NHTSA begins GM 6.2L V-8 engine failure probe – 870k trucks
January 17, 2025
8 comments
GM 6.2L V-8 engine failures probe
The National Highway Traffic Safety Administration (NHTSA) said it is launching a probe into a GM 6.2L V-8 engine failure affecting 870,00 vehicles.
This probe covers certain 2019-2024 Chevy Silverado 1500, GMC Sierra 1500, Chevy Tahoe, Chevy Suburban, GMC Yukon and Cadillac Escalade vehicles equipped with the 6.2-liter V-8 engine aka L87.
According to a Reuters report, the NHTSA Office of Defects Investigation determined the scope and severity of the problem was high enough to take a closer look.
Federal Investigators believe a bearing failure could result in engine seizure or breading of the engine block by the connecting rod.
This failure would lead to a loss of power.
NHTSA states they have received 39 complaints and several early warning field reports from vehicle owners. These owners also said the loss of power was sudden and they had no warning signs before the engine failed.
There have been no crashes or fires reported.
GM says it will work with NHTSA during this probe.
2,848 messages 4,742 likes
The National Highway Traffic Safety Administration (NHTSA) said it is launching a probe into a GM 6.2L V-8 engine failure affecting 870,00 vehicles. GM 6.2L V-8 engine failure probe This probe covers certain 2019-2024 Chevy Silverado 1500, GMC Sierra 1500, Chevy Tahoe, Chevy Suburban, GMC Yukon and Cadillac Escalade vehicles equipped with the 6.2-liter V-8 engine aka L87. According to a Reuters report, the NHTSA Office of Defects Investigation determined the scope and severity of the problem was high enough to take a closer look. Federal Investigators believe a bearing failure could result in engine seizure or breading of the […] (read full article...)
Avatar of Hilux
Hilux
Well-known member
472 messages 783 likes
Can we just be honest here? Wouldn't it be better to just build these vehicles right in the first place?
S
Saddle Tramp
Moderator
1,109 messages 1,228 likes
Is it a building problem or supplier problem?
Reply Like
I think statistically you are just going to have some failures and things happen.
For example, I just returned a Dyson vacuum to Sam's Club. It worked once and then just died. We had one for 14 years and beat the crap out of it before it finally died. The new one dying doesn't change my opinion of Dyson as a brand. I just chalk it up to things happening.
Now, obviously, a vacuum cleaner is much smaller potatoes than a truck.
Reply 3 likes
D
Dusdaddy
Well-known member
1,387 messages 2,060 likes
Always tough when you get these reports. The "870K affected" sounds so bad, but when only 39 complaints have come in, that kinda puts it perspective. I wonder what failure percentage point GM determines it is not random, but a problem that needs to be addressed?
I suppose the "doom & gloom" YT channels will be posting all sorts of "GM is dead on the vine" videos over it. Hell, the Tundra got one complaint on a 2025 and that created weeks of content. Honestly, that'll be the best outcome for GM if this turns into a real issue. That the finding is something similar to Toyotas and doesn't create a redesign in addition to a recall.
Reply 3 likes
Avatar of Fightnfire
Fightnfire
Moderator
1,259 messages 2,162 likes
I'm hoping they find something and issue a recall, that's a good step to rectifying the "lifter" issue fears that have been plaguing GM for several years. I'm at 54k now with no issues, knock on wood. It will be curious to see what happens...oddly the 5.3 has significantly more issues from what ive heard but they also sell a lot more of them so who knows.
Reply 4 likes
Avatar of stevemax07
stevemax07
New member
8 messages 20 likes
Lots of lifter and cam wear issues going around for the cylinder deactivation engines. GM, Honda, and Ram all have issues that result in premature cam wear or lifter failure.
This is a technology that needs to go away until made reliable.
Reply Like
What about Ford? They have it as well.
Reply 3 likes
D
Dusdaddy
Well-known member
Except, in the Ram Hemi's case, lifter failure occurs in the engine model without MDS as well as the model with it.
Reply 3 likes
