Mazda CX-5 vs. CX-50: A spec-by-spec comparison
August 24, 2022
mazda cx-50 vs. cx-50
When I first saw the Mazda CX-50 in photos, we couldn’t understand why this vehicle was necessary. It looked so much like the CX-5. But after looking at them in person, and reviewing the specs, we can see the differences more clearly. Kinda. If you’re trying to choose between these two compact SUVs, you might make your decision on purely cosmetic reasons, but it might also be helpful to see a Mazda CX-5 vs. CX-50 spec-by-spec comparison as well.
So, we’re including the full chart below as well as a few key takeaways.
Size differences
When looking at the sizes of the Mazda CX-5 vs. CX-50, if you don’t seem them side by side, they look quite similar. But the CX-5 has less length, though it is a little wider and taller than the CX-50. CX-50 also generally weighs more than the CX-5.
The end result is CX-5 has more passenger volume but CX-50 has more cargo volume.
Identical powertrains, but …
Both vehicles come standard with all-wheel drive and a base 2.5-liter engine with an available 2.5-liter turbo. Power delivery is also identical. Note, on the turbo engines, power delivery is affected by whether you use regular or premium fuel.
However, even though the powertrains are the same, fuel economy is not. CX-50 is slightly more efficient than the CX-5, which seems odd since CX-50 is heavier.
Off-road clearances
Because CX-50 is intended to be a little more capable off-road and bears extra cladding, it gets some extra ground clearance. Mazda also spells out approach, departure and breakover angles for the CX-50, whereas nothing is provided for CX-5.
Towability
While few people are going to tow with a compact SUV, we suppose it could happen. So, if you were bringing along a small camper or boat, you’ll get more capacity with the CX-50 paired with the turbocharged engine. You’re looking at 2,000 pounds max for the CX-5 but 3,500 for the CX-50.
CX-50 CX-5
Engine Type Skyactiv-G 2.5 4-cylinder (std); Skyactiv-G 2.5 with Twin Scroll Turbocharger (available) Skyactiv-G 2.5 4-cylinder (std); Skyactiv-G 2.5 with Twin Scroll Turbocharger (available)
Horsepower 187 hp @ 6,000 rpm (2.5); 227 hp @ 5,000 rpm (2.5T, regular fuel), 256 hp @ 5,000 rpm (2.5T, premium fuel) 187 hp @ 6,000 rpm (2.5); 227 hp @ 5,000 rpm (2.5T, regular fuel), 256 hp @ 5,000 rpm (2.5T, premium fuel)
Torque 186 lb-ft @ 4,000 (2.5) 310 lb-ft @ 2,000 rpm (2.5T regular fuel), 320 lb-ft @ 2,500 rpm (2.5T premium fuel) 186 lb-ft @ 4,000 (2.5) 310 lb-ft @ 2,000 rpm (2.5T regular fuel), 320 lb-ft @ 2,500 rpm (2.5T premium fuel)
Top speed (mph) 127 (std); 142 (available) 128 (std); 129 (available)
MPG City/Highway/Combined 24/30/27 (std); 23/29/25 (available) 24/30/26 (std); 22/27 /24 (available)
Drivetrain AWD AWD
Transmission SKYACTIV-Drive 6-speed automatic transmission SKYACTIV-Drive 6-speed automatic transmission
Front Suspension Macpherson strut Independent, MacPherson Strut type coil spring and stabilizer bar
Rear Suspension Torsion Beam Independent, Multi-link type coil spring and stabilizer bar
Steering Type Rack and Pinion Rack and Pinion
Turning Circle, Curb to Curb (diameter – feet) 18 18
Turning Circle, Wall to Wall (diameter – feet) 39 39
Wheel Size 17 X 7J (std); 20 X 8J (available) 17 X 7J (std); 19 X 7J (available)
Tire Size 225 / 65 / R17 (std); 245 / 45R20 (available) 225 / 65 / R17 (std); 225 / 55 / R19 (available)
Wheelbase (in) 110.8 106.2
Overall Length (in) 185.8 180.1
Overall Width mirror to mirror (in) 80.8 83.3
Overall Height (in) 63.5 (std); 63.9 (available) 65.4 (std); 65.6 (available)
Overhang front/rear (in) 37.8 / 37.2 38.0 / 35.8
Minimum Ground clearance (in) 8.3 (std); 8.6 (available) 7.6 (std); 7.9 (available)
Approach Angle (degrees) 18 n/a
Departure Angle (degrees) 24 (std); 25 (available) n/a
Breakover Angle (degrees) 18.4 n/a
Headroom front/rear (in) 39.1/38.6 (std.); 38.6/37.5 (available) 39.7/39.0 (w/o moonroof), 39.3/39.0 (w/ moonroof)
Leg Room front/rear (in) 41.7/39.8 41.0/39.6
Rear knee clearance (in) 3 2.7
Shoulder Room front/rear (in) 55.9/53.6 57.1/54.8
Hip Room front/rear (in) 53.6/52.1 55.2/55.3
Passenger Volume (cu ft) 100.3 (std); 98.3 (available) 103.6
Cargo Volume behind second row/second row flat (cu ft) 31.4/56.3 30.8/59.3
Curb Weight (lbs) 3,706 (std); 3,907 (available) 3,717 (std); 3,856 (available)
Gross Vehicle Weight Rating (lbs) 4,848 (std); 4,945 (available) 4,724 (std); 4,828 (available)
Fuel Tank Capacity (gallons/L) 15.8 / 60 15.3 / 58
Towing Capacity (lbs) 2,000 (std); 3,500 (available) 2000
The bottom line on the Mazda CX-5 vs. CX-50
At the CX-50’s introduction, Mazda made a big deal out of it being more rugged, while the CX-5 is more urbane. And sure, there’s more cladding as well as an extra half inch of ground clearance. But I’m not sure that’s enough of an aesthetic difference to really differentiate the two SUVs.
One other difference to note is pricing: The CX-5 costs about $800 less than the CX-50. Then again, not sure if that’s enough of a difference to matter.
But in terms of design and capability, the CX-50 is the clear winner. Frankly, we’d be surprised if CX-5 sticks around much longer.
