2026 Jeep Grand Cherokee Gets New Hurricane 4 Engine: Engineer Explains Why Jeep Dropped The V6
May 27, 2026
Hurricane 4 4
The new turbocharged Hurricane 4 engine. (Photo by Tim Esterdahl)
Jeep is making a major change to the 2026 Jeep Grand Cherokee lineup by replacing the traditional V6 with the brand-new Hurricane 4 turbocharged engine. This has created a lot of concern, so we asked their chief engineer to answer many of the top questions.
In this interview from our video interview, Jeep Hurricane 4 Chief Engineer Ashish Dubet explains why Stellantis developed an entirely new engine architecture, how the turbulent jet ignition system works, and why the company believes this four-cylinder can handle decades of ownership while improving both performance and fuel economy.
Our journalist Cory Fourniquet conducted the interview, I transcribed the video.
Why Develop An All-New Hurricane 4 Engine?
Hurricane 4 3
Journalist Cory Fourniquet interviewing Ashish Dubet (Screenshot by Tim Esterdahl)
Q: Is this truly a brand-new engine architecture?
Ashish Dubet:
“Yes. This is the first application for this engine in the entire Stellantis lineup. The only shared component with today’s 2.0-liter turbo engine is the oil filter. Everything else is brand new.”
Dubet further explained Jeep wanted an engine capable of matching the Grand Cherokee’s “dual personality” by balancing luxury SUV refinement with off-road capability and towing performance. Rather than modifying an older engine design, engineers started with a clean-sheet approach to avoid future limitations on strength, power and fuel system upgrades.
According to Dubet, the primary objective was avoiding trade-offs between performance, fuel economy and refinement.
What Is Turbulent Jet Ignition And How Does It Work?
Hurricane 4 6
The new small chamber that is key to the turbulent jet ignition system. (Photo by Tim Esterdahl)
Q: What makes the Hurricane 4 combustion system different?
Ashish Dubet:
“We call it turbulent jet ignition. Think of a conventional spark plug like a lighter. This system works more like a blowtorch.”
The Hurricane 4 uses a passive pre-chamber system mounted inside the combustion chamber. Instead of igniting the air-fuel mixture directly inside the cylinder like a traditional spark plug, the spark occurs inside a small chamber. Flames then shoot through multiple small openings into the cylinder at extremely high speed.
Dubet said the result is:
  • Faster combustion
  • More complete combustion
  • Reduced knock
  • Better emissions performance
  • Increased power output
The company claims the engine produces 20 percent more power while using 10 percent less fuel compared to the current 2.0-liter turbocharged engine.
How Does Jeep Improve Performance And Durability?
Hurricane 4 5
What about durability? (Photo by Tim Esterdahl)
Q: How does a small turbocharged four-cylinder handle long-term durability concerns?
Ashish Dubet:
“When engineers design something from the beginning, we account for peak cylinder pressures, temperatures and fatigue over tens of years.”
Jeep engineers added several technologies aimed at improving both drivability and durability:
  • Variable geometry turbocharger
  • Miller-cycle combustion
  • 350-bar direct injection
  • Port fuel injection
  • Spray bore cylinder coating
  • Larger crankshaft and main bearings
  • Structural oil pan and windage tray
  • Single-piece die-cast block design
Dubet said the variable geometry turbocharger helps improve low-end responsiveness while maintaining high-end power.
The addition of port fuel injection also helps reduce concerns over carbon buildup often associated with direct injection-only engines.
Engine structure was another major focus. Jeep increased cylinder wall thickness by 24 percent compared to previous designs to better handle higher cylinder pressures over long-term use.
Can The Hurricane 4 Replace The Grand Cherokee V6?
Hurricane 4 2
The new Hurricane 4 engine in the engine bay of the 2026 Jeep Grand Cherokee. (Photo by Tim Esterdahl)
Q: Can this engine really replace the outgoing V6?
Ashish Dubet:
“We’re not saying this is a replacement for a V8. But compared to the Pentastar V6, this engine delivers more power, more torque and better fuel economy while maintaining full towing capability.”
According to Jeep, the Hurricane 4 delivers:
  • 31 more horsepower than the Pentastar V6
  • 72 lb-ft more torque
  • 10 to 15 percent real-world fuel economy improvement
  • Full 6,200-pound towing capability
Dubet also emphasized that low-end torque was a major development target to improve highway merging and towing performance without requiring high engine RPM.
Noise and vibration reduction was another engineering priority since many buyers associate four-cylinder engines with harshness. Jeep says extensive work was done to improve cabin refinement and reduce unwanted engine noise entering the passenger compartment.
Final Thoughts
Hurricane 4 1
The new 2026 Jeep Grand Cherokee. (Photo courtesy of Jeep)
The new Hurricane 4 represents one of the biggest powertrain changes Jeep has made to the Jeep Grand Cherokee in years. Instead of downsizing an existing engine, Stellantis developed an entirely new turbocharged four-cylinder architecture aimed at balancing fuel economy, towing capability, refinement and performance.
Whether longtime Jeep buyers embrace a four-cylinder Grand Cherokee remains to be seen, but the engineering behind the new Hurricane 4 is clearly far more extensive than simply bolting on a larger turbocharger.
