2026 Jeep Grand Wagoneer, Grand Wagoneer L Recall: 11K Loss of Electronic Stability Control & Brake Assist
Bianca Bailey
Bianca Bailey
July 18, 2026
2026 Jeep Grand Wagoneer (Photo courtesy of Stellantis)
A recall of 11,980 Jeep Grand Wagoneer and Grand Wagoneer L for faulty stability control and brake assist.
Chrysler (FCA US, LLC) is recalling certain 2026 Jeep Grand Wagoneer and Jeep Grand Wagoneer L vehicles. The brake system control module software may cause a loss of electronic stability control and a loss of electronic brake assist. As such, these vehicles fail to comply with the requirements of Federal Motor Vehicle Safety Standard numbers 126, “Electronic Stability Control Systems” and 135, “Light Vehicle Brake Systems.”
NHTSA ID Number: 26V414
Components: ELECTRONIC STABILITY CONTROL (ESC), SERVICE BRAKES, HYDRAULIC
Potential Number of Units Affected: 11,980
Descriptive Information
Some 2026 Model Year Jeep Grand Wagoneer and Grand Wagoneer L vehicles may have been built with a Brake System Control Module (“BSCM”) with suspect software which may disable Electronic Stability Control (“ESC”) and may lose electronic brake assist.
The suspect period began in June 2025, when the first 2026 Model Year vehicles were produced, and ended on February 16, 2026, when the last suspect vehicle was produced. The suspect period was determined using supplier and vehicle production records.
Similar vehicles not included in this recall were built after the suspect period or were repaired prior to being released from plant control.
Federal Motor Vehicle Safety Standards (“FMVSS”) No.126 S5.1.2 requires that the Electronic Stability Control (“ESC”) “[i]s operational during all phases of driving including acceleration, coasting, and deceleration (including braking) […].” A BSCM with suspect software may not allow proper ESC function during all phases of driving.
FMVSS No. 135 S7 requires certain testing to be performed using the specified test methods. Suspect vehicles may lose electronic brake assist and be unable to meet the performance requirements of FMVSS No. 135.
A BSCM with suspect software can cause a loss of ESC function and/or electronic brake assist, which can cause a vehicle crash without prior warning.
Description of the cause:
None stated.
None prior to failure. Once the BSCM has faulted, multiple warning lights may illuminate in the instrument panel cluster.
Chronology
On April 7, 2026, the FCA US LLC (“FCA US”) Technical Safety and Regulatory Compliance (“TSRC”) organization opened an investigation into some 2026 Model Year Jeep Grand Wagoneer and Grand Wagoneer L vehicles potentially built with suspect BSCM software.
From April 2026 through May 2026, FCA US TSRC met with FCA US Engineering to understand potential root cause, customer consequence and vehicle scope.
From April 2026 through May 2026, FCA US TSRC conducted an analysis of field records and customer assistance records to understand potential customer consequences.
On June 10, 2026, the FCA US TSRC organization recognized a vehicle build issue existed on certain vehicles related to a condition potentially resulting in a noncompliance with FMVSS Nos. 126 and 135.
On June 25, 2026, FCA US determined, through the Vehicle Regulations Committee, that a noncompliance to Federal Motor Vehicle Safety Standard Nos. 126 and 135 exists in certain vehicles.
Remedy
Description of Remedy
Remedy Type: Software
FCA US will conduct a voluntary safety recall on all affected vehicles to update the BSCM software.
Remedy is updated BSCM software.
FCA US will notify dealers on or about 07/09/2026 and begin notifying owners on or about 07/30/2026.
