Planning to order replacement parts for your car or workshop through an online platform? If yes, it’s essential to understand the techniques that you can use to ensure that you order the right item. Purchasing the wrong part leads to stalling of the car you’re working on. And that means time wastage which inconveniences your customers.
You can ensure that the part you want to replace for your vehicle is compatible by applying various techniques. Keep reading to discover the tips and tricks of ensuring that the replacement part is compatible with your car.
Checklist to use when checking compatibility
Ordering your car replacement part can be a daunting task when you lack an accurate checklist for reference. Here is the checklist you can use to help you avoid guesswork and order the correct spare part:
Begin with identity
A Vehicle Identity Number (VIN) has various details, including build month, engine code, and drivetrain and trim. The VIN comprises of a string of numbers found on the car’s windshield and doorjamb. This information is valuable when you want to purchase a spare part compatible with your car.
VIN details help spare part dealers and databases to determine the exact shape of your car. It helps clear ambiguity regarding engine options, drivetrain outline, or regional specs that have an impact on spare part attachment.
When you want to make a virtual order of a replacement part, it’s critical to indicate your VIN on your purchase order. Some websites allow users to decode their VIN when creating the order.
Check the OEM part number
An essential detail that can help you when making an order is the Original Equipment Manufacturer (OEM). You can find this information on the original part or plant documentation. It’s normally stamped, inscribed, or labeled part number.
Once you have the OEM, cross-reference it directly in OEM registers or with secondary market counterparts. Remember, numerous parts are updated by the manufacturer over time. So, applying OEM helps you know whether a new edition has superseded the earliest versions, or there is a compatible part in the aftermarket under a different number.
Apply approved compatibility tools
Compatibility tools help you check whether the item you want to purchase will fit into your vehicle. The aftermarket now has various tools you can use to purchase the right spare parts.
Reputable spare part suppliers use data-driven spare part compatibility equipment like Hollander Interchange. These tools are made on numerous data points, including verified part matches across different models and years. When you’re not sure whether a used spare part will function, request the supplier to verify it through an interchange database.
Check trim level and submodel information
Some vehicles under the same model line can still have different parts depending on their trim. For example, a base model and a luxury trim apply different suspension formats, lighting systems, and interior apparatuses. For example, a 2023 Honda Accord LX and a 2023 Accord Touring may apply diverse entertainment systems. So, performing a car parts comparison exercise is crucial before buying the replacement part. The information is essential as it helps buy the right replacement spare.
Factor in regional differences
Some cars are made with different specs depending on the region. A car sold in Washington DC might have a different emission system than a similar make sold in Oklahoma. Similarly, Canadian or export vehicles have different sensors, lighting components, or electrical harnesses due to different rules. It’s essential to check whether your car is a USA spec, European model, or oversea-market version.
Check pinout and voltage when purchasing electrical parts
A vehicle’s electrical parts can look similar to replacement parts prompting you to make a haste buying decision. But looking similar isn’t a guarantee the spare parts will function on your car. It’s critical to check the pinout and voltage before purchasing the replacement part.
Online buying of your vehicle’s replacement parts can save time and money if done properly. Smart shoppers must equip themselves with knowledge before ordering the spare part online. The tips and hacks shared here helps you to buy the right item. Whether you’re buying the spare part for your vehicle or a customer’s, it’s crucial to follow the checklist above.
