Ram 1500 Reliability & Common Problems: Best Years to Buy & Avoid
2025-2026 Ram 1500 Known Problems
2026 Ram 1500 (Photo courtesy Ram Trucks)
When people shop full-size pickups, the Ram 1500 usually lands on the shortlist because it rides better than a lot of rivals and has one of the nicest interiors in the class. Still, Ram 1500 reliability is a mixed story depending on the year, powertrain, and how well the truck was maintained—which is why I always tell my friends to budget for a few smart upgrades, like high-quality LED headlight bulbs, to fix the factory’s dim output right away. The big question isn’t whether the truck is comfortable or capable, because it is. The real question is whether the Common Ram 1500 problems are manageable enough to make it a smart buy for your driveway, jobsite, or weekend tow rig.
Is the Ram 1500 Reliable?
So, is Ram 1500 reliable? Overall, the answer is yes, but with an asterisk. RepairPal gives the Ram 1500 a 3.5 out of 5.0 reliability score, ranks it 1st out of 17 full-size trucks, and estimates average annual repair costs at about $691. On the J.D. Power side, the 2025 Ram 1500 shows a Quality & Reliability score of 77 out of 100, which is basically middle-of-the-pack rather than truly outstanding. Those Ram 1500 ratings tell you the truck is not a disaster, but it also is not one of those “ignore maintenance and nothing bad ever happens” vehicles.
Here’s the thing: Ram 1500 reliability depends heavily on model year and engine choice. Some trucks hold up very well with routine service, while others are known for engine valvetrain noise, electrical gremlins, leaking rear glass, drivetrain complaints, and a steady stream of recalls or investigations. That matters a lot when you’re shopping a used Ram 1500, because the badge alone does not tell the whole story.
Common Problems with the Ram 1500
The Common Ram 1500 problems tend to fall into a few predictable categories. CarComplaints lists engine issues as the truck’s overall worst problem category, and it flags the 2014 model as the worst year overall. That gives you a pretty good starting point for what to inspect before buying.
1. Engine and valvetrain issues
Engine trouble is one of the biggest reasons some Ram 1500 years get a bad reputation. The 2014 model alone shows hundreds of engine complaints on CarComplaints, including stalls, warning lights, broken rocker arms, and camshaft/lifter failures. One 2014 camshaft and lifter failure example listed an average repair cost of about $6,830 at roughly 117,300 miles, which is the kind of repair bill that can erase any savings from buying used.
Later trucks are not immune either. CarComplaints shows 2020 and 2021 trucks with engine complaints tied to ticking, rough running, stalling, and serpentine-belt-related failures. NHTSA also documented reports of loss of motive power in some 2022–2023 Ram 1500 trucks, especially vehicles equipped with the 5.7L eTorque setup, which is exactly the kind of issue truck buyers should take seriously.
2. Transmission and drivetrain complaints
Ram trucks have also seen a fair number of drivetrain complaints. The 2015 model shows heavy drivetrain complaint volume on CarComplaints, while 2019 trucks include reports of broken stub shafts, lock-up events, and shift-to-park issues. These are not universal problems, but they are common enough that any test drive should include low-speed maneuvering, reverse engagement, and a full warm-up before you decide the truck feels “fine.”
3. Electrical and electronics issues
A lot of owners don’t realize how many Ram 1500 headaches are electrical rather than mechanical. The 2014 truck is well known for various electrical issues, and newer models have had complaints involving infotainment freezing, instrument cluster faults, and software-related warning lights. For example, a 2025 NHTSA recall covered more than 43,000 Ram 1500 pickups because software could cause the 12-inch cluster to go blank at startup or while driving.
4. Water leaks and body-related defects
Rear window and third-brake-light leaks are another recurring theme, especially on newer body styles. CarComplaints identifies rear windshield leaking as a top 2020 problem and back-window leaking as a top 2021 problem. NHTSA service bulletin records also reference water intrusion tied to the third brake/cargo lamp area on certain 2019–2021 Ram 1500 trucks. Water leaks may sound minor, but once moisture gets into the headliner or electronics, repairs can snowball fast.
5. Fuel system and safety investigations
There are also open or recent safety concerns worth noting. CarComplaints lists NHTSA investigations for some later Ram 1500s involving high-pressure fuel pump failure, and NHTSA documents show ongoing scrutiny around loss-of-power events and brake/shift-related behavior in certain model years. This does not mean every truck is unsafe, but it does mean recall history and VIN checks are non-negotiable before purchase.
Ram 1500 problem summary
Problem AreaCommon Issues
EngineLifter/cam failure, rocker arm issues, ticking, stalling, rough idle
Transmission/DrivetrainHarsh shifting, shift-to-park messages, drivetrain lock-up, axle/stub shaft issues
ElectricalVarious electrical faults, Uconnect freezes, warning lights, blank instrument cluster
Body/Water IntrusionRear window leaks, third brake light leaks, wet headliner
LightingHeadlight flicker, dim headlights, exterior lighting complaints
When shopping for a used Ram 1500, prioritize service records, recall completion, cold-start behavior, leak inspection around the rear glass and cab brake light, and a scan for stored trouble codes. A clean-looking truck with poor maintenance history can still be a money pit.
Lighting System Problems & LED Upgrades
Factory lighting is one area where the Ram 1500 often leaves owners wanting more. CarComplaints has a dedicated Ram 1500 lights-problems page, where the 2012, 2014, and 2015 trucks stand out as particularly troublesome years, and the 2019 and 2015 model pages include complaints about headlights flickering and dim headlight performance. There are also NHTSA-linked lighting complaints for the 2014 truck and service documentation involving auto high beam configuration issues on some newer Rams.
The good news is this is one of the easier areas to improve. Quality Ram 1500 led bulbs can give you a cleaner beam pattern, quicker illumination, and much better nighttime confidence than tired halogen bulbs. For owners dealing with weak stock output, upgrading to well-designed Ram 1500 led bulbs is one of the most practical changes you can make, especially for rural roads, bad weather, and dark worksite driving. Many owners looking for better visibility start with the brightest LED headlight bulbs like SEALIGHT S7S series, since a stronger and more focused beam can make nighttime driving feel much more controlled. Just make sure the bulbs are sized correctly, properly aimed, and compatible with the truck’s electrical system so you do not trade dim lights for glare or CANbus flicker.
Best & Worst Years
Based on complaint volume and problem severity, 2014 is the clear year to avoid first. CarComplaints calls it the worst Ram 1500 model year overall, and 2015 and 2016 also show very high complaint counts with recurring engine, drivetrain, and electrical concerns. If you are cross-shopping older trucks on price alone, those years deserve extra caution and a very thorough pre-purchase inspection.
The safer bets are usually later, better-documented trucks with fewer major complaint trends. On complaint volume alone, 2017 and 2018 look more manageable than 2014–2016, though they are not flawless. Among newer-generation trucks, 2020 and 2021 still show issues, but the top complaints are more often leaks, infotainment bugs, and trim-related annoyances rather than the truly ugly early-engine horror stories that haunt 2014.
My mechanic-style take: if you want the sweet spot, shop carefully among late-2017, 2018, or well-maintained 2020–2021 examples, verify recalls by VIN, and avoid any truck with obvious ticking, incomplete service history, or signs of water intrusion.
Comparison: Ram 1500 vs. Ford F-150
The most logical rival here is the Ford F-150. On paper, RepairPal scores both trucks at 3.5 out of 5.0 for reliability, but the Ram 1500 ranks 1st among full-size trucks while the F-150 ranks 7th, and the Ram also has a lower estimated annual repair cost at $691 versus the Ford’s $788. That gives the Ram a real edge in ownership-cost math.
Where the Ram usually wins is ride comfort, cabin quality, and day-to-day refinement. Where the F-150 often wins is parts availability, broader powertrain familiarity, and a reputation for being easier to find and compare on the used market. The tradeoff is that both trucks have their trouble years: CarComplaints flags the Ram 1500’s worst year as 2014 and the F-150’s as 2018. In plain English, the Ram often feels more upscale, but the exact year matters more than the logo on the grille.
At the end of the day, Ram 1500 reliability is good enough to recommend, but only if you buy the right year and inspect it like someone who plans to keep it. The smartest shoppers learn the Common Ram 1500 problems before signing anything, then use that knowledge to check engine noise, leaks, recalls, and electrical behavior on a test drive. And once you’ve got a solid truck, upgrading worn factory lighting with high-quality SEALIGHT Ram 1500 led bulbs is an easy way to make nighttime driving safer, sharper, and a whole lot more confidence-inspiring.
