2020 Ram Rebel TRX spied testing with video of the exhaust note
March 21, 2019
The 2020 Ram Rebel TRX was spied testing and they captured video of the exhaust note as well. Powered with what we believe to be the 707 HP Hellcat 6.2L V8 engine, this could be a solid Ford Raptor competitor and it looks pretty close to being launched.
Making its debut at the 2016 State Fair of Texas, the Ram Rebel TRX Concept grabbed everyone’s attention. Flash forward a few years and it seems very likely this truck is coming to market.
Spied with what is believed to be the 6.2L V8 Hellcat engine, the pickup may use that engine along with an 8-speed transmission. Then, it could follow the concept with 37-inch wheels, off-road coil-spring suspension, wide-body kit and 13-inches of wheel travel.
When it was revealed Ram’s Jim Morrison boasted it could 100 MPH all day long with its internal bypass shocks and suspension. In other words, it could be a hell of a lot of fun and seriously challenge the Ford Raptor.
In June, 2018, FCA officials confirmed the production plans of the TRX and said it was coming soon.
Ram Rebel TRX Production Confirmed - Will it Actually Happen?Here are our thoughts on the concept.
This new Rebel TRX concept is so incredible, it is truly hard to know where to start besides the fact it can now lay claim to be the most powerful factory-engineered half-ton pickup ever. Now THAT is a Texas sized claim.
Ram Rebel TRX Concept Boasts 575 HP (More than Raptor)
100 MPH in a STOCK pickup on dirt?!?
The Rebel lays this claim after engineers took the already huge 6.2L V8 and put a supercharger on it pushing the truck to achieve 100 MPH when off-roading. In other words, it is mega sized and really, REALLY fast.
Handling this speed is a concern though since a standard half-ton truck would literally get torn to shreds. Ram engineers thought of this too and added an open differential and custom CV half-shafts to handle the wider track. Then, they moved the spindles forward to make room inside the wheel wells for the aggressive 10-ply 37-inch tires with 13.5″ of width and beadlock Mopar wheels.
That’s not all. In the rear, Ram engineers added a Dynatrac Pro 60 axle which spools power through an electric, selectable locker to 35-spline, 1.5″ axle shafts. This locker is available on each of the four different drive modes (Normal, Wet/Snow, Off-Road and Baja) to better help provide traction when tearing up the desert.
Going Fast is Fine, But How About Getting Over Rocks?
You got obstacles to get over? I got you.
– 37 inch tires
Speed is one thing when tearing up the desert, climbing over rocks is another. Ram engineers also looked at this part of the truck and increased the suspension travel by 40 percent which along with those tires means the truck can speed right over obstacles.
It shouldn’t get beat up either with a new custom-built upper and lower A-arms along with changes to caster and camber angle during suspension cycling. Overall, the front- and rear-wheel travel is increased more than 13 inches over the standard 9 inches. Plus, the coil-over shocks with internal bypasses results in a fun, smooth ride all day.
(drools)
The rear also gets new 2.5″ bypass shocks and the rear axle travel spans up to 13 inches now (more than the 9.25″ the stock truck provides).
What about the Rebel TRX Looks?
This truck is so sexy looking!
Sure the modifications are impressive, but I can’t stop taking my eyes off of it. It looks so amazing and Ram says this is because it borrows the best of Rebel and Power Wagon to create a much more chiseled look.
With the Power Wagon-like grille, bold RAM lettering on the rear and a functional front hood scoop, it simple oozes awesome. Designers also went above and beyond adding custom touches and colors to the exterior.
On the inside, FCA’s designer Ryan Nagode for RAM, SRT and Fiat products had to have had a blast working on this truck. The suede seats have an accent mesh cloth along with suede inserts to grip clothing and dress up the styling. Plus, the front seat has embroidered logos and lateral support upper bolsters. Finally, every seat has a six-point harness to keep you from literally flying all over the place.
Yep, that’s a custom release handle.
Throughout the truck, there are TRX badges everywhere including on a special-edition tool bag in the upper glove box.
Finally, all this fun is hard to describe, so Ram added a custom camera mount on the rear-view mirror.
Suddenly riding shotgun isn’t a bad thing.
