Legal Implications of Windshield Obstructions: What Pickup Truck Owners Should Know
Maintaining a clear windshield is about more than safety—it’s a legal requirement. The DOT (U.S. Department of Transportation) has established rules or windshield laws under 49 CFR §393.60 to regulate windshield obstructions for all vehicles, including pickup trucks. Ignoring these rules can lead to penalties, safety hazards, and costly repairs. Here’s what you need to know.
DOT Rules on Windshield Obstructions
The U.S. Department of Transportation (DOT) rules aim to make the road safer for everyone. They regulate how accessories are mounted, where safety technologies can be placed, and how much tinting is allowed.
Prohibitions Surrounding Obstructed Windshields
Mounting devices, such as antennas and GPS units, must be positioned:
  • No more than 6 inches below the upper edge of the windshield.
  • Outside areas are swept by the windshield wipers.
  • Away from the driver’s view of road signs and signals.
Exceptions for Safety Systems
Certain safety devices are allowed in specific areas:
  • Lane departure warning systems can be installed within 8.5 inches from the upper edge or 7 inches from the lower edge of the wiper-swept area.
Tinting Restrictions
Windshield tinting must allow at least 70% of light to pass through in regulated areas. Excessive tinting reduces visibility and violates federal standards.
Legal and Financial Risks
Failing to follow windshield rules can lead to:
  • Fines and Violations: These vary by state and range from a few hundred to thousands of dollars.
  • Out-of-Service Orders: Commercial vehicles may be grounded until violations are fixed.
  • Increased Liability: Drivers may face lawsuits or be denied insurance claims if obstructions contribute to an accident.
Addressing issues promptly avoids these consequences and keeps your vehicle roadworthy.
Common Windshield Issues and Solutions
Every driver faces windshield challenges at some point. Whether it’s cracks, dirt, or accessories, small problems can lead to larger consequences if ignored.
Common Issues and How to Handle Them
Issue
Impact
Solution
Cracks and ChipsSpread over time, obstructing visibility and weakening the windshield.Repair small cracks early; replace them if necessary.
Improperly Mounted DevicesBlock the driver’s view and violate DOT regulations.Mount devices in permitted areas, as outlined in the rules.
Excessive TintingReduces visibility and may result in fines.Use a tint that allows at least 70% light transmittance.
Dirt, Ice, and SnowObstructs visibility and can lead to accidents.Clean and defrost your windshield regularly.
Being proactive about these issues not only aligns with the windshield law but also reduces risks, avoids fines, and promotes safer driving.
Is A Cracked Windshield A DOT Violation?
Yes, a cracked windshield can be a violation of the DOT regulations, specifically under the Federal Motor Carrier Safety Administration (FMCSA) rules. The following are DOT’s regulations on windshield cracks:
  • Permissible Damage:
    • A single crack not intersected by any other cracks is allowed.
    • An affected area that fits within a 19 mm (3/4 inch) diameter disc is acceptable, as long as it is at least 76 mm (3 inches) away from any other similar area.
  • Prohibited Damage:
    • Any intersecting cracks are not permitted.
    • Cracks or chips exceeding 3/4 inch in diameter are prohibited if they fall within the driver’s direct line of sight.
These regulations ensure that any damage does not obstruct the driver’s view, maintaining safety standards. For more detailed information, you can refer to the FMCSA’s official guidelines.
Steps for Staying Compliant
Staying compliant with DOT windshield regulations is manageable with consistent practices. These steps will help you avoid violations and keep your vehicle safe.
1. Regular Windshield Inspections
Inspect your windshield often to spot cracks, chips, or devices that block your view. Focus on the driver’s field of vision and the areas swept by the wipers. If you’re unsure about the condition of your windshield, reach out to a service specializing in expert auto glass repair for trucks to assess the issue.
2. Address Problems Quickly
Cracks and chips can grow over time, especially with temperature changes or regular driving. Repairing small issues early can save you from more expensive replacements. If a replacement is needed, use DOT-approved glass that meets safety standards.
3. Know the Rules
Federal DOT regulations apply everywhere, but states may have additional rules. Some states have stricter laws on tinting or accessory placement. If you drive across state lines, research the regulations to stay compliant.
4. Position Accessories Correctly
Devices like GPS units and dashcams should be mounted in approved areas. Avoid placing them where they block your view or interfere with wipers. Check your vehicle manual for proper placement, or ask an expert if needed.
These steps reduce risks and help you follow the law. Professional services offering auto glass repair services can provide reliable solutions to maintain your windshield and visibility.
Why Compliance Matters
A clear windshield improves your reaction time on the road, prevents accidents, and keeps you and others safe. For commercial drivers, compliance also avoids downtime caused by inspections or out-of-service orders. Whether it’s your personal pickup or a commercial fleet vehicle, addressing windshield issues is simple and beneficial.
Ignoring windshield obstructions can result in serious legal and safety issues. DOT regulations and windshield laws offer clear guidance on managing cracks, accessories, and tinting to ensure compliance and safety. Addressing these issues promptly helps you avoid violations, minimize risks, and drive with confidence.
Stay informed and take action—explore expert tips and resources for safer driving at Pickup Truck Talk.
Continue reading
