While Lincoln used to be known primarily for luxury sedans. However, in 1998, the Navigator arrived in dealerships, and today, its entire lineup is now entirely made up of SUVs. The 2023 Lincoln Corsair is the smallest and least expensive, followed by the Nautilus, Aviator and Navigator. The Corsair started at just $38,690 for the 2023 model year base trim (just called the Standard). From there, the mid-range Reserve came in at just more than $43,000, and the Grand Touring, like our tester, kicked off at $53,885.
It’s a plug-in hybrid electric vehicle (PHEV) finished in “Pristine White” ($750) with the ebony/cashew interior and the “Collection III” package, which adds another $8,000. That basically means it’s got, well, everything with regard to features and options. All in, you’re looking at around $62,000 out-the-door for this top-spec Corsair. Let’s run through five good and five bad things about it, and see if it gets the nod as a recommended buy in the compact luxury crossover market.
5 good things about the 2023 Lincoln Corsair Grand Touring III
OMG it’s got massaging seats! I’ll admit that, even though I’ve entered the second half of my 40s in relatively decent shape, I absolutely adore massaging seats. I appreciated how easy it is to get into the massage controls, you just push the button for the seat massage next to the seat memory buttons on the door. Then a menu pops up on the nicely sized 13.2-inch touchscreen, and you can select your setting. When you’re done, you can press it again and it goes away.
I also liked how the front seats have a bifurcated front section so you can dial in more support for one leg versus the other. I didn’t use it all that much, but it could be helpful for a long road trip. The interior overall is full of nice details and solid materials that mostly feel at home in an SUV that costs more than 60 grand. Add in the fact that even the base model is very well-equipped and you’ve got a pretty solid compact luxury option already.
Finally, it’s incredibly quiet. Even when the gas engine is going, you sort of coast down the road in impressive silence. Once you are in all-electric mode it’s dead quiet, which as was the case in the Lightning EV, is good and bad. Stay tuned.
5 bad things about the 2023 Lincoln Corsair Grand Touring III
The piano black interior trim tend has to die a quick and painful death. Like a lot of other press loaners I’ve tested in the past couple of years, it shows absolutely every bit of dirt, dust and fingerprint. They deliver these vehicles pretty clean, so the pics below give you some sense of what things looked like in less than a week of use.
As I alluded to above, the Corsair is incredibly quiet. In fact, it was so quiet in electric mode is that you can hear the seat massaging motors quite prominently. As relaxing as the massaging seats are, hearing the motors churning away just behind (and below) you wasn’t an amazing experience.
- The start-stop button is sort of hidden up under the vents.
- There are six buttons behind the steering wheel, I had no clue what they do.
- The drive button is actually pretty far away, and I have long arms.
- The area for the wireless charger has a cover, which is great. However anything you put on that hard plastic surface would most definitely slide around.
- I found myself accidentally pressing the voice activation button very often, which is located around 10 o’clock on the steering wheel.
