Leitner Designs Launches New GearPOD HD Truck Bed Storage Box With 20% More Space
May 21, 2026
GearPOD HD Truck Bed Storage Box 1
The new Leitner Designs GearPOD HD Truck Bed Storage Box. (Photo courtesy Leitner Designs)
Leitner Designs has announced the new GearPOD HD, a third-generation version of its side-mounted truck bed storage system designed for heavy-duty use and increased storage capacity.
New GearPOD HD by Leitner Designs
The new GearPOD HD is built from 11-gauge 5052 H32 aluminum instead of the rotomolded construction used on the standard GearPOD XL. According to Leitner Designs, the aluminum construction allows the company to eliminate internal ribbing and increase usable storage space by 20 percent while keeping the same exterior dimensions and nearly identical weight.
GearPOD HD Truck Bed Storage Box 2
Redesigned for 20% more storage. (Photo courtesy Leitner Designs)
The company says the GearPOD HD was developed for overlanders, contractors and truck owners wanting a more durable storage solution mounted to the side of the bed rack system.
Leitner says the new storage box is compatible with existing Active Cargo System (ACS) rack setups and can directly replace the current GearPOD XL.
Features include:
  • 11-gauge 5052 H32 aluminum construction
  • Gas strut assisted door
  • Steel locking latch with internal two-point locking system
  • 20 percent more usable storage space than the GearPOD XL
  • Made in the USA
GearPOD HD Truck Bed Storage Box 3
Proudly made in the U.S.A. (Photo courtesy Leitner Designs)
GearPOD HD weighs 50 pounds and measures 48.75 inches long, 15.845 inches deep and 15.125 inches tall.
Leitner Designs has set pricing at $999.99.
GearPOD HD Truck Bed Storage Box 4
It has a locking feature as well and integrates with the Active Cargo System rack design. (Photo courtesy Leitner Design)
We recently installed a Leitner ACS rack system with a Gear Pod XL on our Ford F-150 project truck and found the modular design added significant side storage for camping gear and tools while keeping the bed more organized. You can read that story here: Upgrading Our F-150 With a Leitner Designs ACS Rack for Camping Gear, Storage and Daily Use
