The dangers of overloaded trucks
the dangers of overloaded trucks 2
Overloaded trucks are a major hazard as they pose a significant safety risk to all drivers on the road. Trucks that exceed their weight limit can have significant consequences and dangerous repercussions, including mechanical failures and serious collisions. In this article, we will explore some of the dangers associated with overloaded trucks.
Longer stopping distances
One of the most significant dangers of overloaded trucks is the increased stopping distance that is required as a result. As is, trucks have a longer than average stopping distance given their weight and size. However, when trucks are overloaded, the force required to bring them to a stop increases drastically, making it even more difficult to slow down or stop in time to avoid collisions. This becomes particularly dangerous in emergency situations where quick reactions are necessary to prevent a serious crash from occurring. Additionally, poor weather conditions, such as rain or ice, can make it even more difficult to come to a safe stop.
Added stress on brakes
A truck that is overloaded can put excessive stress on its brake system. Brakes are designed to handle a specific load, and when that weight limit is surpassed, the brakes must work much harder to slow down or come to a stop. This added stress on the brakes can result in brake failure, which is one of the most dangerous mechanical failures a truck can experience.
Difficulty with control
Not only are overloaded trucks tough on the brakes, but they can also be more difficult to control. Since trucks’ steering and suspension systems are designed for specific weight loads, when this load is exceeded, these systems can become strained, resulting in far less control over the vehicle. As a result, the truck is at risk of swerving, tipping over, or jackknifing, especially in high winds, sharp turns, or sudden maneuvers.
Bursting tires
Tires are another part of the truck that suffers greatly from overloading. Each tire has a specific load rating, and exceeding that rating can cause excessive wear and tear. Unfortunately, this added pressure placed upon the tires can result in tire overheating, tread separation, and even tire blowouts. When a truck experiences a tire blowout, it is likely that the truck driver will lose control of the vehicle and cause the truck to swerve or crash. It is important that truck drivers regularly maintain their tires and check them before driving.
Increased risk of crashes
The combination of all of the aforementioned dangers of overloaded trucks makes overloaded trucks significantly more likely to be involved in an crash. These crashes are often more severe than the average motor vehicle crash given the weight and size of the truck, resulting in serious injuries and even fatalities. Overloaded trucks are also more likely to cause multi-vehicle crashes, especially on busy highways or in poor weather conditions. If you have been injured in an crash involving an overloaded truck, it is important that you speak to an Olympia truck accident lawyer who can guide you through the legal process of filing a personal injury claim. Truck crashes are far more complex than the average motor vehicle crash as there are a number of different parties who may be held liable for the crash. Consult with a lawyer before filing a claim in order to ensure that your rights are protected and that you recover maximum compensation.
