Beyond Lifting: 7 Four-Post Car Lifts That Double as Storage—and Wrenching—Solutions
(Photo by Artem Podrez)
Most home garages have a dirty little secret: all the square footage you need is already there, hiding in the rafters. A four-post lift lets you claim that vertical real estate, turning one floor slot into two.
But the pay-off isn’t just parking—being able to stand under your vehicle changes every maintenance task from a contorted crawl to a comfortable walk-up job.
Below, we unpack how vertical parking works, the servicing perks you’ll feel on day one, and seven lift picks that give every cubic inch of overhead space a new purpose.
Why “Vertical Parking” Beats Adding On
The average American wastes about 17 hours a year searching for parking—time better spent working on your car.
A four-post lift solves both problems: you park two vehicles in one bay and elevate the top one to oil-change height without jacks or creepers.
The capital outlay is often less than a month’s mortgage on a new addition.
How Four-Post Lifts Unlock Your Garage’s “Air-Rights” and Under-Car Access
Unlike two-post units that grab the frame at four pads, four-post lifts use runways. Drive on, hit the button, and a hydraulic piston pulls steel cables over massive sheaves—raising the entire deck in perfect unison.
Every four inches, a mechanical ladder lock engages, giving you dozens of safe working heights for brake jobs, exhaust swaps, or detailing.
A typical UK single garage—3 m × 6 m—becomes a two-bay stack when you add a four-post parking lift.
In North America, the maths is similar: vehicle height + runway thickness + 4 in clearance tells you whether your ceiling accommodates both parking and wheel-well room for a torque wrench.
Three Essentials Before You Click “Add to Cart”
Capacity & Wheelbase
Account for EV curb-weight creep—full-size trucks now top 7,000 lb. Choose a lift rated at least 20 percent above your heaviest vehicle so you can still lift the car high enough to drain the diff or drop a transmission.
Footprint & Ceiling Height
Measure bumper-to-bumper, mirror-to-mirror, and door swing. Add 24 in behind the posts so you can still roll a tire balancer or brake lathe behind the runways.
Safety & Certification
Look for ALI or ETL badges, secondary slack-cable devices, and enclosed pulleys. Those details matter when you’re lying under a fuel tank with a ratchet in hand.
The 7 Best Four-Post Lifts for Space-Strapped Owners
Each pick below meets three rules:
  • Capacity of at least 8,000 lb,
  • Runways short enough for a 20- to 24-ft garage,
  • Available from U.S. suppliers.
1. Wrenchers BendPak HD-9
  • Capacity: 9,000 lb
  • Rise height: 70 in.
  • Best for: All-rounder garages
BendPak’s HD-9 is the benchmark thanks to almost ½-inch cables and multi-position safety latches that engage into position every four inches. Order it bolt-down for max rigidity or spec the caster kit and roll the entire unit to the driveway for detailing day.
Need mid-span wheel work? Slide-in bridge jacks convert the runways to a flat scissor lift. Dealer-grade support matters too—HD-9 listings on Wrenchers include free freight and phone tech support.
2. Forward Lift EFP8
  • Capacity: 8,000 lb
  • Rise height: 79 in.
  • Best for: Budget-friendly, ALI-certified peace of mind
Forward’s light-duty storage lift borrows its DNA from 14-k-lb commercial cousins: greaseable sheaves, single-point lock release, and full ALI certification.
The 110-volt power unit plugs into a standard outlet, and multi-position locks keep the runways level at any height—a perk when you’re bolting on a roof rack.
3. AMGO A430-HP
  • Capacity: 6,600 lb
  • Rise height: 74 in.
  • Best for: Narrow British-style garages
At just 2,509 mm wide, the A430-HP squeezes into bay widths that two-post lifts can only dream of. Fold-away ramps retract 100 percent, so the door behind the column still opens.
Manual single-point release drops both locks together; hidden secondary latches re-engage automatically on the way down.
4. Wildfire WF9000XLT
  • Rise height: 88 in.
  • Best for: Tall-ceiling workshops needing truck clearance
Wildfire’s signature is over-built: ½-inch cables rated for 14,500 lb, 5×5-in. laddered locks laser-cut from a single billet, and two hydraulic cylinders (not one) to share the load.
The powder-coat formula is the same zinc-rich epoxy used on highway guardrails, ideal for salty climates.
5. Dannmar D4-12
  • Capacity: 12,000 lb
  • Rise height: 78 in.
  • Best for: ¾-ton pickups and vans
With 88-in. between posts, the D4-12 swallows dually fenders yet still fits a spec-home garage. A 220-V pump unit lifts the platforms in a brisk 55 seconds.
Order the rolling bridge jack and it doubles as an alignment rack—handy for DIY ADAS calibrations.
6. Advantage DX-9000-XLT
  • Rise height: 82 in.
  • Best for: Crew-cab trucks or long-wheelbase classics
The XLT stretches the runways to 205 in. (17 ft 1 in.), perfect for Rivian R1T or a ’70s Cadillac.
CNC-milled aluminum drip trays slide anywhere along the deck, and a built-in caster kit means you can reposition the whole lift solo.
7. APlusLift HW-8S
  • Best for: Cash-savvy builders wanting plug-and-play
Despite its entry-level price, the HW-8S ships with casters, drip trays, a jack tray and nylon felt on ramp ends to protect painted floors.
Powder-coat meets ASTM B-117 salt-spray standards for 500 hours—roughly five winters of condensation cycles.
Installation & Safety Checklist
A four-post lift isn’t a beer-and-buddies Saturday project—treat it like structural steel:
  • Slab: Minimum 4 in. of 3,000 psi concrete; no cold joints inside the footprint.
  • Shims: Use factory shims under every baseplate until the bubble centrelines.
  • Anchors: Torque to manufacturer spec (typically 90–100 ft-lb) after 24-hour cure.
  • Lock audit: Cycle the lift empty, then load, checking both mechanical and slack-cable latches.
For a primer on weight math, see PickupTruckTalk’s Personal truck towing basics – understanding payload.
Maximising the Storage and Service Dividend
Bolt plywood between the runways for a 100-sq-ft mezzanine—or leave them open so you can set up a transmission jack.
Some owners store a classic Mustang overhead, a daily SUV below, and still roll a tire changer under the front cross-beam.
Future-Proofing: EV Mass, ADAS & Resale Value
Battery packs add 800–1,000 lb to midsize crossovers; spec capacity now so you’re not shopping again in five years.
Runways pre-drilled for alignment turntables make ADAS recalibration a driveway job—an income stream that accelerates payback.
A cleanly installed lift is also the open-house eye-candy buyers remember.
A four-post lift buys both square footage and wrench-time: park two cars in one slot, then service the top one at standing height. Measure your ceiling tonight, browse the seven contenders above, and picture a future where oil changes, brake swaps, and detailing all happen without your back ever touching concrete.
Continue reading
