Ford F-150 recall: 100k+ trucks for loose rear axle hub bolt
Ford F-150 Recall
2024 ford f 150 stx 04
Ford Motor Company (Ford) is recalling certain 2021-2023 F-150 vehicles equipped with the Trailer Tow Max Duty package and a 9.75-inch heavy duty axle with a 3/4 float axle design. The rear axle hub bolt may fatigue and break, which can result in damage to the axle hub splines.
Damaged axle hub splines can result in a vehicle roll away when the vehicle is in park without the parking brake applied, or cause a loss of drive power. Both of these conditions can increase the risk of a crash.
If you own a 2021-2023 Ford F-150 be sure to consult the NHTSA recalls portion of the website and type in the specific VIN of your truck to see if this current recall applies to your vehicle.
The remedy is currently under development. Owners will be instructed to take their vehicle to a dealer for an interim repair if they experience symptoms related to rear axle bolt breakage, such as a clicking or rattling noise. Owner notification letters are expected to be mailed January 29, 2024. Owners may contact Ford customer service at 1-866-436-7332. Ford’s number for this recall is 23S65.
Ford F-150 recall information:
NHTSA Campaign Number: 23V896000
Manufacturer Ford Motor Company
Components POWER TRAIN
Potential Number of Units Affected 112,965
Editor’s note: This information was copied directly from the NHTSA website. If you have questions or concerns about this Ford recall, please contact Ford Motor Co. directly.
