New Ford Bronco Spotted With New Front End, Interior Changes
April 6, 2026
New Ford Bronco Spotted 1
A new Ford Bronco model has been spotted with several changes. (Photo courtesy Glenn Paulina)
A new Ford Bronco has been spotted driving around Ford’s proving grounds without camo showing a new front end and interior changes.
New Ford Bronco Spotted 2
Exterior and interior changes for this new Ford Bronco. (Photo courtesy Glenn Paulina)
This prototype Ford Bronco was spotted by our spy photographer and shows many unique changes inside and outside.
This makes sense to see new Ford Bronco variants with Ford stating their will not be a traditional mid-cycle refresh instead opting to hold off until 2029 for a fully redesigned model as a 2030 model.
Our spy photographer had the following to say about this prototype.
New Face Unexpectedly Uncovered
New Ford Bronco Spotted 3
The new grille has few changes versus current production models. (Photo courtesy Glenn Paulina)
It was only days ago that we got our first look at a disguised Bronco prototype on Ford’s test track, displaying a fully-covered grille, and curiously-wrapped rear wheel arches and disguised backlight.  Now we have the same spec Bronco prototype running on public roads, but its grille is completely uncovered—revealing a new treatment to its BRONCO lettering, and a fine grille mesh unlike anything seen on the Bronco since it was resurrected in 2020.
A Move Upmarket?
New Ford Bronco Spotted 5
The camo-wrapped rear wheel arches raises some questions. (Photo courtesy Glenn Paulina)
Prior Bronco press events have suggested that Ford is considering moving the Bronco brand into the Work space, while also considering a move upmarket into a more luxurious Premium space.  This Bronco has the same front bumper as the Badlands and Heritage trims—both of which sit above the Outer Banks in the Bronco trim hierarchy.  The prototype also shows signs of the Fox shocks from Ford’s HOSS 3.0 set-up, confirming proper Bronco off-road prowess.  These details would seem to rule out a Work-level specification, and point to something more upmarket.
A Peek Inside—More Premium Details?
New Ford Bronco Spotted 4
The interior shows new materials. (Photo courtesy Glenn Paulina)
Our initial sighting of this new Bronco trim involved a prototype with a fully-covered dashboard, suggesting some interior changes.  This new prototype was driving without any dash-camo, revealing a subtle detail that may also point to a higher-tier trim-level than the Badlands or Heritage.  The prototype showcased a dashboard finished in a new material, displaying nice stitching details only found on its top two trims—the Bronco Stroppe Edition and the Raptor.  Everything from the Heritage Edition and below doesn’t have such detailing, suggesting that this new prototype might be positioned above the Badlands and Heritage Broncos—skewing it toward a more Premium offering.  The prototype’s apparent Badlands bones says it will still be formidable off-road, but may get more posh detailing for those that might be considering something a bit more…Land Rover.
New Wheels
New Ford Bronco Spotted 6
A new wheel design was spotted as well. (Photo courtesy Glenn Paulina)
We see an all-new wheel design on this Bronco prototype, with a clean, relatively deep-dish six-slot design.  The wheels have a new outer rim that looks bead-lock-capable.  Ford appears to have done some shaving to the tire’s sidewalls, but we can see that they’re Sasquatch-sized Goodyear Territory RTs.
The front wheel arches are undisguised, but they appear to be graced with new front splash guards that attached elegantly to the trailing edge of the wheel arches, for a sleek fit.  There are no running boards on the street-tested prototype, but the track tested-tested prototype appears to be have new side sills that may also serve as rocker guards.  Then there are those wrapped rear wheel arches, which remain a mystery.  New badges are covered up on the track-testing Bronco’s front fenders.
Articulation/Clearance Testing?
New Ford Bronco Spotted 7
The new Ford Bronco being tested. (Photo courtesy Glenn Paulina)
The engineers were caught running the prototype over a particularly punishing track surface, and then over to a set of dips that would challenge wheel articulation and approach and departure angles.  The prototype appears to have some green plastic bits screwed onto the undercarriage, perhaps to test for clearances.  An engineer appeared to be filming the testing, perhaps for later analysis.  It would seem that Ford would have these clearances well worked out by now, so we’re left to wonder if any further suspension or driveline changes may have been employed, which would change the underbody geometry.  Ford boss Jim Farley has confirmed that a hybrid Bronco is coming.
There’s still lots to learn about the future trims and special editions planned for the Bronco lineup, but this new prototype has given us our most detailed look yet at what Ford has cooking.  Stay tuned for more details, as testing ramps up.
No replies yet
2,822 messages 4,724 likes
A new Ford Bronco has been spotted driving around Ford’s proving grounds without camo showing a new front end and interior changes. New Ford Bronco Spotted This prototype Ford Bronco was spotted by our spy photographer and shows many unique changes inside and outside. This makes sense to see new Ford Bronco variants with Ford stating their will not be a traditional mid-cycle refresh instead opting to hold off until 2029 for a fully redesigned model as a 2030 model. Our spy photographer had the following to say about this prototype. New Face Unexpectedly Uncovered It was only days ago […] (read full article...)
