Tim and I just spent three days in Death Valley living with the first Explorer to wear Ford’s Tremor branding and off-road hardware. While we cannot yet tell you about how it handled the harsh terrain of the hottest place on Earth, we can tell you what makes it worthy of the Tremor name.
It is worth noting that when the current generation Explorer was launched in 2021, Ford did give it an off-road-focused Timberline trim that was later added to the larger Expedition.
Powerful and Responsive Engines
The standard engine in Ford Explorers is the brand’s 2.3L EcoBoost 4-cylinder engine, making a stout 300 horsepower and 310 lbs.-ft of torque. This was the same engine offered in the Timberline. However, the Tremor has the option of stepping up to the ST trim’s 3.0L twin-turbocharged V6 with a substantial increase in power to 400 horsepower and 415 lbs.-ft of torque.
Limited-slip Rear Differential
Standard All Wheel Drive traction at all four tires is improved by the addition of a Torsen limited-slip differential. Off-road drive mode, a Tremor exclusive, adds to driver confidence with better throttle and transmission response, along with a display from the Explorer’s exterior cameras on the infotainment screen.
All these features were also standard equipment on the Timberline.
Off-Road Tuned Suspension and Tires
Tremor wears exclusive 18-inch gloss black wheels with orange accents highlighting the placement of the valve stem for easier spotting when you need to air down for a trail or back up to hit the road. These wheels are wrapped in 265/65R18 Bridgestone Dueler A/T tires. These 31.5-inch-tall tires and uniquely tuned suspension give the Tremor about one inch of additional ground clearance, while the suspension’s tuning for springs and sway bars sets it apart from other trims.
Aside from the “Electric Spice” orange accents, this is the same approach taken by the Timberline.
Underbody Protection and Improved Off-Road Angles
Three different skid plates protect the underbody of the Explorer Tremor. A bash plate under the nose, along with an increase in approach angle from 19.7 degrees to an impressive 24.1 degrees, could mean the difference between taking a trail or turning around. A front underbody skid protects the engine and vital components at the front of the Explorer, along with an improved 18.7-degree breakover angle versus the base 16.5 degrees. A 23.7-degree departure angle is further accentuated by a rear skid plate that protects around and under the trailer hitch receiver.
| 2026 Ford Explorer | 2021-25 Explorer Timberline | 2026 Explorer Tremor | |
| Approach Angle | 19.7º | 23.5º | 24.1º |
| Departure Angle | 21.5º | 23.7º | 23.7º |
| Breakover Angle | 16.5º | 18.7º | |
| Ground Clearance | 7.6 inches | 8.7 inches | 8.7 inches |
Enhanced Comfort Options
In addition to all the off-road capabilities mentioned above, Ford is proud that any of the luxury items from other trims of the Explorer are available on the Tremor. We had heated and ventilated seats with a full massage wrapped in Miko Suede, dual zone climate control, and seating for six.
Come back on January 29th to get our full thoughts on what it was like taking the 2026 Ford Explorer Tremor through Death Valley.
