Red Flags to Look Out For When Buying a Second-Hand SUV in 2025
mountains 7405696 1280
An SUV is an excellent car choice for those who want to enjoy a spacious and versatile vehicle. Buying a second-hand one can be a great way to save money and still get what you want. However, the used car market comes with its risks. Identifying red flags before committing to a purchase can save you from costly repairs and long-term headaches.
Understanding what to look for when buying a used SUV is crucial to ensuring you get a reliable vehicle that meets your needs. While some issues may be minor and easily fixed, others can signal significant problems that could cost thousands to repair. Knowing the common pitfalls and leveraging modern resources will help confidently navigate the buying process and avoid SUVs that are more trouble than they are worth.
Altered Mileage
Mileage manipulation will remain a concern in the used car market, even in 2025. Rolling back odometers to make a vehicle appear less used can mislead buyers into paying more than the SUV is worth.
Using a mileage checker is an effective way to verify the vehicle’s odometer reading. This tool compares the reported mileage with historical data and makes it easier to identify discrepancies. If the numbers do not match up or seem unusually low for a car’s age, it is a major red flag that warrants further investigation.
Poor Maintenance Signs
1. Exterior and Interior Condition
Look for signs of poor upkeep, such as dirty oil, worn tires, or a neglected interior. A messy cabin, stained upholstery, or a cracked dashboard could indicate that the owner was not diligent about routine care, which can potentially lead to other mechanical or structural issues.
2. Brake and Suspension Health
The condition of the brakes and suspension is especially important for SUVs, which are often used on rugged terrain. During an inspection, pay close attention to these components. If you notice vibrations, squeaking sounds, or uneven tire wear, it could be a sign of neglected maintenance or deeper mechanical problems that compromise safety and handling.
3. Problematic Test Drive
Feel for any unusual vibrations, and listen for odd noises like clunks or squeals when driving over bumps or making sharp turns. These signs may point to wear and tear on essential components, such as the suspension or steering system, that require immediate attention or costly repairs.
Vehicle History
The history of a used SUV tells a story about how it has been maintained and used. A clean one typically indicates that the previous owner cared for the vehicle, while a history filled with accidents or frequent repairs raises concerns.
Request a history report to uncover details such as past accidents, recalls, and major repairs. Look out for gaps in service records, as they could suggest periods of neglect. Always double-check any claims made by the seller against the report to ensure accuracy.
beijing automotive 2486704 1280
Hidden Damage
Cosmetic repairs can mask more serious structural damage. While a fresh coat of paint or shiny exterior may look appealing, it could be covering up the aftermath of a major collision. Use a flashlight to inspect seams and edges for uneven paint or poorly aligned panels, which may indicate past repairs.
Also, check the undercarriage for rust or corrosion. These issues can weaken the vehicle’s structural integrity over time. Pay close attention to areas around the wheel wells, exhaust system, and frame, as these are common spots for rust to develop.
Common Red Flags in Used SUVs
IssueWhat to Look ForWhy It Matters
Transmission problemsDelayed shifting or grinding noisesCan lead to costly repairs
Oil leaksPuddles or stains under the vehicleSign of engine or gasket issues
Electrical faultsMalfunctioning lights or power windowsMay indicate wiring or battery issues
Suspension wearUneven tire wear or poor handlingAffects safety and ride quality
Tire conditionWorn or mismatched tiresMay need immediate replacement
Buying a second-hand SUV can be a great experience if you know what to look for. Take the time to identify red flags to find a reliable SUV that suits your needs and lasts for years to come. Being proactive and informed makes all the difference in the buying process.
