How to Avoid Blind Spot and Underride Accidents Around Semi-Trucks
Pickup trucks sit in a strange middle zone on the highway. Tall enough to feel confident next to a sedan, but still small enough to disappear entirely in a semi’s mirrors. That gap between how a truck feels and how visible it actually is causes more close calls than most owners realize.
The Federal Motor Carrier Safety Administration tracked more than 5,700 fatal crashes involving large trucks in 2021 alone, the most recent year with finalized federal data. A meaningful share of those crashes involved a passenger vehicle caught in a blind spot or merging too close behind a trailer.
The Federal Motor Carrier Safety Administration tracked more than 5,700 fatal crashes involving large trucks in the past 5 years. This is the most recent year with finalized federal data. A meaningful share of those crashes involved a passenger vehicle caught in a blind spot or merging too close behind a trailer.
For Californians involved in these high-impact collisions, consulting a truck accident lawyer California, such as The May Firm, can help clarify how federal trucking regulations, commercial insurance policies, and questions of liability may affect a potential claim.
Where a semi’s blind spots actually sit
Big rig blind spots, sometimes called “No-Zones,” extend along both sides of the trailer, directly behind it, and a long stretch in front of the cab. A pickup truck riding alongside a trailer’s rear wheels is almost always invisible to the driver, regardless of mirror setup.
The front blind spot surprises most drivers the most. A truck driver sitting high in the cab can lose sight of a pickup that’s merged in too closely ahead, especially on an uphill grade where the trailer’s nose blocks the view further.
A simple rule helps here: if you can’t see the truck driver’s face in their side mirror, they can’t see you either.
Why underride guards matter more than most owners think
An underride crash happens when a smaller vehicle slides partially beneath a trailer during a collision, and the National Highway Traffic Safety Administration has linked these crashes to a disproportionate share of trucking fatalities relative to their frequency. Rear underride guards are federally required, but side underride guards still aren’t standard on most trailers nationwide.
This matters most during sudden lane changes or hard braking situations, where a pickup following too closely behind a trailer has far less reaction room than it would behind a passenger car. Following distance behind a semi should be longer than instinct suggests, not shorter, because the trailer blocks your view of traffic conditions ahead just as much as it blocks the driver’s view of you.
Towing changes the equation again
Pickup owners towing a trailer of their own face a second layer of risk, since a loaded truck-and-trailer combination handles differently in an emergency maneuver than an unloaded pickup. Stopping distance increases substantially with a loaded trailer, which shrinks the safety margin even further when traveling near commercial trucks already operating with long stopping distances of their own.
Checking trailer brake controller settings before a long highway trip, and avoiding tailgating any large vehicle while towing are two of the simplest habits that meaningfully reduce risk on routes shared with commercial freight.
What actually happens after a collision with a commercial truck
When a crash does happen between a pickup and a semi, the aftermath looks different than a standard two-car accident. Commercial trucks are required to carry electronic logging devices under FMCSA rules, which record speed, braking, and hours-of-service data that can become central to understanding exactly what happened.
“We see this pattern constantly in trucking cases, the data tells a more complete story than either driver’s memory of the crash,” says Robert May, founder of The May Firm, a California personal injury practice that has handled trucking collisions, including a case where a client was rear-ended by a tractor-trailer. “Pulling that data quickly, before it gets overwritten, often makes the difference in understanding what really happened.”
That urgency is worth knowing even before a crash happens. If you’re ever involved in a serious collision with a commercial truck, photographing the trailer’s company markings, DOT number, and any visible camera equipment can support a later request for the carrier’s own internal records.
A few habits that reduce risk on every drive
Stay out of the lane directly beside a trailer’s rear half whenever possible, and pass decisively rather than lingering in a blind spot during a slow overtake. Leave extra following distance in rain or fog, since a semi’s spray can cut visibility dramatically faster than a passenger vehicle’s would.
Watch for wide right turns, since large trucks frequently swing left before turning right to clear the trailer’s wheelbase, a maneuver that catches pickup drivers off guard when they assume the truck is simply changing lanes. And resist the urge to squeeze into a gap in front of a truck right after passing, that’s the front blind spot, and it’s bigger than it looks from the driver’s seat.
None of this requires giving big rigs a wide berth out of fear. It just means treating visibility, not size, as the thing that actually determines safety when a 5,000-pound pickup and an 80,000-pound rig share the same lane.
Reading a trailer’s turn signals from further back
Most pickup owners watch the cab for turn signals, but a trailer’s own signal lights sit much further back and can flash slightly out of sync with the cab’s, especially on older equipment. Watching the whole rig rather than just the cab gives a split second more warning before a lane change actually begins.
That extra half-second matters more than it sounds. At highway speed, a truck drifting into an adjacent lane covers significant ground before a following driver has time to react, which is exactly why staying out of the No-Zone in the first place is more effective than reacting quickly once you’re already in it.
Night driving adds a layer most owners underestimate
Trailer running lights and reflective tape are designed to outline a trailer’s shape in low light, but a poorly maintained trailer can have missing or dirty reflectors that make it harder to judge its true length and position at night. Pickup drivers approaching from behind should slow earlier than daylight habits suggest, since a trailer’s actual silhouette can be harder to read than it appears.
Glare off wet pavement compounds this further, scattering headlight reflections in ways that can make a trailer’s edge genuinely difficult to distinguish from the surrounding road surface during a nighttime rainstorm.
Weigh stations and rest areas carry their own risks
Pickup owners towing trailers sometimes share weigh station entrances and highway rest areas with commercial trucks maneuvering in tight quarters, and these low-speed environments produce a surprising number of minor collisions every year. Trucks backing into spots or pulling out from an angled parking row often have limited visibility of smaller vehicles positioned at an angle behind them.
Parking with enough clearance to avoid being directly behind or beside a parked truck’s blind spot, even in a rest area, is a habit worth building before it becomes necessary.
A final word on staying visible, not just careful
Keeping headlights clean and properly aimed, replacing dim taillights promptly, and avoiding lingering in any blind spot longer than necessary all do more for highway safety than most owners realize. Visibility works both ways: a truck driver who can clearly see your pickup is far less likely to make the kind of sudden lane change that causes a serious collision in the first place.
Sharing the road with commercial freight isn’t going away, especially on routes that connect major distribution hubs to the rest of the country. Understanding exactly how a big rig sees, and doesn’t see, the road around it remains one of the simplest and most effective things any pickup owner can do to stay safe on long highway stretches.
