Making 777 horsepower for one fast lap is one thing. Keeping a pickup pulling lap after lap is another. To see how the 2027 Ram 1500 Rumble Bee SRT would hold up, Ram’s engineers put it through a simulated 24-hour endurance race. Toon Tan, manager of SRT Vehicle Performance Truck Programs, told me he spent about six hours behind the wheel himself.
That run took place in cool weather. In a separate track test at 100 degrees Fahrenheit, the engineers looked for something specific: whether the truck would cut power to protect itself as temperatures climbed. Here’s what they tested and what they changed to keep the Hellcat cool.
1. Six hours behind the wheel in a 24-hour test
Tan said the team ran a 24-hour validation exercise to simulate an endurance race. He didn’t name the track or say he drove the whole test. What stood out to him from his time behind the wheel was how planted the truck felt and how it kept pulling.
He described cool conditions during that exercise. That distinction matters: The 24-hour simulation tells us the team looked at extended use. It doesn’t give us a 24-hour run at 100 degrees or a lap time to compare with another truck.
2. The hot-weather test looked for a drop in power
The engineering team described separate track durability testing in 100-degree heat. Among the things it looked for was a derate, when the vehicle reduces power to protect itself. A quick acceleration number says little about whether a truck can deliver the same punch after it has spent time working hard in the heat.
Ram had already said in its Rumble Bee announcement that it designed the SRT for racetrack use in 100-degree heat. The interview put a more specific test objective behind that claim. It didn’t establish how many laps owners can expect at a given temperature.
3. What the cooling team changed
The engineers described a larger radiator than the TRX’s and a new water-cooled engine oil cooler supplied by the coolest available engine coolant. Ram also says the front fascia moves more air through the cooling system and to the front brakes. The extra airflow and cooling hardware each address a different source of heat.
4. Ram rated the engine with its intake restrictions in place
Ram’s team also explained a different kind of validation: measuring peak power on an engine dyno. The engineers said their test represented the production intake and exhaust restrictions under the revised SAE J1349 standard. With this dual-path intake, they said that meant putting the hood and its duct into the test cell. The 777-hp rating is an engine-dyno result, separate from the endurance simulation or the hot-weather track work.
I’m interested in what happens after a few laps, not just what a 777-hp truck feels like the first time you lean on the throttle. The testing tells us what the engineers were looking for. It’s still their development work, rather than an independent track test. See our first look at the Rumble Bee lineup for the specs Ram announced.
