Chevy put a 2027 Silverado Trail Boss high enough above the floor at the 2026 LA Auto Show that I could walk right under it. I came away with a short list of things I like, plus a few things I’d change before taking one down a rocky trail.
I filmed the walkaround for Pickup Truck + SUV Talk and GT: Garage Talk®. Here’s what stood out while I wait for my own 5.7-liter V8 Custom Trail Boss to arrive.
1. Skid plates up front, plus more bumper clearance
Chevy left the front air dam off the Trail Boss, and I could still see the mounting points. That improves the approach angle when you’re climbing onto a ledge. The air dam can help fuel economy at highway speeds.
A two-piece skid plate covers the engine and oil pan, and a separate plate protects the two-speed transfer case. However, the fuel tank gets no skid plate. That’s where I’d add protection first.
2. Wheels, tires, a 2-inch lift, and new shocks
The Trail Boss gets a 2-inch factory lift. The LA show truck wore 18-inch wheels with Goodyear Wrangler mud-terrain tires, the same setup I ordered on my Custom Trail Boss. The optional 20-inch wheels come with all-terrain tires. I also spotted plain black shocks with no Rancho branding.
3. Chevy sticks with a wax-coated frame and rear leaf springs
The 2027 Silverado Trail Boss rides on a fully boxed frame, and GM is sticking with a wax coating for corrosion protection. Plenty of you have asked about that in the YouTube comments. We’ve already covered why GM uses wax on its new truck frames.
Chevy also kept rear leaf springs. The Ram 1500 and Toyota Tundra use rear coil springs, which can help smooth out the ride.
4. Underbody cameras are available on the Trail Boss
Chevy used to reserve the underbody camera for the ZR2. It’s now available on the upper-trim Trail Boss. The camera unit sits next to the transfer case and gives you forward and rearward views under the truck. A passenger can watch the screen and help you place the tires around obstacles. I wish Chevy offered it on the Custom Trail Boss I ordered.
5. I’d trade the temporary spare for a matching tire
The spare tucked under the show truck looked like a temporary tire. Space is tight between the rear axle, bumper, and hitch, but I’d rather have a spare that’s a closer match for the four Goodyear mud-terrains. A flat on a rocky trail is exactly when I’d want the same tire I started with.
The show truck’s 3.0-liter Duramax had an easy-to-reach oil filter and a fully exposed drain plug. Once my Custom Trail Boss arrives, I’ll put it on a lift to see how the 5.7-liter V8 compares.
What else should I check while I’m under there?
