The federal civil penalty for tampering with an emissions control device on a diesel pickup currently sits at 45268 dollars per engine or part. A clean used three quarter ton diesel from a small lot in Idaho or East Texas can be had for under 30000 dollars right now. The arithmetic that this creates is doing something to the secondary market in heavy duty diesels that most vehicle history reports do not capture, and the people on the receiving end are second and third owners who never touched a wrench.
EPA’s National Compliance Initiative on aftermarket defeat devices ran hard through 2024 and into 2025. By the time the agency closed out FY 2020-2023, the civil docket carried 172 cases and about 55.5 million in penalties. The criminal side ran 17 cases on the same enforcement push, with 5.6 million in fines and 54 months of incarceration spread among the defendants. The agency’s targeting pattern has not shifted much. Most of the EPA cases name a delete kit manufacturer somewhere on the docket. Bench flash tool suppliers turn up, too, as do the shops doing the install. Hits on individual owners come mostly through state channels, when they come at all. The other route is getting rolled into a commercial case as a secondary defendant. Then, in November 2025, a Wyoming tuner manufacturer who had been convicted on hundreds of counts got pardoned. Two months later, the DOJ put out a memo telling prosecutors to stop pursuing new criminal cases for tampering with onboard diagnostics. Civil authority sat where it was. EPA had already pegged the population at more than 500000 diesel pickups with emissions equipment fully removed, which works out to something like 13 percent of the certified diesel fleet, and those trucks did not disappear. Most ended up resold through wholesale channels, which is the standard way a truck loses any paperwork trail back to whoever did the delete. The demand side shifted in 2025 as well. Franchised lots in states without emissions testing had spent the previous decade either refusing deleted trades outright or marking the trucks down five to ten thousand before shipping them off to auction with the SCR still gutted. By the back half of 2025, that posture had reversed at a lot of stores.
A wholesaler on a Kansas auction circuit said the fastest movers off his lanes are trucks where the previous owner already sank four to six grand into the delete. The next buyer skips that bill, plus the days the truck would sit on a lift waiting for parts. His estimate was that maybe one in three diesels rolling through his lane in the second half of 2025 had something other than stock software on the ECM. A scan tool would surface it in seconds. Nobody at his auction runs the scan. From there, the trucks tend to land on small dealer lots in states with no emissions program. Two transfers, three transfers later, the federal liability is still riding on the same VIN. Pull a history report on one of these trucks, and you get title brand, lien history, mileage as declared at each transfer, accident reports the state DMVs filed, and insurance payouts that bubbled up into the aggregator feeds. What you do not get is the software sitting on the ECM. Whether the SCR can be gutted to a straight pipe is not in there, neither is the status of the DEF plumbing, and the tune that turns off the NOx sensors and fakes regen cycles is also invisible. Upstream of the aggregators, no reporting rule exists that would generate this data in the first place. The feeds carry nothing on it because nothing flows in. An analyst who works on vin checker coverage for heavy duty pickups said the same gap turns up on cross border diesel imports. Sometimes, the only flag is a mismatch between the declared mileage on the title and the engine hours stored on the module. Catching that mismatch means somebody put the truck on a lift and pulled the data manually. Most buyers do not pay for that step. Most dealers do not offer it.
State enforcement does not clean any of this up. If anything, it compounds the mess in ways that hurt the second or third owner more than anybody upstream. CARB in California will catch a deleted three quarter ton during a smog visual or an OBD II scan, and the state penalty stacks 10000 dollars or more per infraction on top of whatever federal exposure already applies. The inspection regime in Texas, Florida, and across the rural Mountain West is safety only, and inspectors there do not look at the exhaust. Consider a truck deleted in Idaho in 2022 and resold to a California fleet operator three years later. The federal violation rides across the state line still bonded to the chassis. When a DOT scale inspector eventually plugs in and pulls codes, the person standing there is the new owner. An inspector at commercial weigh stations in a CARB aligned state said he was pulling deleted three quarter tons off the scale around twice a week through fall 2025, almost all of them titled to second or third owners who claimed they had no idea. Putting the emissions hardware back is not a casual job either. Parts to put the SCR and DPF back on a heavy duty diesel run three to six thousand, labor adds another 800 to 1800 for what is an eight to twelve hour job, and dealer ECM reflash sits on top of that. Five to ten thousand all in for the restoration is roughly what the original owner pocketed by deleting in the first place. Absorbing that cost at resale does not pencil out for the seller, so the bill rides downstream to whoever buys next.
Senator Cynthia Lummis introduced the Diesel Truck Liberation Act in October 2025, and if it passes, it would block federal enforcement of diesel violations, and the inheritance problem on the individual owner side would basically evaporate. As of April 2026, the bill was still sitting in committee, with EPA civil authority under 40 CFR Part 1068 unchanged from where it sat three years ago. A clerk at a registration office in central Wyoming put the volume of deleted diesels coming through her window on transfer paperwork in 2025 at maybe one in four for trucks over 8500 pounds GVW, with no field on the form for any of it.
