Ford Trucks, SUVs recall: 91K for “catastrophic engine failure”
September 5, 2024
Ford recall
More than 91k Ford trucks, SUVs are being recalled due to catastrophic engine failure. (Photo courtesy Ford Motor Company)
Ford has issued a recall for 90,736 trucks and SUVs due to a potential issue with engine intake valves that may crack and lead to engine failure, according to documents from the National Highway Traffic Safety Administration (NHTSA). The company states that a fractured intake valve can result in a loss of power, and in most cases, a full engine replacement is required.
Ford reports that there have been no known injuries or accidents related to this issue. However, vehicles covered by the recall will need to be inspected to identify any possible problems. The recall affects 2021-22 model year trucks and SUVs equipped with 2.7L or 3.0L EcoBoost engines, including the following models:
  • Ford Bronco
  • Ford Edge
  • Ford Explorer
  • Ford F-150
  • Lincoln Aviator
  • Lincoln Nautilus
A Ford spokesperson told MLive.com, “Our goal is to prevent quality issues from happening in the first place. When they do occur, our focus is on responding quickly with a recall or service action to prevent our customers from experiencing issues with the least inconvenience possible.”
Ford dealerships will conduct an engine cycle test and replace engines if necessary, at no cost to the vehicle owners. Affected owners will be notified by mail starting October 7, 2024. For more information, Ford customer service can be reached at 1-866-436-7332, or owners may contact the NHTSA at 1-888-327-4236. NHTSA ID: 24V635000.
Ford recall chronology report
In the related documents section of the recall on NHTSA.gov, Ford engineers said they first discovered the issue in 2022.
On January 25, 2022, Global CCRG opened an investigation into 2021 Model Year (MY) Lincoln Aviator and Nautilus vehicles equipped with 2.7L and 3.0L Nano EcoBoost gasoline engines after an international investigation discovered twenty-two (22) instances of engine failure at three (3) months in service or less. A review of failed engines revealed that the engine intake valves fractured and fell into the combustion chamber of the engine causing catastrophic engine damage leading to a Loss of Motive Power (LOMP). Based on an analysis of returned fractured valves from failed engines, Ford identified that the potential root cause of the failures was engine intake valve failure due to valves that exceeded the designed specification for hardness, were brittle, and more likely to fracture. Ford determined that this was due to the supplier’s grinding processes and the sensitivity of the intake valve material to grinding processes that were not within control specifications. The intake valve material was changed for vehicles produced after October 31, 2021. The new material increased the valve’s robustness to keeper groove grinding processes outside of control specifications.
On May 05, 2022, Ford’s North America (NA) CCRG opened an investigation regarding early time in-service left-hand engine intake valve fractures on 2021MY Ford and Lincoln vehicles equipped with 2.7L and 3.0L Nano EcoBoost gasoline engines. Teardown analysis of returned failed engines confirmed intake valve fracture on two-hundred fifty-one (251) engines from warranty repairs.
On May 27, 2022, the National Highway Traffic Safety Administration (NHTSA) opened Defect Petition 22-001 in response to an increasing trend of Vehicle Owner Questionnaires (VOQs) submitted by 2021MY Ford Bronco customers alleging LOMP as a result of catastrophic engine damage.
On July 22, 2022, NHTSA opened Preliminary Evaluation (PE) 22-007 to continue their investigation into 2021MY Ford Bronco customer allegations of LOMP. Ford’s response was provided to NHTSA on September 28, 2022.
On September 29, 2023, NHTSA opened Engineering Analysis (EA) 23-002 and expanded the scope of their investigation to include all 2021 and 2022MY Ford/Lincoln products that are equipped with the 2.7L and 3.0L Nano EcoBoost engines. Ford’s response was provided to NHTSA on January 02, 2024. Ford noted that there was a higher than ambient level of repairs observed for vehicles produced between May 1 and October 31, 2021.
On December 4, 2023, NHTSA personnel visited Ford facilities to observe Ford’s engine teardown and laboratory analysis processes for evaluating fractured intake valves. Between February and August 2024, Ford has participated in several discussions related to fractured intake valves on Nano EcoBoost engines with NHTSA.
As of August 09, 2024, Ford is aware of 811 global warranty claims confirmed or suspected to be related to fractured intake valves with report dates ranging from February 13, 2021 to June 03, 2024. Ford is aware of 267 field reports with report dates of October 06, 2020 to October 18, 2023. Ford is aware of 223 customer reports with report dates of March 31, 2021 to August 29, 2023.
On August 16, 2024, Ford’s Field Review Committee reviewed the concern and approved a field action.
Recalls happen, but a full engine replacement is a big one. We will never know the true cost of the engine replacement, however, we do know the retail cost of new engines is over $30,000 like with the 3.5L V6 from Toyota.
