2023-2027 Ford F-150 Recall: Fuel Tanks May Leak or Detach in 223K Trucks
Bianca Bailey
Bianca Bailey
September 17, 2026
2026 Ford F-150 (Photo courtesy of Ford Motor Company)
Ford is recalling 223,472 F-150 trucks because improperly secured fuel tanks may leak or detach from the vehicles.
Ford Motor Company (Ford) is recalling certain 2023-2027 F-150 vehicles. The fuel tank may be improperly secured and leak fuel, or detach from the vehicle while driving.
NHTSA ID Number: 26V578
Components: FUEL SYSTEM, GASOLINE
Potential Number of Units Affected: 223,472
Descriptive Information
Ford’s team reviewed plant records to determine the population of affected parts. Affected vehicles are equipped with front fuel tank straps that may have been improperly assembled from January 4, 2023, through August 27, 2026, when camera systems to verify proper fuel tank strap assembly were not in continuous use at F-150 vehicle assembly plants. Vehicles from this production period that are either unsold or have less than 3 months in service as of August 27, 2026, are included in the recall population. This population is based on Ford’s understanding of the issue and observed occurrences in the field, which indicate the condition will manifest very early in the vehicle’s lifetime.
Fuel tanks may become unsecured from the vehicle and detach while driving.
An improperly secured fuel tank may cause fuel leaks, which could increase the risk of fire or engine stall from fuel loss. A detached fuel tank also creates a road hazard to other vehicles.
Description of the cause:
In some instances, front fuel tank strap T-slots were not properly inserted into the vehicle’s frame rail at the time of vehicle assembly.
None.
Chronology
On July 23, 2026, an issue pertaining to potentially unsecure fuel tanks was brought to Ford’s Critical Concern Review Group for review.
From July 2026 to August 2026, CCRG reviewed global warranty data for unsecured fuel tanks and worked to understand potential for improper assembly of fuel tank straps. This review identified a number of unsecured fuel tanks affecting F-150 vehicles built during periods when the vision systems that confirm proper assembly were not in continuous usage.
As of August 27, 2026, Ford is aware of 16 warranty claims globally related to this condition received between June 25, 2018 and August 5, 2026.
On September 1, 2026, Ford’s Field Review Committee reviewed the concern and approved a field action.
Ford is not aware of any reports of accident or injury related to this condition.
Remedy
Description of Remedy
Remedy Type: Inspect, Replace
Owners will be notified by mail and instructed to take their vehicle to a Ford or Lincoln dealer to have their fuel tank straps inspected and replaced if necessary. There will be no charge for this service.
Remedy fuel tank straps are the same as the recalled component, but will be properly secured to the frame rail.
Notification to dealers is expected to occur on September 14, 2026. Mailing of remedy owner notification letters is expected to begin September 21, 2026 and is expected to be completed by September 28, 2026. The date VINs are planned to be searchable is September 14, 2026.
2,841 messages 4,731 likes
Ford is recalling 223,472 F-150 trucks because improperly secured fuel tanks may leak or detach from the vehicles. Ford Motor Company (Ford) is recalling certain 2023-2027 F-150 vehicles. The fuel tank may be improperly secured and leak fuel, or detach from the vehicle while driving. Affected VINs should be searchable now at the NHTSA website. Here is the relevant information from the NHTSA Recall notice: NHTSA ID Number: 26V578 Manufacturer: Ford Motor Company Components: FUEL SYSTEM, GASOLINE Potential Number of Units Affected: 223,472 Estimated percentage with defect: 1% Descriptive Information Ford’s team reviewed plant records to determine the population of affected […] (read full article...)
Reply Like
D
Dusdaddy
Well-known member
1,387 messages 2,060 likes
Reporting about a recall with Ford is like reporting that it's hot and humid in Florida; not exactly surprising.
Reply Like
