How Long Does Servicing a Car Take? A Complete Guide
auto repair
Regular car servicing is crucial for maintaining your vehicle’s performance, safety, and overall lifespan, whether you rely on routine maintenance or occasionally visit an autobody shop Lancaster, PA for
more extensive repairs
In this guide, we’ll explain the different types of car services—Interim, Full, and Major—detailing what each includes, how long they typically take, and the factors that can influence service duration.
What Is Car Servicing?
Car servicing involves routine maintenance checks and component replacements to ensure the vehicle is functioning efficiently and safely. It can prevent unexpected breakdowns and reduce long-term repair costs. Generally, servicing is categorized into three types:
  • Interim Service (every 6 months or 6,000 miles)
  • Full Service (annually or every 12,000 miles)
Each level of service requires a different amount of time, depending on the depth of checks and replacements involved.
Interim Service – Time Required: 1 to 2 Hours
An interim service is designed for high-mileage drivers who require frequent check-ups to maintain vehicle reliability.
What’s Included:
  • Oil and oil filter change
  • Fluid top-ups (coolant, washer fluid, brake fluid)
  • Basic safety checks on lights, wipers, tyres, and brakes
  • Visual inspections for leaks, corrosion, or damage
  • Basic suspension and steering check
Duration:
This level of service usually takes between 1 to 2 hours. If no issues are detected and replacements are readily available, the process is swift and convenient.
Full Service – Time Required: 2.5 to 3.5 Hours
A full service is a more detailed inspection carried out annually.
What’s Included:
  • All interim service checks
  • Air filter and fuel filter replacement
  • Cabin filter replacement
  • Spark plug replacement (petrol engines)
  • Brake system and battery inspection
  • Exhaust and suspension checks
Duration:
Expect the service to take around 2.5 to 3.5 hours, depending on your car’s make and condition. Additional diagnostics or small repairs may extend this time slightly.
Major Service – Time Required: 3 to 5 Hours
The major service is the most comprehensive and is recommended every 24,000 miles or two years. It focuses on deep maintenance and longevity of essential vehicle systems.
What’s Included:
  • Everything from full service
  • Brake fluid replacement
  • Transmission fluid and coolant change
  • Wheel alignment checks
  • Timing belt inspection or replacement (if applicable)
  • In-depth engine diagnostics
Duration:
This can take 3 to 5 hours or longer if additional parts are required or complications are found. It’s best to drop off your vehicle for the day when booking a major service.
S&B Filters: Enhance Your Vehicle’s Performance
When you’re investing in car servicing, it’s also a good time to consider performance-enhancing upgrades. During or after a major service, installing an S&B Filter can significantly boost your car’s fuel efficiency and performance. They are especially beneficial for drivers of trucks and SUVs who need more from their engines. Adding performance parts like S&B Filters can make your routine service even more valuable by extending engine life and improving throttle response.
AudioCityUSA: Elevate Your Driving Experience
If you’re already booking a service appointment, why not also take the opportunity to upgrade your vehicle’s style and comfort? AudioCityUSA offers an extensive range of custom wheels, tires, and suspension upgrades that can be perfectly timed with your car service.
Having your car at the shop already makes it convenient to install AudioCityUSA wheels or suspension kits, as the vehicle is already lifted and inspected. Their products not only enhance the look of your car but also improve ride quality, traction, and handling—key elements of overall driving satisfaction. Combine routine maintenance with aftermarket upgrades for a complete performance and aesthetic overhaul.
Factors That Can Affect Service Time
Several variables can alter how long a car service actually takes. These include:
1. Vehicle Age and Condition
Older vehicles or those with a spotty service history may require more inspections and replacement parts.
2. Car Make and Model
Luxury or imported vehicles often require more time due to complex designs or the need for specialized equipment.
3. Parts Availability
If parts are not readily available, the garage may need to order them, extending the service time.
4. Workshop Schedule
Booking during peak hours or seasons can increase wait times even if the actual service is quick.
5. Additional Repairs
Unexpected issues discovered during servicing—like worn brakes or leaking fluids—can lengthen the time needed.
Can You Wait While Your Car Is Being Serviced?
For interim or full services, many garages allow you to wait in a lounge with Wi-Fi and refreshments. However, for major services or repairs that require part replacements, it’s usually best to drop off your car and pick it up later.
Some service centers also offer courtesy cars, pick-up/drop-off services, or express service options to make the process more convenient.
Tips to Minimize Downtime
  • Book ahead – Advanced scheduling helps ensure parts and technicians are ready.
  • Visit during weekdays – Avoid weekends or holiday rushes.
  • Bundle upgrades with service – Install parts like S&B Filters or AudioCityUSA wheels during your scheduled service to save time. Scheduling car detailing service alongside a servicing appointment is also common, as it allows owners to return to a vehicle that’s both mechanically sound and visually refreshed.
  • Communicate clearly – Let the service advisor know if you’re on a tight timeline.
Final Thoughts: Make the Most of Every Service
So, how long does servicing a car take? Here’s a quick recap:
Interim Service: 1 to 2 hours | Full Service: 2.5 to 3.5 hours | Major Service: 3 to 5 hours
Proper car servicing ensures your vehicle stays in peak condition, helps avoid costly breakdowns, and maintains resale value. Combine this with performance upgrades from S&B Filters or style enhancements from AudioCityUSA, and your car will not only run better but also look and feel brand new.
Ready for Your Next Service?
Whether you’re due for a quick oil change or a comprehensive two-year inspection, planning ahead can make all the difference. Make sure to book your next visit at a trusted auto body shop in Los Angeles for optimal results. Schedule your service in advance, consider bundling in smart performance upgrades, and hit the road with enhanced confidence. For a bold style and superior performance, explore premium Giovanna wheels to elevate your driving experience.
