Rediscovering Rugged Simplicity – 2025 Nissan Frontier Pro4X Review
The 2025 Nissan Frontier Pro4X stands out with its straightforward design and proven mechanics. It keeps the old school leaf springs and solid axle at the rear. It relies on a naturally aspirated V6 and a tried and tested automatic gearbox. There are no complex hybrids or turbos in sight. This model offers a simple, honest setup that still feels modern enough for daily use like non GamStop sports betting.
Design and Build
Exterior and Chassis
The Frontier Pro4X keeps a familiar look. Its single side exit exhaust is mild steel with an aluminium coating. The spare wheel matches the rest. The skid plates protect key parts under the fuel tank and transfer case. The wheels are optional 17 inch replicas with beadlock styling. They pair with 265/70 R17 tyres from Hankook.
Features:
  • Steel skid plates on engine, transfer case and fuel tank
  • Single exhaust outlet in mild aluminised steel
  • 17 by 7.5 inch diecast alloy wheels
  • Solid rear axle from Dana with 3.692 final drive ratio
  • Electronic locking rear differential
Suspension and Underbody
The rear uses four leaf springs and Bilstein yellow body shocks. There is no lift block under the leaves. The front uses double wishbone arms and coilover dampers. The front anti‑roll bar is about 36 mm in diameter. The rear bar is roughly 26.5 mm. The platform is the F‑Alpha chassis shared with other models.
Key specifications
ComponentSpecification
Chassis platformF‑Alpha (four-door)
Rear suspensionSolid axle with leaf springs
Front suspensionDouble wishbone with Bilstein coilovers
Rear anti-roll bar26.5 mm diameter
Front anti-roll bar36 mm diameter
Final drive ratio3.692:1 (rear axle)
Low range ratio2.717:1 (transfer case)
Wheels17 × 7.5 inch alloy replicas
Tyres265/70 R17 Hankook Duro AT2
Powertrain and Performance
Engine and Transmission
Under the bonnet sits the VQ38D 3.8 litre V6. It makes 310 hp at 6,400 rpm and 281 lb‑ft of torque at 4,400 rpm. The engine uses direct injection and chain driven camshafts. It drives through the JR913E nine speed automatic. That gearbox is a German design, built in Japan by Jatco. It has a 700 Nm torque limit and a plastic pan cooler.
The transfer case is a two speed unit with low range of 2.717:1. It shifts power front and rear. There is no front locker option. The skid plate under the case is steel and shows some use on this test model.
On‑road and Off‑road Tests
Track test and braking gave mixed notes. Braking felt smooth but a bit past average distance. The two piston front calipers clamp 297 mm rotors. Rear uses single piston units on 287 mm discs.
Off‑road, the truck climbed hills and rough paths well. It used rear diff lock and four low gear without fuss. Stability aids can be intrusive, even when switched off. The steering is weighty and precise. The solid axle rear soaks rough terrain better than expected.
Interior and Comfort
Cabin Layout
The cabin is simple. The seats are black leather with orange stitch and Pro4X logos. They are heated, as is the steering wheel. The dash has easy knobs for dual zone climate control. The drive mode, traction and diff lock buttons sit to the left of the wheel. There is a manual slider for the seat. The door uses map pockets and soft padding.
Storage and power:
  • One 400 watt AC outlet
  • USB‑C port and USB‑A charger
  • Wireless phone charger and cubby tray
  • Cup holders built into centre console
Technology and Storage
The infotainment screen is integrated into the dash. The active grille shutter offers slight gains. A trail camera sits on the front grill. The sound system is by Fender. Its bass punch is strong. High notes are clear, if not top end.
The back seat is fair for tall passengers. Folding seats can be tricky to lock in place. The rear wheel wells are open to debris build up. There are fake body coloured vent covers on the flares.
Practical Scores
Tow Capacity and Payload
The Frontier Pro4X can tow 6,680 lb (3,030 kg). Payload is around 1,500 lb (680 kg). Its leaf spring rear end is simple but strong. Tow mode tuning gives a confident feel.
Fuel Economy
This V6 averages just over 20 mpg on mixed roads. It nudges 21 mpg (13.4 L/100 km) on open runs. That is good for a truck of this shape and weight.
Performance Scores
CategoryScore (out of 10)Comment
Driving feel7Responsive steering, firm yet engaging ride
Value for money6Fair base price but high when fully loaded
Ease of maintenance9Simple design, easy access to key parts
Off-road capability8Solid axle traction, good ground clearance
Enthusiast appeal8Natural V6 sounds great, mod-friendly
Pros and Cons
The following highlights the key strengths and weaknesses of the Frontier Pro4X based on its performance, design and value.
Pros
  • Simple design that is easy to fix
  • Strong V6 power and sound
  • Solid off‑road performance
  • Heated seats and wheel
  • Reasonable fuel use
Cons
  • Gearbox shift delay in manual mode
  • Nanny systems can be intrusive
  • No manual transmission option
  • Rear wheel wells gather dirt
  • Higher price pushes near £50,000
The 2025 Nissan Frontier Pro4X suits buyers who want a true midsize truck with few frills. It blends a classic build with modern features. The naturally aspirated V6 stands out in a market of turbos. Its simple suspension and solid axle rear offer both strength and comfort off‑road. It will not be the fastest or the most advanced. It may be the last of its kind in a segment that is drifting toward complexity.
For those who value ease of upkeep and honest performance, this truck holds strong appeal. It asks for few upgrades and delivers clear capability at a fair cost. It may well be the last simple, reliable pickup left on sale.
Frequently Asked Questions
What engine does the 2025 Frontier Pro4X use?
It uses the VQ38D 3.8 litre naturally aspirated V6 with direct injection and variable valve timing.
Can the Pro4X handle serious off-road trails?
Yes. Its solid rear axle, electronic locking differential and sturdy skid plates offer reliable off-road performance.
What towing capacity can I expect?
The truck can tow up to 6,680 lb and carries a payload around 1,500 lb.
How efficient is the V6 in fuel use?
It averages about 20 mpg in mixed driving and can return close to 21 mpg on highways.
Does it offer modern comforts inside?
It has heated leather seats, a heated steering wheel, dual zone climate knobs and a simple infotainment screen.
Why is there no manual gearbox option?
Nissan did not offer one for 2025, likely to streamline production and meet emissions targets.
