A guide to maintaining your Ford truck
2024 Ford F-150 preproduction model shown. Available early 2024. Actual production vehicle may vary. Closed course. Professional Driver. Do not attempt unless you have special off-road driving training and are driving on a closed course. Always consult the Owner’s Manual before off-road driving, know your terrain and trail difficulty, and use appropriate safety gear. Ford is committed to the preservation of the environment and treading lightly.
Ford trucks have been a staple in the American automotive industry for almost a century. Since the release of the first Ford pickup truck in 1925, the company has continued to innovate and improve its vehicles to meet the ever-changing needs of its customers. From the Ford F-150 pickup, which has been the best-selling truck in America for more than four decades, to the heavy-duty F-450, which can tow up to 37,000 pounds, this Michigan-based manufacturer offers a range of trucks to suit any job or lifestyle.
But whereas Ford trucks are known for their durability, performance, and versatility, they do come with their own inherent flaws. After all, there is no such thing as a “perfect pickup.”
Therefore, owners should be diligent about maintenance in order to keep their Ford truck in good condition. Here are five key maintenance tips to keep that Ford pickup on the road and out of the repair shop.
5 Ford truck care tips to follow
1. Retain a routine maintenance schedule: This not only includes regular oil changes and air filter replacements, but tire rotations and brake inspections as well. Following the recommended maintenance schedule in your owner’s manual can help prevent serious problems from forming down the line.
2. Check those fluid levels: Regularly checking your fluid levels, including oil, coolant, transmission fluid, and brake fluid is crucial to keeping a Ford truck in good condition. Make sure to top off any fluids that are low and address any leaks or other obvious issues promptly.
3. Keep your truck clean: Pressure washing your Ford truck, including its undercarriage, can help prevent rust and corrosion from forming. Ceramic coating your truck can also help protect the paint and clear coat from fading, and can even protect against light surface scratches.
4. Always use quality parts: When replacing parts on your Ford truck, make sure to use high-quality, OEM (original equipment manufacturer) parts. These parts are designed specifically for your truck and can help prevent future problems.
5. Address issues promptly: If you notice any problems with your Ford truck, have them addressed promptly. Ignoring issues can lead to safety concerns, and more costly repairs down the line.
A few Ford focused suggestions
Be sure to stick to a regular maintenance schedule with your Ford pickup truck, and review any necessary tasks with an ASE certified mechanic. This will ensure that any potential problems are caught and corrected before they become major issues. During regular service appointments, your mechanic will also check other key components of your Ford truck, such as the suspension, steering, engine, transmission, and electrical system.
It is also important to keep a record of all maintenance and repair work completed on your Ford, including the dates, mileage, and the type of work that was performed.
While properly maintaining a Ford truck requires regular attention and care, owners can extend the lifespans of their trucks by staying on top of routine maintenance tasks and addressing issues as soon as they arise. It’s crucial to keep an eye out for any symptoms your vehicle presents, as you want to ensure you get any problems taken care of as soon as possible to prevent further damage.
Common issues Ford owners experience
Regarding what you should watch out for as a Ford truck owner, the following four concerns remain the most prominent. So bear these in mind every time you drive, and have them amended immediately if they surface.
  • Engine issues: Many Ford truck drivers note tapping, knocking, or rattling sounds when experiencing engine trouble in their vehicles. Additionally, engine issues may present in the form of stalling, excessive oil consumption, overheating, misfires, or fluid leaks.
  • Transmission problems: Ford owners have long reported transmission problems in their vehicles, specifically jerking, slipping, rough shifting, delayed acceleration, abnormal noises, lack of acceleration, and even transmission failure. Regular transmission maintenance, including fluid changes and filter replacements, can help prevent these issues. If you do experience transmission problems, it’s important to have them addressed promptly by a qualified mechanic.
  • Electrical malfunctions: Electrical issues are also common in Ford trucks, including problems with the battery, alternator, infotainment system, headlights, back-up camera, and more. While some of these issues seem rather obvious, others are more covert, such as cable or wiring defects inside the vehicle. Either way, it’s crucial to pay attention–as some electrical issues can lead to increased risk of fire and are covered via a Ford recall.
  • Suspension and steering issues: For certain Ford drivers who have experienced the feared “Ford Death Wobble” in their trucks, the threat of this affliction is fear-inducingly real. Since the early 2000s, Ford truck owners have encountered an issue that can be best described as intense shuddering and shaking when driving at highway speeds or after hitting a bump on the road. As a result, the steering wheel may also rattle excessively, making it difficult to control the truck. This Death Wobble defect can also cause premature wear of other suspension components in your vehicle, such as the ball joints, shocks, control arms, track bar bashing, or damper brackets.
Some final thoughts on Ford trucks
By following these maintenance steps and keeping an eye out for any potential issues, you can greatly increase the longevity and reliability of your Ford truck.
So always remember to schedule regular check-ups with a qualified mechanic, stay up to date with recalls and technical service bulletins, and address any concerns as soon as they arise. Together, with consistent care and attention, your Ford pickup truck can continue to provide you with reliable transportation and enjoyable driving experiences for many miles down the road.
