BOLT Lock 2023 Ford F-150 Lightning EV pickup’s one-key solution
The 2023 Ford F-150 Lightning EV certainly made a stir when it was first announced all those months back. Love it, hate it, or write it off as foolhardy, there is no ignoring the fact the future of pickup truck power is becoming increasingly electronic and automatic in nature.
But having a brilliant, fully electrified Ford F-150 does not mean that it will deter thieves and vandals. Lightning F-150 pickups are still work trucks at the end of the day, for what’s the point in having a bed and towing capacity if you don’t use it? This leads us back to the topic of thieving miscreants and that form of ilk, for they are the type that is forever quick to pilfer unsecured belongings from the back of a pickup.
The brainiacs behind the patented BOLT Lock system understand this better than anyone. Security specialists tend to go to great lengths to make their locks a royal pain to disengage, and BOLT’s “Breakthrough One-Key Lock Technology” for the 2023 Ford F-150 Lightning EV pickup is about as good as it gets.
Oh, you didn’t know that the all-caps BOLT name was an acronym for “Breakthrough One-Key Lock Technology?”
Well, get ready to be astonished all over again, because BOLT Locks truly has some of the slickest security options imaginable for this futuristic Ford truck.
New electric suit and a clever hat trick
Much like other platforms, which have a physical key bob for inserting into the Wisconsin-based brand’s patented “one-turn tumbler,” the new BOLT Lock product line for the electric F-150 Lightning comes primed to be permanently programmed to the truck’s ignition key. Thus far, BOLT Lock has made the following products compatible with this tech-loaded Ford F-150 Lightning: 5/8” receiver lock, coupler pin lock, padlock, cable lock, trailer coupler lock, and locking recovery hook.
“While this is not our first EV-compatible application, it does mark the first electric pickup model we support. Our aftermarket products offer the convenience, security, and peace of mind active truck owners require to lock up their valuable gear,” —Jason Buckles, BOLT Lock
Upon inserting and twisting the truck’s ignition key into the lock cylinder for the first time, BOLT technology gets to work permanently programming itself. As the key is turned, a series of spring-loaded tumbler plates move up and down until they precisely match the pattern of the key in question. After returning the key to its original position and removing it from the lock, the tumbler locks these plates into place for all of eternity. That way the cylinder of the locking barrel becomes coded to that key, and that key alone.
2022 F-150 Lightning
The 2022 F-150 Lightning has a max tow rating of 10,000 pounds when equipped with the extended-range battery and the optional tow package. (Photo by Jill Ciminillo)
Variety is the lock of life
As far as a brief product rundown goes, you can find some quick specs on the following Ford F-150 Lightning products from BOLT Locks. All of these are guaranteed to work without any need for modification.
  • 5/8” Receiver Lock: BOLT Lock’s receiver is constructed to fit both 2.5-inch and 3-inch square receivers, and is a fantastic way to safely secure a receiver to a trailer hitch. Relying upon its own signature stainless steel Coupler Pin Lock, BOLT has made it possible to fit couplers ranging anywhere from ½-inch to 3/8-inch, with adjusts in 1/8-inch torque increments providing unparalleled grip. When utilized in conjunction with BOLT Locks’ receiver lock, trailer theft becomes near impossible.
  • BOLT Padlocks: Intended to be used on toolboxes, trailer doors, and overlanding gear containers.
  • Cable Lock: This black vinyl-coated coiled 6-foot-long lock rocks a slender ¼-inch circumference, which makes it quite flexible. An ideal upgrade for those looking to secure things like fishing gear, kayaks, bikes, tents, and overlanding external upgrades to their Ford Lightning F150 pickup truck.
  • Trailer Coupler Lock: Protection for that unaffixed trailers is just as important as when it is attached to the back of your Lightning F-150. BOLT’s robust trailer coupler lock is made of hardened steel that’s been powder coated red and is proven to work with 1 7/8-inch, 2-inch, and 2 5/16-inch couplers.
  • Locking Recovery Hook: Constructed from aircraft-grade aluminum, and rated up to 10,000 pounds, this hulking recovery/tow hook from BOLT Locks is designed to swivel 160 degrees. Formed to fit the standard 7/8-inch bumper tabs on the front of the F-150 Lightning, this hook allows the secure deployment and recovery of winch-related gear and recovery ropes when things get messy off-road.
Much like its other offerings, every one of the BOLT Locks products listed above comes with a limited lifetime warranty and comes reinforced by a series of impact, pry, and pick-resistant features.
