Moving To New Jersey With A Pickup (Or Towing): The Real-World Driving Prep Checklist
(Photo by Dina Badamshina)
Long weeks on the road make a cross-country move feel deceptively simple—until New Jersey hands you toll gantries, tight interchanges, and metro traffic right when you’re tired and towing. This checklist is built for readers who want fewer surprises in the first two weeks: mobility sorted, paperwork scheduled, tolling handled, and a tow setup that matches NJ requirements.
If you’re towing a camper or car, print this checklist, tape it to your dash, and follow it.
If You Arrive Without Wheels: Nj Public Transportation For Getting Around In New Jersey
If your pickup is shipping in later, your trailer is already parked, or you’re simply trying to avoid driving while you learn the area, New Jersey’s transit network can cover a lot of your “first-week essentials. The first thing to do is start getting around  New Jersey.
The most practical first step is NJ TRANSIT’s Trip Planner: plug in your new address (or closest station) and save your repeat routes—work, grocery runs, and the MVC—so you’re not re-planning every morning. If you’re in Hudson County/near NYC, add light rail for local hops (Hudson-Bergen Light Rail and Newark Light Rail are both covered in NJ TRANSIT’s light rail tools and “How to Ride” guidance). And if your commute crosses into Manhattan from Newark/Jersey City/Hoboken-area connections, PATH can fill the gap; the Port Authority notes MetroCard will continue to be accepted into 2026 while changes roll out.
Driver-specific tip: treat transit like a pre-trip inspection. Do one “dry run” at the same time of day you’ll normally travel, note the walk time from the stop to the actual door you need (office, school, apartment), and screenshot the return options—because the easiest way to blow your first week is getting stranded when your plan assumed perfect timing.
New-Resident Paperwork: Don’t Let The 60-Day Clock Sneak Up
New Jersey’s Motor Vehicle Commission (MVC) states that under New Jersey law you must transfer your vehicle title and registration within 60 days after moving (longer deadlines apply only in specific emergency periods). That matters for pickup owners who keep out-of-state plates “until everything settles.” Plan the appointment early—many MVC services are appointment-based, and the MVC’s registration guidance emphasizes scheduling rather than walking in.
Treat the trailer as its own project. The MVC has a dedicated page for trailers and private utilities that covers registration for manufactured or homemade trailers. Gather your proof of ownership, confirm the correct trailer category, and handle it before you’re commuting through toll plazas with temporary paperwork in the glove box.
Toll Reality: Set Up E-ZPass Before You Hit Rush Hour
A move into North Jersey can rack up tolls quickly, and many facilities are cashless. The cleanest solution is E-ZPass. The New Jersey Turnpike Authority explains that you open an NJ E-ZPass account with an initial deposit of at least $25, receive a tag, mount it, and tolls are deducted automatically on the Turnpike and Garden State Parkway (and other E-ZPass roads). Do this before move day so you’re not juggling invoices and plate lookups after a long drive.
For live road conditions, 511NJ is your friend. NJDOT describes 511 as a free traveler-information service you can access by calling 511 anywhere in New Jersey, and 511NJ.org provides real-time updates. Use it the night before and the morning of any “first-time” drive with the trailer.
(Photo by Matt Donders)
Towing Setup That Matches NJ Requirements
Before you roll, confirm your numbers: truck payload, hitch rating, tongue weight, and the trailer’s GVWR. New Jersey MVC states that if the trailer’s gross vehicle weight rating (including load) is more than 3,000 lbs or more than 40% of the towing vehicle’s gross weight, the trailer must be equipped with brakes. If you’re near that threshold, don’t guess—set up a brake controller, verify braking response in a safe lot, and rebalance your load.
Do a fast walkaround every morning for the first week: tire pressures, lights, coupler latch, safety chains, and breakaway cable. And if you’re moving in winter, watch NJDOT restriction alerts. In January 2026, NJDOT messaging encouraged trucks already in New Jersey to wait out restrictions at truck stops and warned not to park on shoulders. Your takeaway: have a “pause plan” (where you can safely stop) if weather or traffic collapses.
One very NJ-specific detail: fueling. New Jersey’s Retail Gasoline Dispensing Safety Act resources state that no person shall dispense fuel at a gasoline station unless they are an attendant meeting training requirements. Translation for out-of-staters: you typically don’t pump your own gas—so budget extra time, especially when you’re towing and need a wider forecourt.
Route Quirks: Jughandles, Keep-Right Enforcement, And The Parkway Trap
Two local realities bite movers: intersections and lane discipline.
  • Jughandles: a Federal Highway Administration research page notes NJDOT’s design manual definition of a jughandle as an “at-grade ramp” that permits indirect left turns and/or U-turns, exiting from the right lane either before or after the intersection. With a trailer, that means your “left turn” may require a right-lane exit you must spot early.
  • Lane discipline: New Jersey statute 39:4-88 says a vehicle shall normally be driven in the lane nearest the right-hand edge when available, except when passing or preparing for a left turn. For a towing rig, staying right also keeps your exit options open and reduces sudden merges.
Finally, know where you can’t go. The New Jersey Turnpike Authority states that heavy trucks with a registered weight of 10,000 pounds or more are prohibited north of Interchange 105 on the Garden State Parkway. Most pickups won’t hit that registered-weight category, but some registrations and upfitted work builds can—so verify your registration weight and route accordingly.
(Photo by Jonathan Roger)
Endnote
Moving into New Jersey with a pickup or tow rig is easiest when you treat it like a professional run: plan mobility, then paperwork, then tolling, then route details. Use NJ TRANSIT and PATH as a backup until you learn local traffic patterns. Schedule MVC tasks early and register the trailer as its own item. Set up E-ZPass before your first commute, and check 511NJ when weather or congestion threatens your timeline. Confirm trailer brakes, lights, and load balance, and remember fueling works differently here. Do these steps once, and the rest of your move gets calmer for everyone involved.
