Electric Trucks CAN Tow Cheaper than Gas? 2026 GMC Sierra EV AT4 Towing With a 30′ Camper Shocker
August 22, 2025
32 comments
2026 GMC Sierra EV AT4 Towing 1
How is the 2026 GMC Sierra EV AT4 towing a camper? That’s a question we had to answer. (Photo by Tim Esterdahl)
Many people hate on electric trucks for towing, but is it really that bad? I towed the 2026 GMC Sierra EV AT4 with a 30′ camper was shocked.
The Sierra EV AT4 was part of my regular rotation of review vehicles and I connected it to our new 2024 Coleman 30′ double-axle camper with one slide out. It has a dry weight of around 5,300 pounds empty and 7,000 pounds loaded. I charged the Sierra EV up at home on my 220 volt outlet to 100%, normally you keep it charged at 80% as the truck tells you to do so for optimal battery health, for the most range possible out of the maximum range battery pack on this truck.
Our test model is the $93,000 2026 GMC Sierra EV AT4 Max Range with up to 725 horsepower, 478 miles of electric range (not towing), DC Fast Charging, 800 volt, up to 350 kW. Standard ProGrade trailering system (available on Extended Range) and Standard MultiPro Midgate (available MultiPro Midgate on Extended Range).
Hookup and Specs for the 2026 GMC Sierra EV AT4 Towing
2026 GMC Sierra EV AT4 Towing 2
Squat? Nope. A good weight distributing hitch and that problem is solved. (Photo by Tim Esterdahl)
Getting the camper hitched to the Sierra EV was straightforward. The large 16.8 inch diagonal infotainment screen might be a target for critics who think trucks have gotten too fancy, however, it is really nice when trying to use the numerous camera systems available on newer trucks. Selecting the hitch view eliminates the need for another person’s help and lining up the truck’s ball to the camper tongue is incredibly easy. A real marriage saver technology.
With a weight-distributing hitch in place, there was virtually no squat at the rear and the truck and camper are level, a big deal for towing safely.
The Sierra EV is well suited for this job with a maximum towing capacity is rated at 10,000 pounds. It also has 1,500 pounds of payload per a VIN-specific door jamb sticker. This means all passengers, gear and the tongue hitch weight must be below 1,500 pounds. If I can’t determine the tongue hitch weight on the manufacturer’s sticker provided on the camper, I use the 10% rule of the weight of the camper either empty or loaded weight. The camper was empty as far as water and the gray/black tanks, so the tongue weight would be 530 lbs (10% of 5,300 lbs). This leaves 970 pounds for the rest of the passengers and gear which should be plenty for a family of four.
On the Road: Smooth and Effortless
2026 GMC Sierra EV AT4 Towing 3
Super Cruise engaged means sitting back and relaxed even when towing. (Photo by Tim Esterdahl)
Towing with an EV feels very different from a gas or diesel truck. Acceleration is instant—no gears, no turbo lag, just torque on demand. From 30 to 60 mph, the Sierra pulled the camper effortlessly, smooth and quiet all the way. Driver fatigue is noticeably lower, especially paired with Super Cruise, which worked well even with the trailer in tow.
Climbing grades did draw heavy power, but regenerative braking downhill recaptured energy, acting much like a diesel exhaust brake—without the noise. On winding Nebraska highways, the Sierra felt stable, confident and easy to handle even at highway speeds.
The AT4 trim adds off-road rubber and rugged styling, while still packing the smooth ride you’d expect from an EV even with off-road tires.
Inside, the vertical infotainment screen dominates the dash, complemented by a head-up display and improved seating comfort—finally, GM has nailed the seats. Rear passengers benefit from heated outboard seats, a flat load floor, and good cargo versatility. Up front, a large frunk provides additional storage.
Range Reality Check
2026 GMC Sierra EV AT4 Towing 4
Seat comfort sucks? Not anymore with the Sierra EV seats. These things are like the GM sofa cushions of old. (Photo by Tim Esterdahl)
The trip covered about 50 miles, with the Sierra averaging around 1.5 miles per kWh. Starting with a full charge showing 250 miles of estimated range, I ended with 76% battery and 165 miles remaining. Translation: towing a 7,000-pound camper roughly cuts range in half.
That’s not unexpected—physics doesn’t change just because it’s electric. Still, the truck’s performance showed that a 100–120 mile tow to a campground is realistic on a single charge.
Once you arrive at the campground, you’ll have some options. You could charge at the campground since many have 220 volt hookups in the U.S. with 30 or 50 AMP service. This would mean you would have to juggle plugging in the camper or the truck sacrificing running items like the air conditioning in the camper.
The other option would be to find a public charging spot near the campground and spend time charging up the truck. This charging time varies on many factors, but plan for around 30 minutes. With some of these charging sites located near grocery stores, it could be a two birds, one stone kind of thing.
How Much Does it Cost Versus a Gas or Diesel Truck?
2026 GMC Sierra EV AT4 Towing 7
How much does it really cost to tow with an electric truck? It depends. (Photo by Tim Esterdahl)
Ok, the electric truck can tow your camper, so what? What does this all cost? And how does this compare to a gas or diesel truck? Is it worth the money?
There are about a million different factors, so this is going to be very general.
Let’s assume you were two different ways – home vs public charging.
For the 50-mile tow drive, I would spend around $13 in electricity charging back up to 100 percent (keep in mind, I’d only charge to 100 for towing, 80% for daily driving) versus the same trip is $45 for our long-term 2025 Ram 1500 RHO with premium fuel, $40 for non-premium. Diesel would be around $35.
For the 100-mile tow drive, if I could charge up the truck at the campground, I’d have free electricity since campgrounds haven’t caught on to electric vehicle charging yet. So, I’d have the same pricing scenario above.
For the 100-mile tow drive with public charging, Electrify America, a well-known public charging company, commonly charges $0.48 per kWh. Our test model GMC Sierra 1500 EV had the maximum range battery of 205kWh. Let’s say we used half of that battery and needed to add 102.5 kWh energy back into the battery pack. This math works out to be 102.5 x $.48 = $49.20 to fill it back up. Keep in mind, this is perfect world stuff with the EV station running at full capacity, the kWh at that rate and not higher, the truck taking the charge the full time without disruption, etc…
GM’s inclusion of a Tesla charging adapter is also a big help for public charging availability and have similar prices as Electrify America.
Verdict: Getting Closer, But Not Quite There
2026 GMC Sierra EV AT4 Towing 5
It is getting closer to where electric trucks make sense for more people. (Photo by Tim Esterdahl)
The 2025 GMC Sierra 1500 EV AT4 proves an EV pickup can tow—and tow well. Smooth power delivery, quiet operation and reduced driver fatigue thanks to GM’s Super Cruise and the driving experience make for a relaxing towing experience. Range is the biggest limiter, but for shorter trips to the lake or a weekend campground within 100 miles, the Sierra EV handles the job.
At around $93,000, it’s still priced well above traditional trucks and long-haul towing remains tricky without more charging infrastructure. But this test shows the future is getting closer. For those willing to adapt, the Sierra EV delivers capability, savings at home and a glimpse at the ease of electric truck towing.
2,834 messages 4,724 likes
Many people hate on electric trucks for towing, but is it really that bad? I towed the 2026 GMC Sierra EV AT4 with a 30′ camper was shocked. The Sierra EV AT4 was part of my regular rotation of review vehicles and I connected it to our new 2024 Coleman 30′ double-axle camper with one slide out. It has a dry weight of around 5,300 pounds empty and 7,000 pounds loaded. I charged the Sierra EV up at home on my 220 volt outlet to 100%, normally you keep it charged at 80% as the truck tells you to do […] (read full article...)
Reply 3 likes
Avatar of Fightnfire
Fightnfire
Moderator
1,259 messages 2,162 likes
It is getting closer, you're absolutely right. For me it's still a hard no ... Only because of the range I need for my camping trips. I just got back from our annual family camping trip to the beach in SW WA. That's 220ish miles one way. The thought of having to charge before the destination is an absolute killer. My other yearly trip is up on Mt Baker, only 80 miles but a heck of a climb, not coming down until the way home.. The thing is I don't stay at the campground while I'm camping the whole time. We usually include a day out exploring the area. We're usually on site for 4-5 days so the break away is nice. To explore the mountains or the beach.
Also, a lot of the campgrounds in my area are hard no(s) for charging EVs from campground power. Some of them do have dedicated EV charging stations but they're large campgrounds and I wouldn't want to sit there while it charges.
Getting close though...real close.
Reply 5 likes
Avatar of TheDo114
TheDo114
Well-known member
778 messages 1,218 likes
I agree, getting better and better but still not there. Anything out of major highways or civilisation is still a major pain in the ass or impossible.
For someone towing short to medium distances and can charge at home. This looks perfect.
Reply 3 likes
Avatar of James-kd2cm
James-kd2cm
Well-known member
228 messages 414 likes
It would probably work for my needs. Shorter towing distances for my boat etc. I’ve only put on 13k miles in 2 years…
I have two(maybe 2.5) big stumbling blocks.
1. How long it would take to make back the extra cost of buying an EV and installing the charger through fuel savings.
2. What battery tech does it use and how susceptible is it to thermal runaway? I would be reluctant to park it in my garage due to the thermal runaway risk. This is a negative for wintertime in Canada (I prefer not to scrape the windshield). I know I could precondition the battery and warm the interior but I have no set schedule(retired).
I know some of these gripes are convenience gripes.
2.5-lol, an added gripe would be the cost of installing a charger at my cottage and the higher price of electricity at my cottage. 2/3rds of my electricity cost at the cottage is delivery because of the remote location.
Just some thoughts.
Reply 5 likes
Glad you guys are open minded to this story. I struggled with this headline, rewrote it at least a dozen times, and with even publishing it. Talking about EVs on a truck channel in any sort of positive light seems like suicide at times. The fact is they tow loads really well and I think most truck guys understand it. And once you get past all the politics and environmental noise, they are really cheap to operate. I think the gas savings is the thing the geeky outlets miss and that's the information truck guys want.
Reply 3 likes
James-kd2cm
Well-known member
There is a lot of noise against EV’s from people who think it was being forced on them.
I can see the practicality of them. Recently, I compared an RST spec Silverado EV with the long range battery pack(not max) with gas trucks in my area with money on the hood. I could get a new RAM sport for $30k Canadian dollars cheaper.
The RST long range was at $95k CAD and the discounted RAM sport ( slots between the big horn and the Laramie) was $65k CAD.
Just a specific example in my area.
Those would be the 2 trims I would be looking at rightly or wrongly.
Avatar of TheDo114
TheDo114
Well-known member
Next frontier for EV is being actually good offroad. None of the software has impressed me or come close to an actual transfer case with locking diffs.
D
Dusdaddy
Well-known member
1,387 messages 2,060 likes
My problem is the 500 mile drive I do. I leave this Thursday and will be pulling my 4K trailer. It's a long enough day of driving as it is so adding a multiple 45-60min charge stops is just not practical. I do two gas stops that combine with food for 15 mins. max. With no electricity at the destination, it's a big negative for me. The Ramcharger style would be different.
Reply 4 likes
Avatar of TheDo114
TheDo114
Well-known member
Same for me. Just did a 450 mile round-trip with 120 of those off-road and on top of that, half of those 450 miles were while pulling a small trailer. I would have added several hours to the trip and I'm not sure I could've made the off-road portion with an EV truck.
Picked up the stuff left by my grand-pa at the moose hunting camp.
I truly think if EVs are to ever take off automakers need to create programs were they loan people them for a few weeks to try them out. There's a lot of what ifs and probably's that people think right now about them. Not saying those aren't all true, just saying, I think once you live with it for a few weeks those obstacles aren't as big as they used to be.
Nice truck by the way.
Avatar of TheDo114
TheDo114
Well-known member
Thank you!
That would be a nice program for consumers, and I would love to try it but I fall into the 1 or 2 percent of people that it would not actually work for. Unless they really upgrade the charger network, battery chemistry and how fast it charges.
I need a minimum of 350-400 miles while towing and off-roading since recharging in the middle of the bush is practically impossible. Right now I can bring 4 x 5 gallons jugs of gasoline with me and be good to go on the fly.
I’m not oppose to EV, in fact, I’m buying an EV for my wife since she puts around town and pretty much all of them works for her even in winter.
I just need them to build one that fits my use case for when I need a truck the most.
