Curious case of missing transmission oil cooler on 2019-2020 Toyota Tundra
August 12, 2020
15 comments
transmission fry toyota tundra
One of the hallmarks of the Toyota Tundra, for its fans and consumers, has been reliability especially with the stories of the million mile trucks. With a powertrain, and the overall truck, having been largely untouched since 2007, the idea is all the kinks have been worked out. However, a relatively unnoticed change, the removal of the transmission oil cooler, has caused a huge uproar, and irate owners are even talking about a class-action lawsuit.
Starting in the 2019 model year and extending into 2020, Toyota Tundra and Sequoia vehicles saw the removal of the transmission oil cooler. This external cooler is designed to reduce the heat in the transmission, which can lead to catastrophic part failures.
How much heat? The conventional wisdom for years has been it should be less than 200 degrees when empty and below 225 degrees when towing (between 175 and 225). Anything higher than these numbers can cause the fluid to break down and seals as well as parts to fail.
Chart courtesy of Transmission Repair Guy.
Owners tracking temps
Over the course of the last few months, we have had several owners come forward with stories of their trucks running higher transmission temperatures than they would like. Doing more investigation, we discovered the transmission oil cooler was missing.
One of the affected owners went from a 2017 Tundra to a 2020 Tundra and proceeded to tow the same load as he did before. Now, his 2020 Toyota Tundra is throwing error codes at him for overheating.
Tundra owners screenshot of transmission fluid temps
As he looked into the issue, he discovered the transmission was operating a little higher than 220 degrees empty and presumably climbing much higher towing. While he hasn’t used his phone app with the OBD2 sensors to track temperatures when towing, he has dealt with a persistent issue of a high transmission temperature warning on the dash.
He believes this happens when the transmission surpasses 304 degrees.
Temperature gauge warning.
He has had the truck checked out by the dealer and has since ordered a new ATF cooler to install on his truck like another owner.
The other owner, who goes by DirtE30 on YouTube, has not only documented his issues but also created a series of videos on how to install an ATF fluid cooler as well as how his fluid looked after 40,000 miles (before switching to Valvoline Maxlife ATF fluid, more on this further down). It is an interesting watch and you can see his temperatures dropping 10-20 degrees after installing the cooler.
Finally, the big issue for a lot of owners is the feeling of being misled. The sales stickers (aka Monroney labels) for the Tundra and Sequoia haven’t been changed to show the transmission oil cooler is no longer installed. This scan of the sticker shows the transmission oil cooler on it under the tow package. It’s a bit blurry, so we are working on getting a new one.
2020 Toyota Tundra TRD Pro sticker
The sales sticker from the Toyota Tundra owner, referenced above.
This has lead many owners to discuss calling an attorney, filing a class-action lawsuit or other such action to force Toyota to install the transmission oil coolers since it was listed on the sticker.
Toyota responds claiming all is fine
We reached out to Toyota on this issue and they said in separate conversations and interviews, the truck’s transmission was operating as it should. Plus, in the case, of the owner with the overheating transmission message, it is likely a sensor issue causing the error code to be thrown (the owner tells us, he has had his truck checked out by the dealer and the dealer can’t find anything wrong).
Why are the temps higher in the first place? Toyota says the higher temps are just a byproduct of new synthetic automatic transmission fluid allowing them to run hotter than conventional oil. The chart above is based on old conventional oil and as such is outdated in their view.
There is some merit to this statement. For years, Toyota “WS” is/was the transmission fluid used in their vehicles. So, what is the WS, and who makes it? Well, those are trade secrets long used by all automakers to ensure consumers use their products.
While, we can’t narrow down exactly what that fluid is or if they have changed it like they claim to a synthetic oil, we can compare it to the leading alternative transmission synthetic fluid called the Valvoline Maxlife.
This new synthetic ATF fluid can withstand higher temperatures than the conventional oil.
In fact, according to a posted email exchange on Toyota-4Runner.org, we learned the fluid can operate as high as 280 degrees albeit for a short period of time before it decreases quickly. It is worth noting this decreasing quality is much slower than conventional fluid according to Valvoline.
Finally, Valvoline also says if your transmission runs hotter than 200 degrees, they recommend having it checked out. In their view, a transmission shouldn’t be running that hot.
Towing temperature?
Driving around empty is one thing, but what happens to the transmission when you are towing a heavy load? Our understanding is towing a truck can add around 35 degrees of increased temperature for the transmission. This means, if the truck is already running at 220 degrees, it should top out at less than 260 degrees.
While 260 degrees seems like it is quite high for a lot of owners,  Toyota says this is within the acceptable range for the truck.
The question really isn’t about the fluid as even Valvoline says their fluid can withstand the higher temps, the question is about the transmission parts — clutch, seals, etc. Can those parts withstand the heat? Toyota says it can.
Why change it at all?
The biggest question (and frustration) for many owners is why even make the change at all? With one of the most highly thought of powertrains for reliability, this change seems backwards.
Toyota’s Chief Engineer Mike Sweers told us in an interview, Toyota made the change after discovering they no longer needed the part to keep the transmission within acceptable operating range.
Basically, engineering was out testing the truck, as all automakers do, and discovered they simply didn’t need the cooler to hit their operating range targets. By removing the transmission oil cooler, they could still be within an acceptable range and, according to Toyota, they would not damage the transmission.
Our video interview with Sweers includes his answer:
The transmission does still have a heater to warm up the fluid on cold days as well as an engine oil coolant to reduce heating issues.
It is worth noting, we reached out to our YouTube viewers for their truck’s automatic transmission fluid temperatures. Unlike Toyota, many automakers have an electronic gauge available to owners on the dash. We have received many different responses with different brands of trucks, engines from across the country. It seems, to us anyway, the newer trucks are running higher temperatures than the older trucks. This is pretty odd considering all other half-ton trucks come with a transmission oil cooler when selecting the tow package.
Finally, we hope Toyota will update their sales stickers after this story comes out. It sounds like a simple miscommunication between engineering and marketing.
What about other trucks?
Another question was raised by viewers about other truck makers. One in particular wondered: Why Toyota would eliminate something that is part of every towing package offered by other manufacturers? Naturally, this got our curiosity up on which other trucks offered a transmission oil cooler and if it was part of a towing package.
Turns out all the other truck makers offer one as standard equipment.
Specifically, Ram’s Trevor Dorchies, product communications and media relations for Ram Truck, said you don’t need any sort of towing package, it is standard equipment much the same as Chevy’s Mike Ofiara told us.
Ford said their new 2021 Ford F-150 “2.7L, 3.3L, 5.0L, 3.5L FHEV, and 3.5L all use the same trans mounted one cooler across the board. 3.0L has a unique trans cooler design that is common with the last gen 3.0L,” according to Dawn McKenzie, Ford Truck communications manager.
Nissan’s Steve Parrett, regional communications manager, said it is standard equipment on the Titan.
The bottom line on transmission oil coolers
For years, an auxiliary transmission cooler was thought to be a common-sense, standard piece of equipment on trucks designed to tow. Now, it seems like there is some disagreement between Toyota and consumers on whether or not you need it.
The real controversy is really about how long the transmission will hold up to the additional heat. Newer synthetic fluids don’t seem to be the issue — the parts are the real concern.
Toyota running their trucks without coolers sounds like a bad idea, yet we haven’t heard of a rash of transmission problems related to overheating.
In our view, the owner, mentioned above, either has a sensor issue the dealer can’t locate or something else is amiss. And we agree, it definitely seems like Toyota owners have been misled thanks to the sticker.
What do you think? Is this a big issue or a small issue many people are making into a big issue? Are auxiliary transmission oil coolers a thing of the past?
VIDEO: Crazy! Another 2007 Toyota Tundra Breaks the Million Mile Mark
Next-gen 2022 Toyota Tundra could get new diesel engine: No def? Better MPGs?
Toyota Tacoma Still Reliable? Engine/Transmission Issues Plague Reliability Scores
15 comments
  • Justin Wallace
    Ws stands for world standard. Also WS is NOT a synthetic fluid. It’s made by Exxon and they verified it’s NOT synthetic. You are giving out alot of bad and miss information in the youtube video.
  • I’m a new Toyota TUdnra TRD Pro 2020 owner and made sure my trucks sticker had the towing package with the expectation that the truck would include a trans cooler among other things and match part of part what as per what was labelled. I’m super pissed to find it doesn’t have the aforementioned trans cooler and am now in the process of collecting the 2017 model hard lines, trans thermostat, Hayden or B&M trans cooler. The bolt holes and cooler line brackets are already in place from the factory which makes it easy. Toyota just swapped out the trans thermostat with a pass thru spacer plate to the trans heater. So you simply swap the spacer plate with the thermostat and connect it to your new lines running to the trans cooler.
  • When I purchased my 2019 Tundra Platinum, the tow package said “eng/trans coolers”. I looked in the grill and saw the power steering cooler which I mistook for the transmission cooler. About a month later I saw a YouTube video that described the transmission cooler as being “integrated” with the engine radiator. So I called Toyota and got a case number, then went back to the dealer and they explained the heat exchanger. It was over a year later when I saw the YouTube video with the Toyota engineer describing the transmission cooler was removed to reduce mass and drag. So the sticker was misleading, especially when page 604 of the Owners Manual describes transmission fluid capacities “with towing package” and “without towing package”.
  • Richard Medina
    I’m currently exploring legal option in this fraud. Please post any legal actions you may have taken.
    • Mr. Medina, please let me know if you get anywhere with this.
      Thanks
      Walter
      A fellow tundra owner
  • I currently have 2020 tundra with 20,000 miles and is at the dealership having a new transmission installed because it overheated and lost 5th and 6th gears. Window sticker stated it also had trans cooler, trans temperatures unloaded 225 to 230 degrees, loaded with 3500 lb trailer 245 to 260 degrees at the pan. At one time even saw 274 degrees, Toyota’s response about the lack of advertised trans cooler being on the window sticker is that it was a miss print. The new replacement trans showed up with the factory thermostat attached along with the warmer. Still waiting to hear back from Toyota corporate if they are going to add the cooler and lines. But as of this time the field agent said no because that would be modifying the trucks transmission. You can’t even make this stuff up how ridiculous does that sound.
    • A
      Well here’s to hoping the new transmission lasts longer. I’ve been down the road arguing with them over their decision. Thanks for speaking up. If they see more failures, maybe they will change their minds.
  • I have 2019 1794. I don’t know much about this transmission thing. But I want to know if I paid for something and didn’t get it? I have been looking at my truck very carefully for past 2 years. Every time I look at it, there are small bits and pieces that have been omitted on this truck that other domestic trucks have. I don’t NEED them, but I WANT them. The only conclusion I can reach is that Toyota did this to save money. Higher operating temps, reducing drag and mass are bunch of BS. It’s to reduce cost. Toyota needs give customers what they WANT. Not what they think we NEED. Domestic makers know this too well.
  • This is a bunch of bs. Toyota is ripping off there loyal buyers! I bought my 2019 with plans of keeping it for many years! I tow a toy hauler that is 9000 plus lbs and I will be very pissed if I have Transmis issues especially after buying a truck that is supposed to be built for towing and as far as I am concerned I payed for a transmission cooler! I know that I am in on any legal action taken against Toyota!!!
  • Clarence Easley
    2019 tundra, first pull 8000 lbs outside air temperature 58F, light came on, checked manual, it said cool 15 minutes till
    warning light goes out, well how would this truck hold up in Kansas pulling a load of hay on my farm? Toyota stepped on it this time, typical engineer who is clueless. Got rid of the truck, will never buy another Toyota product!
  • Own a 2019 Tundra this is my third Toyota and because of what I will call bate and switch will be my last.I called toyota got a call back they act like they know nothing about this very disappointed last toyota
  • Kirk Rogozinski
    This is total BS! I too bought a 2019 Tundra double cab TRD off road. I traded my 2012 in on it. My 2012 had a transmission cooler, my 2019 does not! This just doesn’t make a bit of sense to me. I tow my camper & and other trailers on a regular basis. If I experience transmission failure, I’m going to be very disappointed with Toyota. If anyone has any luck with legal action, please let me in on it. Much appreciated!
  • Carlos Padilla
    This is my Third Tundra. the first two had Trans coolers. My second truck I kept for 16 years. I tow boats of different sizes and weight and never had an issue with my 2006 crew cab.
    I then updated to a 2019 Tundra Platinum 4×4.
    My first Trip was in the summer june or july and we were stuck i traffic in Atlanta for about 2 hours stop and go.
    At one point I gave the truck gas and to me the truck was moving but it felt like it was struggling. Once we and started moving the symptoms went away . when I arrived back home in florida I took it to the Dealer, they checked the Trany and the mechanic said That i was bit low on fluid so they added it and said that this happens a lot at the factory.
    I have noticed that in the summer the Truck struggles a bit when the outside temperatures are higher than normal. for instance when the temperature is in the 80″s it runs and has a quick response when you step on it but in the summer is a totally different story.
    I believe that Toyota probably had a supply chain Issue between 2019 and 2021 so they moved on and sold the story stating that their oil is a miracle juice and we should not have any issues.
    If there is a CLASS ACTION LAWSUIT Please inform me as i am all in especially since I have been loyal to To Toyota and owned over 20 new toyotas in the past 30 years. This might be my last one.
    Thank you
  • I have a 2020 tundra on the window sticker it is supposed to be a trans cooler, but it does not. evetime I come up my driveway pulling a ton of pellets the trans overheats. When I looked into it the trans warmer is about 4 inches away from the catalytic converter, and at slow speeds the heat from the converter causes the transmission to overheat. Toyota Corportation not the dealer tells me the truck is not made to do that, I don’t get it.The thing is the truck should have the cooler like it says to me that not being truthful, even Toyota’s chief engineer Mike Sweers that the cooler is not needed.
