2018 Ford F-150 Recall: 11k Transmission Gear Indicator Malfunction
2018 ford f 150
2018 Ford F-150 (Photo Courtesy of Ford Motor Company)
A recall of 10,742 Ford F-150 pickups for the transmission gear indicator on the dashboard potentially displaying the wrong gear, leading to unexpected vehicle movement and increased risks of a crash.
Ford Motor Company (Ford) is recalling certain 2018 F-150 vehicles previously repaired incorrectly under recall number 17V669. Quickly moving the shift lever from Park to Drive may cause a loss of gear indication on the instrument cluster display and a momentary selection of an unintended gear, such as Reverse or Neutral.
The date VINs are planned to be searchable is July 6th, 2026.
NHTSA ID Number: 26V375000
Components: POWER TRAIN
Potential Number of Units Affected: 10742
Descriptive Information:
The Ford process is capable of determining which software part numbers have been installed in production and service. Affected vehicles may not have received the Powertrain Control Module (PCM) software remedy for Ford Recall 17S35 / 17V669.
Description of the defect or noncompliance:
According to Ford’s records, certain 2018 MY Ford F-150 vehicles did not have the remedy for Safety Recall 17S35 / 17V-669 installed correctly but were recorded as having the repair successfully completed. Because the correct software update remedy may not be installed on the vehicle, the underlying condition specified in Safety Recall 17S35 / 17V-669 may still exist on 3.3L engines and 6-speed transmissions with a column mounted shift lever, and the rapid movement of the transmission shifter from Park to Drive (~30 milliseconds) may cause loss of PRNDL gear indication in the instrument cluster and momentary (<1 second) engagement of Reverse operation before the vehicle achieves forward Drive function. This could result in unintended vehicle movement. An operator could alternatively experience momentary Neutral operation rather than Reverse.
The underlying safety risk specified in Safety Recall 17S35 / 17V-669 still exists on this specified vehicle. Ford described that safety risk as, “Unintended vehicle movement may increase the risk of accident or injury.”
Description of the cause:
The Powertrain Control Module (PCM) calibration may not properly process intended gear selection when the column mounted shift lever is rapidly moved from Park to Drive. This vulnerability exists with a column shifter cable that is installed at one end of its full adjustment. On vehicles with this condition, rapid column shift movement (~30 milliseconds) from Park to Drive can overshoot the shift cable position into the “Drive/Manual” gear selection transition-zone. This can cause the PCM calibration to command a momentary, inaccurate gear selection into either Neutral or Reverse based on the last PRNDL position recognized by the PCM.
None.
Chronology
On November 26, 2024, an issue pertaining to incomplete software recall remedies was brought to Ford’s Critical Concern Group (CCRG) for review. This issue was initially identified in a Quality Office forum, where an audit was requested for software part numbers applied to vehicles remedied under a sample of field service actions (FSAs). Initial review of three FSAs revealed insufficient data to confirm correct software application across all FSAs using the current field service tool, known as FDRS. CCRG decided to conduct further investigation.
In December 2024, a cross-functional team was formed to audit all software FSAs that used the FDRS service tool, with its first focus being on safety and compliance FSAs. Templates were created to track software lineage part numbers.
On December 19, 2024, Ford informed NHTSA of this concern — the service tool data confirmed that the software state on the service tool at the time of installation matches the FSA software release for most vehicles. However, there are vehicles that do not have a match between the software state on the service tool and the FSA software release. Ford discussed with NHTSA its plan to address the mismatched vehicles.
In January 2025, the cross-functional team created database records to store all software lineage part numbers for previously launched FSAs. The team then began auditing the current software level for every VIN repaired under several previously launched FSAs.
In March 2025, during a comprehensive audit of software-related FSAs dating back to 2017, discrepancies were identified during the transition between the legacy field service tool, known as IDS, and the new FDRS service tool. The audit revealed that implementation inconsistencies found in FDRS could also be present within the IDS software as well as a significant lack of historical data. Further investigation was deemed necessary.
In November 2025, a harvest program was approved to assess the success of remedies applied using the IDS tool for programs administered during this transition period. Results of this harvest program showed that in some FSAs, the intended remedy software may not have been successfully applied to all vehicles.
On April 16, 2026, the matter was presented to the Critical Concern Review Group (CCRG). The CCRG determined that several FSAs that had a recall remedy implemented using the IDS tool may have been closed without that remedy being installed. As a result, an activity was initiated to verify the software levels of vehicles that previously received these FSA repairs. The VINs included in this program are both (1) VINs confirmed to contain the incorrect software, and (2) VINs with a closed FSA, but the software version cannot be confirmed due to gaps in the records.
On May 27, 2026, Ford’s audit team confirmed that the software state matched the FSA software release in a subset of vehicles out of the total population of completed FSA 17S35 remedy repairs.
On June 2, 2026, Ford’s Field Review Committee reviewed the concern and approved a field action.
Ford is not aware of any reports of accident or injury related to this F-150 condition.
Owners will be notified by mail and instructed to take their vehicle to a Ford or Lincoln dealer to have the PCM software updated. Then, the software part numbers will be validated using the Software Validation Form in the Professional Technician System before the FSA is closed. There will be no charge for this service.
Ford provided the general reimbursement plan for the cost of remedies paid for by vehicle owners prior to notification of a safety recall in May 2023. Owners who have paid to have these repairs completed at their own expense may be eligible for reimbursement, in accordance with the recall reimbursement plan on file with NHTSA.
The software service package will have the intended remedy for 17S35 / 17V-669.
Identify how/when recall condition was corrected in production:
Not required per 49 Part 573.
Notification to dealers is expected to occur on July 6th, 2026. Mailing of remedy owner notification letters is expected to begin July 6th, 2026, and is expected to be completed by July 10th, 2026.
