4 Commonly Overlooked Vehicle Maintenance Services You Should Take Serious
pexels olly 3807329 copy
While we’ve all probably sworn at one time to keep our vehicles in constant perfect shape, life happens, and we fall short of this promise. We overlook some service demands more than others and only attend to them when something fails. Whether it’s something as simple as flushing the coolant system or as demanding as changing the oil, we’ll look at the top four services you must not overlook.
Flushing the Coolant System
More often than not, a failed coolant system can lead to almost half of your car’s engine problems. If your cooling system has gone untouched for years, it’s time to have it checked and flushed as soon as possible.
Sludge and slime that form in the system can cause several problems, such as clogging the radiator, fluid passages, or heater core. All these could result in overheating and associated expensive repairs.
Additionally, your metal engine and cooling system components are at risk of failure once the anti-corrosion additives are depleted. You can avoid all these problems by regularly flushing your coolant system and refilling it with high-quality anti-freeze organic coolant.
Checking and Changing Your Needle Bearings
Your car’s needle bearings are crucial in supporting high loads in compact spaces. When inspecting the bearing, you might want to check the condition, amount of lubricant, and bearing size and bore to ensure they’re in perfect working condition.
Your car’s wheel bearings will most likely fail if exposed to corrosive chemicals, wet environments, or lubricated with low-quality grease. Your vehicle can also help you determine when there’s a problem with some of the bearings. The most common signs of a bad wheel bearing include:
  • Increasing heat
  • Uneven tire wear
  • Unstable steering
  • Car looseness
  • Steering wheel pulling
Replacing Cabin Air Filters
You’ll probably not think of your cabin air filters until your driving gets uncomfortable. Cabin air filters are responsible for the comfortable, dust- and pollen-free air you breathe when driving. They filter out the dust that can be picked up by your ventilation system, alleviating allergy symptoms and improving your driving comfort.
However, as time passes, these air filters will need to be replaced to ensure a continual supply of good-quality air. If you drive every so often, you might have to change them more regularly. However, if you drive fewer miles daily, you can have them replaced only once every two years.
Inspecting the Brake System
Your car’s braking system is one of its most crucial safety features. Regular inspection is needed to ensure steady, reliable performance throughout the year. When your brake fluid, pads, or rotors go past their replacement dates, they significantly compromise your brake’s optimal performance.
You need to check the entire system more often, especially if your breaking distance has increased in recent driving days. While having your brakes checked only during your scheduled maintenance is efficient, regular inspections can help you catch potential issues early and keep your vehicle safe.
Taking good care of your car can be demanding, especially if you have to observe every little thing that matters. However, ensuring every part of your car functions perfectly is crucial for your car’s best performance and safety on the road. Whether you’ve often overlooked flushing your coolant system or inspecting the brakes, these tips should help you enjoy your car’s best performance in a long while.
