Top Five Cheap Upgrades Under $200
Benny Kirk
Benny Kirk
August 22, 2026
Ford Maverick is the cheapest truck to insure in the study
(Photo courtesy of vipautoaccessories.com)
Let’s set the scene for a second. You’re pulling into the driveway after grabbing a used pickup or body-on-frame SUV from the internet. You’ve stalked auction websites, filled out the paperwork, and thoroughly convinced yourself you’d bought a unicorn. You’re satisfied with your haul, but then your head starts racing with ideas for affordable upgrades to make it better.
There’s tons of companies chomping at the bit to provide just that for your truck. Well, at least they claim to. To help you sift through the nonsense, here are five cheap upgrades you can add to a used truck without spending more than $200 at a time. As you’ll find, there are more than a few good options.
Tailgate Assist Dampers & Shocks: Modern Refinement for Cheap Used Trucks
Dee-Zee Tailgate Dampers
(Photo courtesy of Dee-Zee/Real Truck)
Cheers to the veterans who grew up before hydraulically damped truck tailgates were prevalent. Before the soft-open craze of the mid-2010s, you needed to have serious muscle to swing that rear gate up and down a dozen times or more a day. Nowadays, we understand that not everyone is built for that kind of grunt day in and day out. We have technology, so why not use it?
Why they’re a legit cheap upgrade
Hopefully, this one’s pretty self-explanatory. Reputable vendors like Dee Zee and Orion Motor Tech sell complete assembly kits for late-model trucks of all shapes and sizes. From compact Rangers, Dakotas, and S-10s to Rams, F-150s, and Silverados, kits like these can run you as little as $20 at places like Amazon. Without factoring Prime membership or shipping costs, that’s remarkable bang-for-your-buck refinement.
How they work is shockingly straightforward. Gravity compresses the fluid inside the shock absorber the second you unlatch the tailgate, preventing a metal-on-metal incident with the rear bumper, or a bone-on-bone incident in your shoulder. With a 15-ish-minute installation in your driveway, it’s hard to deny that hydraulic gate assists are a no-brainer.
Precision-Fitted, All-Weather Floor Mats: Why Aren’t These Stock Anyway?
wheathertech truck floor mats
(Photo courtesy of WeatherTech)
Something has to be in the water at every single truck maker worth talking about in 2026. Why? Well, slapping plush carpets into full-sized trucks meant to haul dirty riff-raff around lets you know just where the OEMs’ heads are at. Maybe they offer a token bit of extra sound deadening, but at the expense of dirty, crusty mats you have to pay to have cleaned every week? Yeah, there’s a better way.
Sure, off-the-rack rubberized floor mats are an okay fix. Yet, companies like WeatherTech ($125-$145 for a front set) and SmartLiner ($127.99 for a front set) make precision, laser-cut rubber floor mats that keep a liquid-tight seal against a truck’s floor pan better than an auto parts store special. Just trek in from a mud bog with a gallon of dirty water dripping from your work boots? Well, precision-cut floor mats will keep that water from seeping into the floor, rusting the cab from the inside out.
Most legit vendors will also put dozens of tiny nibs into the mats’ undersides. That way, you won’t have to worry about them shifting while you drive. Overall, it’s a pretty elegant system, one you can pick up for just south of $200, or even less with a sale.
Underseat Storage: A Small-Item Storage Solution That Makes Sense
du ha under seat storage locker
(Photo Courtesy of Du-Ha)
You’d be surprised how scarce storage pockets for smaller items are in full-size crew cab trucks. SUV-like legroom and features might be there, but why OEMs choose to put the simple stuff behind an optional paywall or leave it out entirely is beyond us. Official under-seat lockable storage solutions from Ford, GM, and Ram can run anywhere from $350 to $500, depending on scarcity, sales tax, and a few other factors. That’s where the aftermarket undercuts the OEMs by 50% or more.
Vendors like Du-Ha, and once again, WeatherTech, offer lockable high-strength plastic small-item storage lockers that slide right underneath the seats in the rear of a truck’s cab. In the case of Du-Ha in particular, their storage boxes are made of roto-molded high-density polyethylene (HDPE). It’s the same material used by YETI’s premium drinks coolers, as well as in whitewater kayaks.
WeatherTech’s system is interesting, in that it’s made of a similar material to their precision-cut rubber floor mats. Oftentimes, aftermarket under-seat storage boxes offer built-in clearance for factory power inverters. That way, you don’t lose any 12-volt functionality. It’s a pretty foolproof system, even for a hunk of plastic. For a price of between $140 and $160, the WeatherTech system is remarkably affordable. For not much more, a roughly $190 Du-Ha box offers great functionality.
Multi-Ball Adjustable Drop Hitches: For People Who Actually Tow With Their Trucks
curt adjustable channel mount
(Photo courtesy of CURT)
If you plan on doing “truck stuff,” like hauling heavy loads, you can do far better than the rusty hitch ball that came with your rig when you bought it second-hand. Sure, it might be okay for a small utility trailer or pop-up camper, but everything falls to pieces the minute you need to haul anything bigger. You could, of course, go all out with an aluminum hitch with built-in hydraulics, but there is a cheaper and nearly as adaptable alternative.
Brands like Rough Country and CURT offer adjustable Class IV and V trailer hitches, much better suited to the trailering demands that mid-size and full-size trucks contend with. The reversible shank and hex bolt system native to the Rough Country hitch does a remarkably seamless job of dropping or raising the hitch as much as four to six inches. Meanwhile, the CURT adjustable channel mount slides directly into a two-inch receiver, making adjustments on the mount side exceptionally easy. Without breaking the bank, it makes an amateur towing setup look and feel a lot more competent. At $149.96 and $112.49 respectively, you could almost buy them for pocket money.
Front and Rear Suspension Tweaks: A World of Difference to the Driving Experience
bilstein steering stabilizer
(Photo courtesy of Bilstein)
No, you don’t need to break the bank to make your truck ride and handle a little bit better. If you’re not set on dishing out thousands for Fox or Bilstein shocks, the exact same companies offer front-end as well as rear-end suspension goodies that do a serviceable job on their own.
At the front of the truck, Bilstein offers the 5100 series gas-charged steering stabilizer for older 4x4s and the few heavy duty modern rigs with solid front axles. At between $90 and $125 depending on the online shop, this little doohickey uses charged nitrogen to keep the steering wheel smooth and stable over rough terrain.
This means bye-bye bump steer and premature wear and tear to your steering box, ball joints, and tie rods. At the back, rear leaf springs are about as sophisticated as a horse-drawn wagon, and they often ride like them. That’s where companies like Hellwig and their EZ-990 over-leaf helper spring kit come into play.
Using hot-rolled, heat-treated spring steel, the system bolts right up to a truck’s rear end and can help level the truck as it gets closer to its maximum towing capacity. They can also mitigate the “seesaw” fulcruming effect that happens when towing heavy loads. That’s an improvement you can feel as soon as the installation is complete, and before labor, it really doesn’t break the bank at all.
