2022-2026 Land Rover Range Rover Recall: 93K Water May Damage Rearview Camera
Bianca Bailey
Bianca Bailey
October 27, 2026
A pale gold-colored Land Rover Range Rover on the road.
2022 Land Rover Range Rover (Photo courtesy of Jaguar Land Rover North America, LLC)
A recall of 93,997 Land Rover Range Rover vehicles for potential water ingress damage to the rearview camera.
Jaguar Land Rover North America, LLC (Land Rover) is recalling certain 2022-2026 Land Rover Range Rover vehicles. Water may not be able to drain away from the rearview camera due to insufficient drain holes, which may result in damage to the rearview camera.
Check your vehicle’s VIN at the NHTSA recall lookup or contact your dealer to confirm whether your vehicle is included.
NHTSA ID Number: 26V678
Manufacturer: Jaguar Land Rover North America, LLC
Components: BACK OVER PREVENTION
Potential Number of Units Affected: 93,997
Descriptive Information
Jaguar Land Rover is conducting a voluntary safety recall campaign involving certain 2022-2026MY Land Rover Range Rover vehicles built at the Solihull Vehicle Assembly Plant from July 08, 2021 to June 04, 2026. 93,997 Land Rover Range Rover vehicles in the United States and Federalized Territories. The basis of the recall population of vehicles was determined by inspection of warranty claims and field report data.
A concern has been identified where the water management system on the tailgate of the vehicle may not be sufficient to allow water to drain away from the rearview camera. This can allow water to pool around the rearview camera installation and, over time, can cause damage to the camera. This water ingress can cause a distorted image, or no image at all, to be displayed on the touchscreen.
A blurred image or lack of display of the rearview camera image may result in the driver being unaware of objects or pedestrians, increasing the risk of an injury or a crash.
Description of the cause:
None stated.
None stated.
Chronology
On 31 July 2026 a Product Safety and Compliance Committee (PSCC) investigation was opened to investigate anomalous rear camera replacement rates on Range Rover vehicles. Analysis of warranty claims globally had identified an unexplained elevated camera replacement rate in US & Canada compared to other markets and PSCC directed a dedicated engineering team to investigate this anomaly and report findings into the forum. The team was tasked with manually reviewing the claim details and evidence to understand the reasons for replacements.
On 08 August 2026, noting the recent recall D145 affecting rearview cameras on Discovery vehicles, JLR’s PSCC Decision Forum reviewed the matter and technical content of the investigation to date and requested that further field evidence be gathered to understand whether the replacements represented genuine camera failures.
Throughout August and into September 2026, the manual review of all claims continued whilst removed parts were captured in the US and shipped to the supplier for analysis, and on 18 September 2026 PSCC was informed that a process had now been implemented to ensure that evidence was provided prior to approval of camera replacements resulting in an apparent significant decrease in claim rate.
On 06 October 2026, the PSCC was informed that whilst the market-by-market discrepancy could not be fully explained, the supplier analysis of the first batch of returned rearview cameras had been completed and showed the majority of the analysed parts had failed due to water ingress.
On 08 October 2026, the matter was referred to PSCC Decision Forum which instructed a recall be launched to remedy the affected vehicles in US & Canada where the field evidence showed an elevated rate of failure.
JLR has received 2,295 claims and field reports in the US involving camera replacement between 03 August 2022 and 28 September 2026.
There have been no reported accidents, injuries or fires in the US as a result of this concern.
Remedy
Description of Remedy
Remedy Type: Repair, Inspect, Replace
Vehicles will have additional drain holes drilled in the underside of the tailgate trim which contains the camera. In addition, the functionality of the camera will be verified and, if required, it will be replaced. There will be no charge to the owners for this permanent repair.
This is a water management issue, and holes will be drilled in the underside of the tailgate bezel to increase drainage around the camera.
Notifications to dealers will occur on October 29, 2026. Interim owner notification letters are planned by December 11, 2026. A further letter will follow when the remedy is available.
