You want a commuter car that can handle snow or dirt roads? Race on down to your local Subaru dealer.
The 2026 Subaru Crosstrek Hybrid is not the best hybrid nor the best small SUV, but the admittedly rather narrow Venn diagram where they meet has one new superstar capable of 36 mpg no matter how it’s driven.
Is third time the charm for the Subaru Crosstrek Hybrid?
I have an admittedly long history with the Crosstrek Hybrid; a decade or so ago, I was one of the dozen automotive journalists to dunk one into a semi-frozen river in Iceland. While much more not fuel-efficient than the standard model, the original 2014 XV Crosstrek Hybrid proved to be durable. Nearly a decade later, Subaru tried again, this time with a plug-in hybrid Crosstrek largely limited to markets that followed California’s emissions standards.
The third time’s the charm. This time, Subaru bolted in two electric motors fed by a lithium-ion battery pack that supplement the 2.5-liter flat-four. In all, the Crosstrek Hybrid puts out 194 hp, all while achieving 36 mpg city, 36 mpg highway, and 36 mpg combined using the EPA’s test cycles.
True, some rivals offer better fuel economy, but the Crosstrek Hybrid retains a relatively simple, fast-acting mechanical connection to its rear differential rather than the rear-mounted electric motors found in competitors like the Toyota RAV4 Hybrid and Toyota Corolla Cross Hybrid. Also, the Crosstrek Hybrid sits 8.7 inches off the ground and it rides on conventional all-season rubber instead of the low-traction, low-rolling-resistance rubber mounted to competitors.
Using the Crosstrek Hybrid to the Fullest
The rocky logging trail I piloted a 2026 Croosstrek Hybrid down proved no serious obstacle for this high-riding hybrid. At lower speeds, it happily motored along on electric power alone. Unlike the prior plug-in hybrid version of the Crosstrek, you can’t expect to go far on electricity, however, and the digital instrument cluster’s display showing whether the gas or electric motors are providing propulsion is light on details.
Sure, there’s an EV Mode button to the left of the steering wheel, but it all it does is emphasize electric power unless you mash the throttle. Do so and the Crosstrek Hybrid zips forward with decent power in reserve for highway passing; it’s not quick, but it’s perfectly fine. It’s also rather quiet, with little of the underhood whine you might expect from a hybrid system. The continuously variable automatic transmission (CVT) mostly fades to the background, aided here by the boost of instant low-end torque courtesy the electric drive motor. (The other motor mostly serves to shuffle regeneration power back into the system.)
What’s the downside?
If there’s any downside to the Crosstrek Hybrid, in terms of capability, it’s that the battery system takes up the place where the spare tire would otherwise go. That’s a bummer for anyone planning to go off-road since the safety net provided by a spare is priceless.
The hybrid version of the Crosstrek retains the gas-only model’s X-Mode traction control system, which, after tapping your way to where it’s displayed on the remarkably low-resolution vertical touchscreen, tweaks various electronic parameters to improve grip in low-traction situations. There’s no low range here, but there doesn’t need to be one; the Crosstrek Hybrid is adept at trundling its way down a gnarly driveway or to a trailhead. A rock-crawler it is not.
Does that make the Crosstrek Hybrid a good buy?
Subaru sells the 2026 Crosstrek Hybrid in mid-level Sport ($35,415, with a $1,420 destination charge) and higher-end Limited ($36,415) trim levels. Those work out to $3,400 and $2,000 premiums over the non-hybrid Crosstrek Sport and Crosstrek Limited, respectively.
Is it a good buy then? Well, maybe. The Sport version has a power-adjustable driver’s seat, blind-spot monitors, a 12.3-inch digital instrument cluster, navigation, and a sunroof. That’s a lot of stuff for $3,400, none of which is available without the hybrid powertrain.
The Limited’s $2,000 upcharge nets a digital instrument cluster, Harman/Kardon audio, a heated steering wheel, and navigation. Again, not a bad buy, all things considered.
And then there’s the fuel-economy boost. At 36 mpg combined rather than 29 mpg combined for the non-hybrid, the gasoline-electric version may eventually pay for itself in fuel savings — with those features as an added bonus.
