2021 Jeep Wrangler adds TrailCam, full-time 4WD updates and more
August 31, 2020
2021 Jeep Wrangler Sahara EcoDiesel (Image courtesy of Fiat Chrysler Automobiles)
The Jeep Wrangler is now heading in to the fourth year of the JL generation. But, similar to its Gladiator sibling, what’s new for 2021 is more of a tweak than anything major. So, here’s quick look at the changes and additions:
TrailCam added to Wrangler
This is probably the coolest add for 2021. The TrailCam is a front-facing off-road camera that gives you a really good view of what’s immediately in front of you. It’s available with the 8.4-inch touchscreen and can be found in the off-road pages.
The front-facing TrailCam as it appears in the 2020 Jeep Gladiator. (Photo by Jill Ciminillo)
We’ve had the opportunity to test this in the Gladiator, and it’s incredibly helpful when traversing rocky trails. We definitely avoided more than one sharp rock using it!
Updated powertrain menu
The powertrain menu gets a small tweak for 2021 in the Sport, Sahara and Rubicon models. These engine/transmission combos will be available across all three trims.
  • 2.0-liter turbo engine (AT only)
  • 3.6-liter V-6 engine (MT only)
  • 3.6-liter V-6 with mild-hybrid eTorque assist (AT only)
  • 3.0-liter EcoDiesel (four-door models only – not a change, but worth noting AT only)
Previously the eTorque assist was only available on the Sahara trim.
2021 Jeep Wrangler Sahara.(Image courtesy of Fiat Chrysler Automobiles)
Full-time 4WD updates
The most important 4WD update is the fact the Selec-Trac two-speed transfer case with full-time 4WD is now available on all models. Only Sahara had this for 2020. This makes the low-range gear ratio 2.72:1.
Additionally, a Rock-Trac 4X4 system with full-time 4WD and a 4LO ratio of 4:1 is now optional on Rubicon models.
2021 Jeep Wrangler Rubicon (Image courtesy of Fiat Chrysler Automobiles)
80th Anniversary, Islander editions added
At this point Jeep has announced but not revealed there will be Wrangler 80th Anniversary and Islander editions, but since the reveal hasn’t happened just yet, details are scant and no photos are available. But here’s what we do know
The 80th Anniversary Edition will feature optional leather seats, Granite Crystal interior accents, a three-piece black hard top, 18-inch wheels with a Granite Crystal finish and commemorative exterior badging.
The Islander Edition adds unique beach-themed exterior and interior accents — including a “Jeep Tiki” decal on the hood – black side steps and 17-inch wheels with 32-inch tires. A white hard top will be optional.
Jeep assures us more details on these two models should be coming within the next month.
And some other new stuff
We’ve called attention to the biggest changes for 2021, but there are a few other updates to note. First and foremost, we appreciate the two additional charge-only USB ports. Jeep didn’t say where these are located, but we’ll assume back seat.
The Select Tire Fill Alert is now standard with both 7- and 8.4-inch touchscreens and is included with the Technology Group. The final new thing of note is Off-Road Plus is now standard on Rubicon models.
Key specs
General Information
Vehicle Type Sport-utility vehicle
Assembly Plant Toledo Supplier Park, Toledo, Ohio
EPA Vehicle Class Multipurpose vehicle
BODY/CHASSIS
Layout Longitudinal front engine, four-wheel drive
Construction Ladder-type frame, open steel and aluminum body
Engine: 3.6-LITER PENTASTAR V-6
Power (SAE net) 285 hp at 6,400 rpm
Torque (SAE net) 260 lb.-ft. at 4,800 rpm
Max. Engine Speed (rpm) 6,600 rpm (electronically limited)
Fuel Requirement Unleaded regular, 87 octane (R + M)/2
Fuel Tank Capacity (gallons) 17.5 (2-door), 21.5 (4-door)
Max. Gross Trailer Weight 2,000 lbs. (2-door), 3,500 lbs. (4-door)
EPA Fuel Economy mpg (city/hwy/combined) 17/25/20 — manual with ESS (2-door)
17/23/19 — manual with ESS (4-door)
18/23/20 — automatic with eTorque mild-hybrid assist (2-door)
19/22/20 — automatic with eTorque mild-hybrid assist (4-door)
Assembly Plant Saltillo South Engine Plant, Saltillo, Coahuila, Mexico
Engine: 2.0-LITER TURBO I-4
Power (SAE net) 270 hp at 5,250 rpm
Torque (SAE net) 295 lb.-ft. at 3,000 rpm
Max. Engine Speed (rpm) 5,800 rpm (electronically limited)
Fuel Requirement Minimum unleaded regular, 87 octane (R + M)/2; 91 octane or higher
recommended for optimum fuel economy and performance
EPA Fuel Economy mpg (city/hwy/combined) 22/24/23 — automatic with ESS (2-door)
21/22/21 — automatic with ESS (4-door)
Assembly Plant Termoli, Italy and Trenton South Engine Plant, Trenton, Michigan
ENGINE: 3.0-LITER ECODIESEL V-6
Power 260 hp @ 3,600 rpm
Torque 442 lb.-ft. @ 1,400-2,800 rpm
Max. Engine Speed 4,600 rpm
Fuel Requirement Ultra-low sulfur diesel
Fuel Tank Capacity (gallons) 18.3 (4-door)
Max. Gross Trailer Weight 3,500 lbs. (4-door)
EPA Fuel Economy mpg (city/hwy) 22/29/25 — automatic with ESS (4-door only)
Assembly Plant Cento, Italy
Transmission: 850RE automatic, Eight-speed overdrive
Availability Standard — 2.0-liter I-4 ESS
Optional — 3.6-liter V-6 with eTorque mild-hybrid assist
Description Adaptive electronic control or Electronic Range Select (ERS) driver-interactive manual control and electronically modulated torque converter clutch
Gear Ratios
1st 4.71
2nd 3.13
3rd 2.1
4th 1.67
5th 1.28
6th 1
7th 0.84
8th 0.67
Reverse 3.3
Transmission: 8HP75 AUTOMATIC, EIGHT-SPEED OVERDRIVE
Availability Standard — 3.0-liter EcoDiesel V-6 ESS
Description Adaptive electronic control or ERS driver-interactive manual control and electronically modulated torque converter clutch
Gear Ratios
1st 4.71
2nd 3.13
3rd 2.1
4th 1.67
5th 1.28
6th 1
7th 0.84
8th 0.67
Reverse 3.3
TRANSMISSION: D478 MANUAL, SIX-SPEED WITH OVERDRIVE
Availability Standard — 3.6-liter V-6 with eTorque mild-hybrid assist
Description Synchronized in all forward gears and Reverse, multi-rail shift system with top-mounted shift lever
Gear Ratios
1st 5.13
2nd 2.63
3rd 1.53
4th 1
5th 0.81
6th 0.72
Reverse 4.49
Final Drive Ratio 3.45 standard, 3.73 optional (4.10 Rubicon)
TRANSFER CASE: NV241 command-trac
Available Standard — Sport and Sahara
Type Part-time
Operating Modes 2WD High; 4WD High; Neutral; 4WD Low
Low Range Ratio 2.72:1
TRANSFER CASE: MP3022 Selec-Trac
Available Optional — Sport and Sahara
Type Full-time
Operating Modes 2WD High; Auto; 4WD High; Neutral; 4WD Low
Low Range Ratio 4.0:1
Axle Ratio 3.45 standard
4.10 standard Rubicon with manual (optional for automatic)
TRANSFER CASE: NV241OR Rock-trac
Available Standard — Rubicon
Type Standard – Part-time
Available – Full-time
Axles
Front 3rd generation Dana axles
Differential type Open or Tru-Lok electronic locking (on Rubicon models)
Axle ratios 3.45, 3.73 (EcoDiesel), 4.10
Rear 3rd generation Dana axles
Differential type Open (Sport and Sahara) with available Trac-Lok anti-spin,
Tru-Lok electronic locking (Rubicon)
Suspension
Front Solid axle, link coil, leading arms, track bar, coil springs, stabilizer bar
Stabilizer bar Electronic sway-bar disconnect system — standard, Rubicon
Shock type Sport: Gas-charged twin-tube shock absorbers with full displacement
Multi-tuned Valve (MTV) technology
Sahara: High-pressure gas-charged monotube shock absorbers with MTV technology
Rubicon: High-pressure gas-charged monotube shock absorbers with MTV technology
and hydraulic rebound stop
Rear Solid axle, link coil, trailing arms, track bar, coil springs, stabilizer bar
Shock type Sport: Gas-charged twin-tube shock absorbers with full displacement MTV technology
STEERING
Type Electro-hydraulic power
Overall ratio 17.4:1 (2-door), 15.6:1 (4-door), 14.3:1 (EcoDiesel)
Turning diameter 34.5 (2-door), 39.4 (4-door)
(curb-to-curb) (ft./m)
Steering Turns (lock-to-lock) 3.6 (2-door), 3.2 (4-door), 3.13 (EcoDiesel)
P/S Pump Electro-hydraulic
BRAKES
Type Power-assisted, anti-lock brake system
Front
Rotor size and type 12.9 x .94 (330 x 24) vented rotor — Sport
12.9 x 1.1 (330 x 28) vented rotor — Sahara and Rubicon
Caliper size and type 1.88 (48) twin-piston floating caliper — Sport
2 (51) twin-piston floating caliper — Sahara and Rubicon
Rear
Rotor size and type 12.9 x .47 (328 x 12) solid rotor — Sport
13.4 x .55 (342 x 14) solid rotor — Sahara and Rubicon
Caliper size and type 1.77 (45) single-piston floating caliper — Sport
1.88 (48) single-piston floating caliper — Sahara and Rubicon
Dimensions and Capacities
Wheelbase 96.8 — 2-door, 118.4 — 4-door
Overhang — Front 29.2
Overhang — Rear 40.8
Track — Front 62.9
Track — Rear 62.9
Overall Length 166.8 — 2-door, 188.4 — 4-door
Overall Width 73.8
Overall Height 73.6
Liftover Height 29.7
Cargo Width at Swing-Gate Opening 41.1
Cargo Height at Swing-Gate Opening 36
Load Floor Height 30
CLEARANCES
Standard on Sport Standard on Sahara Standard on Rubicon
Approach Angle (degrees) 41.4 41.8 44 (2-door)
43.9 (4-door)
Breakover Angle (degrees) 25 (2-door) 21 27.8 (2-door)
20.3 (4-door) 22.6 (4-door)
Departure Angle (degrees) 35.9 (2-door) 36.1 37
36.1 (4-door)
Ground Clearance (inches) 9.7 10 10.8
*measurements the same for both 2- and 4-door models unless specified
Accommodations
Seating Capacity 4 (2-door), 5 (4-door)
Front
Headroom 40.7 hardtop, 42.6 soft top
Legroom 41.2
Shoulder room 55.7
Hip room 53.9
Seat travel 8.1
Rear
Headroom 40.2 hardtop, 41.7 soft top
Legroom 35.7 — 2-door, 38.3 — 4-door
Knee clearance 61.6
Shoulder room 57.7 — 2-door, 55.7 — 4-door
Hip room 45 — 2-door, 56.7 — 4-door
Liftover height 29.7
Rear seat folded 72.4 cu. ft.
Rear seat upright 31.7 cu. ft.
Total passenger plus cargo volume, (cu. ft. / cu. m) 150.4 cu. ft.
Related posts
Jeep Wrangler Mojave Rumored To Be Coming In 2021
Can 2021 Ford Bronco win over two-time Jeep Wrangler owner?
Jeep addresses Gladiator, Wrangler steering issue
