Trucks are integral part of our economy. It often goes on long travels that lasts for days. It may be through remote areas where there is low network reception. Sometimes the drivers have to pass through cities that doesn’t speak his language. Truck drivers’ life is exciting and also possess threats and dangers from the roads. GPS Trackers can help to make it more secure. Let’s Explore how.
The dangers on the roads
Truck drivers have a lot to share on this topic. Each trip brings in new experience and lessons. From the security perspective truck may require service assistance on the road and if it is a low network coverage area it would be hard for the driver to get a solution. Another situation would be if the truck driver requires immediate assistance due an accident. The accidents may be on the road with other vehicles or natural calamities like storm or land slide. In both cases the driver would require immediate assistance from his team.
Thieves and vandalism are also on list. Since the driver is far away from home thieves try to loot the driver’s cabin or even the loaded items. While on the long trip, at the end of the day if the driver chooses an unsafe area, it is possible for vandalism and theft.
How GPS trackers can help Truck drivers
GPS trackers once installed in the trucks gives us an many useful alerts and information to fight against the dangers on the roads as explained above. The live tracking feature on GPS trackers gives precise location data at any time. One has to be careful to use GPS trackers that have global coverage in these purposes. Otherwise, it will not provide location updates if it goes through international borders.
Geo-fencing alert is useful in all scenarios where the truck is parked. Even if it is for loading the goods or the driver is taking a nap inside the cabin the geo fence alert immediately alerts you if your truck moves out of an area marked by you. This can be set up in the tracking application provided with the device.
Ignition alert as the name explains, give the alert when the truck is started without your knowledge. Some driver often has the tendency to leave the keys on the truck for short visit to the convenience store or to use the lavatory. This is a perfect window for thieves or opportunists to try their luck to get away with the truck. Once the ignition alert is enabled, even if the driver forgets about the key from the truck the tracker will alert him if someone try to start the engine.
When it comes to the fleet managers, it is quite challenging to keep track of different shipments on the road. GPS trackers make it easy and provides additional help to optimize the route. Once all the vehicles installed with trackers, The fleet managers can use single application on their PC or mobile to see the current location and routes real time. Along with this they can also see additional info such as how much speed are the trucks are moving, stop points and time taken for each stop points and last by not least dashboards comparing different parameters of the journey.
How to choose the right GPS Tracker for your Truck
GPS trackers with Global coverage and 4G or above network connection would be a good fit for trucks. Since The truck get through different weather conditions, waterproof and resistance to high heats would also be a good criterion. Another important criterion would be user friendly application that have access from PC, mobiles and tablet. This ensures that you can login from any device of your choice. As always choose brands that provide good customer supports and good reviews.
