Toyota Tundra recall: 168k trucks recalled for fuel leak
Toyota Tundra Recall
Toyota Motor Engineering & Manufacturing (Toyota) is recalling certain 2022-2023 Tundra and Tundra Hybrid vehicles. For this Toyota Tundra recall, the plastic fuel tube routed near metallic brake lines may chafe against the brake lines and become damaged, possibly resulting in a fuel leak.
A fuel leak in the presence of an ignition source can increase the risk of a fire.
As an interim repair, dealers will install protective materials and a clamp on the fuel tube, free of charge. Once the final remedy is available, dealers will replace the fuel tube, free of charge. Owner notification letters are expected to be mailed September 25, 2023. Owners may contact Toyota’s customer service at 1-800-331-4331. Toyota’s numbers for this recall are 23TB09/23TA09.
We have previously reported on the 2022 Tundra being recalled for loose axle nuts and a tonneau cover detachment. The 2022 Tundra currently has seven recalls, and the 2023 Tundra has five recalls. If you own a 2022-2023 Toyota Tundra, be sure to consult the NHTSA recalls portion of the website and type in the specific VIN of your SUV to see if this current recall applies to your vehicle.
NHTSA Campaign Number: 23V566000
Manufacturer Toyota Motor Engineering & Manufacturing
Components FUEL SYSTEM, GASOLINE
Potential Number of Units Affected 168,179
Editor’s note: This information was copied directly from the NHTSA website. If you have questions or concerns about this Toyota Tundra recall, please contact Toyota Motor Corporation North America directly.
