (1,023) hardtop, 41.7 (1,059) soft top
Legroom 38.2 (970)
Knee clearance 61.6 (1,565.9)
Hip room 55.9 (1,421)
EPA rear seat volume index (cu. ft. / cu. m) 48.7 (1.38)
Liftover height 29.7 (756.4)
Load floor height 30 (762.1)
Maximum cargo width at liftgate opening 47.9 (1,218.7)
Minimum cargo width at liftgate opening 41.1 (1,052)
Maximum cargo height at liftgate opening 36.0 (942.3)
Minimum cargo height at liftgate opening 35.7 (907.8)
Distance between wheelhouse interior trim 45.0 (1,143)
SAE Cargo Volume
Rear seat folded 67.4 cu. ft. (1.91)
Rear seat upright 27.7 cu. ft. (0.78)
Total passenger plus cargo volume, (cu. ft. / cu. m) 131.0 / 3.71
WHEELS
Availability Standard (Sport S 4xe)
Type and material Machined Baltic Gray aluminum
Size 20 x 8.0 in.
Availability Standard (Willys 4xe)
Type and material Black painted cast aluminum
Size 17 x 7.5 in.
Availability Standard (High Altitude 4xe)
Size 20 x 8 in.
Availability Standard (Sahara 4xe)
Type and material High Gloss Black painted aluminum
Size 20 x 8 in.
Availability Standard (Rubicon 4xe)
Type and material Machined aluminum with black painted pockets
Size 17 x 7.5 in.
TIRES
Size and type 255/60R20, on/off-road, black sidewall
Mfr. and model Nexen Roadian HTX2
Revs per mile (km) 652 (405)
Size and type 255/55R20, on/off-road, black sidewall
Size and type 275/55R20, on/off-road, black sidewall
Mfr. and model General Grabber AT Sport
Revs per mile (km) 674 (419)
Availability Standard (Rubicon and Willys 4xe)
Size and type LT285/70R17C, on/off-road, black sidewall
Mfr. and model BFGoodrich All-Terrain T/A KO2
Revs per mile (km) 637 (396)
TOWING CAPACITIES
WRANGLER Sport S 4xe
Engine Trans
Type
Transmission Axle
Ratio
Payload Base Wt. Base Wt.
Front
Base Wt.
Rear
GAWR
Front
GAWR
Rear
GCWR Max
Trailer
2.0-liter I-4 gas PHEV A8 8P75PH 8-speed automatic 3.73 1398.0 5049.0 2529.0 2520.0 3100.0 3550.0 9100.0 3500.0
GCWR = Base Weight + EPA OPTIONS WEIGHT + 2 Passenger Weight + Trailer weight rating + Trailer equipment
WRANGLER WILLYS 4xe
Engine Trans
Type
Transmission Axle
Ratio
Front
Base Wt.
Rear
GAWR
Front
GAWR
Rear
GCWR Max
Trailer
2.0-liter I-4 gas PHEV A8 8P75PH 8-speed automatic 4.1 1270.0 5177.0 2593.0 2584.0 3100.0 3550.0 9100.0 3500.0
WRANGLER SAHARA 4xe
Engine Trans
Type
Transmission Axle
Ratio
Front
Base Wt.
Rear
GAWR
Front
GAWR
Rear
GCWR Max
Trailer
2.0-liter I-4 gas PHEV A8 8P75PH 8-speed automatic 3.73 1378.0 5075.0 2519.0 2506.0 3100.0 3550.0 9050.0 3500.0
GCWR = Base Weight + EPA OPTIONS WEIGHT + 2 Passenger Weight + Trailer weight rating + Trailer equipment.
WRANGLER High Altitude 4xe
Engine Trans
Type
Transmission Axle
Ratio
Front
Base Wt.
Rear
GAWR
Front
GAWR
Rear
GCWR Max
Trailer
2.0-liter I-4 gas PHEV A8 8P75PH 8-speed automatic 3.73 1188.0 5265.0 2589.0 2676.0 3100.0 3550.0 9200.0 3500.0
WRANGLER RUBICON 4xe
Engine Trans
Type
Transmission Axle
Ratio
Front
Base Wt.
Rear
GAWR
Front
GAWR
Rear
GCWR Max
Trailer
2.0-liter I-4 gas PHEV A8 8P75PH 8-speed automatic 4.1 1328.0 5226.0 2579.0 2554.0 3100.0 3550.0 9250.0 3500.0
This information is only for the 4xe version of the 2024 Jeep Wrangler. Click here for the 2024 Jeep Wrangler specification chart.
