Budgeting for a new vehicle can prove to be impossible for most potential owners. Fortunately, opting for a used option allows you to own a vehicle at a fraction of the cost. However, finding a reliable used truck requires that you proceed with caution.
Since many pickup truck owners tend to use their vehicles as tools for heavy lifting and grunt labor, wear and tear in trucks tends to be more extensive than with passenger cars. Fortunately, the option of buying a car online gives prospective owners access to multiple tools not found on a sales floor. Nonetheless, you should still watch out for the following red flags before making that purchase.
Extensive wear and tear
As mentioned, pickup owners mostly use them for heavy-duty tasks, like towing and hauling cargo. As such, you shouldn’t be surprised if you come across extensive wear and tear on a used truck. However, you should use this wear and tear as a way to gather insight into the overall condition and how well the vehicle has been maintained by the previous owner.
You should specifically pay close attention to interior and exterior wear. For the interior, check the condition of the truck’s controls, switches, seats, and upholstery. The presence of dents or scratches and the paint condition tell it all from the outside. Notable damage from the truck’s paint job affects its appearance and precedes rust and corrosion.
You should also inspect tire and suspension conditions. Uneven wear on the tire is a sign of alignment or suspension issues, while mismatched tire brands suggest neglect or poor maintenance.
Inconsistent mileage
Inconsistent mileage on the truck is a big red flag that shouldn’t be ignored. This is typically a sign of multiple issues, including mechanical problems or odometer tampering. Fortunately, identifying inconsistent mileage in the truck isn’t difficult. Start by checking the maintenance records, as this allows you to verify consistent mileage readings over a given period.
You should also ask for the vehicle’s history report. A comprehensive vehicle history report often includes odometer readings from various service centers. If the vehicle has multiple previous owners, consider reaching out to them for such information. You can also schedule a professional inspection. A qualified mechanic will thoroughly assess the vehicle and provide an accurate description of the vehicle’s general health and why that odometer reading is off.
Unusual engine and transmission sounds
Unusual engine and transmission sounds are another common red flag to watch out for when buying a used truck. Like in other vehicles, you should pay close attention to the sounds emanating from the engine and/or transmission during a test drive, as they may indicate any mechanical miscues. You should never ignore unusual automotive sounds as they are clear indicators of mechanical issues.
Unusual engine or transmission sounds may include:
- Rattling and clattering sounds when accelerating or decelerating point to issues in the engine’s timing belt. Lose components or exhaust problems also produce this noise.
- Knocking or pinging sounds from the engine indicates a problem with the combustion process.
- Whining or humming, especially during turns, suggests a variety of problems, including transmission, wheel and hub, and differential concerns. This may lead to poor handling and significant drivetrain issues over time.
Endnote
Buying a used truck means walking a tightrope between saving money by avoiding the significant depreciation that follows a new truck purchase, and purchasing a lemon that will cost more to repair over time. So shop cautiously for that used truck, ignore any truck related myths, and watch out for the red flags mentioned above.
