7 Mistakes New Pickup Truck Drivers Make (and How Drivers Ed Can Help Avoid Them)
the financial impact of buying a truck and what you need to know
Whether you are using a pickup truck for work or just to enjoy the ride, it can be a lot of fun. But if you’re new to driving one, it’s easy to screw up, and that’s because pickup trucks handle differently than regular passenger cars. Luckily, drivers education (drivers ed) can prevent some of these common problems. Here are seven mistakes new pickup truck drivers often make and how drivers ed can help prevent them.
1. Not Adjusting to the Size of the Truck
New drivers often find it hard to park, turn, or drive through small places with pickup trucks because they fail to remember that they are larger and bulkier than other cars, a fact that could result in accidents or minor damages.
How Drivers Ed Helps: With resources like NextDoorDriving.com, you’ll learn about the size and dimensions of the truck and how to adjust your driving accordingly. You can also get practice parking, making turns, and maneuvering in tight spots, which helps you become more aware of the space around you.
2. Overloading the Truck Bed
Although pickup trucks are designed to carry heavy loads, inexperienced drivers may be unaware of their weight capacities. Driving problems like poor handling, longer stopping distances, and mechanical damages may occur when the truck bed is overloaded.
How Drivers Ed Helps: Drivers ed teaches you about weight limits and how to load your truck properly. You’ll learn the importance of balancing the load in the truck bed so the vehicle stays stable and performs safely.
3. Ignoring the Impact of Towing
Pickup trucks are commonly used for towing, yet many new drivers don’t accommodate their driving accordingly when pulling a trailer or heavy load. That can result in it swaying, hard to put a brake on, or losing control of the truck.
How Drivers Ed Helps: Drivers ed teaches about safe towing practices, how to hitch up a trailer properly, check the load and be more cautious when towing a load. It’s also where you’ll learn how to modulate your speed, keep a safe distance between your truck and other vehicles on the road, and take turns slowly in order to stabilize your vehicle.
4. Driving Too Fast
Pickup trucks may seem like they’re designed for speed, but they are easier to tip over at higher speeds, especially around curves or in bad weather, because they have a higher center of gravity.
How Drivers Ed Helps: In drivers ed, you’ll learn about how truck handling differs from regular cars and the risks of speeding. You’ll get tips on driving at safe speeds, especially in rain, snow, or windy conditions, to keep the truck steady and avoid accidents.
5. Skipping Regular Maintenance
Failure of new pickup truck owners to carry out basic maintenance such as checking tire pressure, changing oil, or monitoring brake pads may result in breakdowns or create risk on the road.
How Drivers Ed Helps: Drivers ed often includes basic car care tips, teaching drivers how to perform basic checks on their vehicle. You’ll learn to inspect things like tire pressure, engine fluids, and the importance of keeping the truck in good working condition to avoid breakdowns or accidents.
6. Not Being Prepared for Off-Roading
Although pickup trucks are ideal for off-roading, driving them on such terrains, especially if you are not used to it, can lead to mistakes that may either cause harm to the truck itself or put you in a tough situation.
How Drivers Ed Helps: While many driver education classes concentrate on driving along the normal roads, a few of them teach how to drive off-road. You can learn how to drive on other different surfaces that are not even, how to use four-wheel drive, and stay in control when driving on gravel, mud, or steep hills.
7. Not Paying Attention to Blind Spots
Pickup trucks have bigger blind spots compared to smaller cars, especially when changing lanes or backing up. New drivers might not be aware of these blind spots and end up making unsafe lane changes.
How Drivers Ed Helps: In drivers ed, you’ll learn how to properly adjust your mirrors, use backup cameras, and always check blind spots before changing lanes or backing up. These techniques help prevent accidents and make sure you’re aware of everything around you.
Summary
Pickup truck driving is a little different compared to driving a car, and mistakes are inevitable at first, especially when you are a beginner. The good news is that many errors out there can be prevented via drivers education that gets these drivers acclimated with how to change their driving style, how to load the truck correctly, and how to care for the vehicle. With a little training and practice, you’ll be ready to hit the road, safely and confidently.
