Why GM crash-tests its crash-test dummies
November 20, 2026
Crash-test dummies lined up in GM’s test laboratory
Crash-test dummies in GM’s anthropomorphic test device laboratory. Photo: Steve Fecht for General Motors.
GM crash-test dummies have to pass their own tests before engineers can rely on what they reveal about a truck.
That was one of the more interesting parts of GM’s safety program for the 2027 Chevrolet Silverado 1500. Inside the dummy lab, the discussion went beyond putting a mannequin in a seat and crashing a truck. The team explained how they inspect the dummies, test their components and check that their measurements can be compared.
What happens after a crash?
Different sizes of crash-test dummies in GM’s laboratory
GM inspects crash-test dummies and checks their components between tests. Photo: Steve Fecht for General Motors.
After every crash test, the dummies return to the lab for mechanical and electrical inspections. Technicians partially disassemble them, look for damaged components and check that the sensors work.
Parts can be replaced as needed. The team explained that dummies are designed for repeated use, with some skeletons remaining in service for decades.
Testing the test equipment
Clifton Pinion in GM’s crash-test dummy laboratory
Clifton Pinion, GM senior manager of vehicle safety and crashworthiness labs and Pontiac propulsion labs. Photo: Steve Fecht for General Motors.
The lab also subjects dummy components and complete bodies to their own impacts. During our visit, the team described a chest-impact demonstration designed to measure rib deflection and the dummy’s movement.
Those tests help establish that a dummy behaves within specified performance ranges. The goal is comparable and repeatable results between dummies and between laboratories.
That is an important part of the larger crash-testing process. If the measuring equipment changes unpredictably, interpreting the vehicle’s performance becomes harder.
The lab team also showed us next-generation frontal-impact dummies representing an average adult male. GM said examples of that type cost well over $1 million each, without providing a specific price.
That figure was not a price for every dummy in the room. The lab uses different sizes and designs for different impact conditions and test requirements. It does help explain why maintaining and checking the equipment is such a substantial part of the work.
Why not fill every seat?
One question during the visit was why the planned crash test used two dummies rather than filling every seating position.
The engineers said the demonstration followed a specific protocol. They also explained that adding more dummies can complicate data gathering and camera coverage. Other seating positions can be evaluated through additional physical testing and virtual work.
A single demonstration does not show the entire vehicle-development program. It shows one part of a much broader effort to understand how the vehicle and its restraint systems perform.
The crash gets most of the attention, but the equipment behind it matters too. Seeing what happens to the dummies between tests helped explain how much work goes into producing useful crash-test information.
