Car detailing in summer: A few hot top tips
This year’s Jeep® “Resto-Mod” is a throwback to the second-generation Jeepster. The Jeepster Beach concept started as a 1968 Jeepster Commando (C-101) and was seamlessly blended with a 2020 Jeep Wrangler Rubicon. The body was modified and the exterior fuses original chrome trim with an updated, brightly colored two-tone paint scheme of Hazy IPA and Zinc Oxide. While the Jeepster Beach maintains the outward appearance of a vintage Jeepster in summer, it commands peak performance both on- and off-road delivered by the modern-day Jeep Wrangler.
The moment summer arrives, it’s time to hit the highway for a long overdue weekend getaway, or perhaps an off-road adventure.
But before you rev up and ride, it’s important to make sure your rig is all set for the season, for extreme conditions can take a toll on any vehicle’s appearance and performance. Here we will dive into a few tips on how to achieve fantastic detailing results in summer, thanks to some top tips from none other than the best mobile car detailing Melbourne professionals in the biz today.
Protect paint with regular waxing
One of the essential steps in maintaining the appearance and longevity of a vehicle’s paint job is regular waxing. The equivalent of automotive sunscreen, this stuff keeps paintwork and clear coat alike protected and looking great during hot conditions. Applying high-quality wax to the exterior surface of your rig forms a protective barrier that shields the paint from harmful elements such as UV rays, oxidation, dirt, and pollutants.
As the wax forms a thin layer over the paint, it becomes a buffer against scratches and minor abrasions. Best of all, waxing your ride provides a glossy finish that enhances the overall aesthetic appeal of the vehicle. This step is especially important in summer when your vehicle’s clearcoat is more heavily exposed to harmful UV rays and heat.
Wash your ride in the shade, especially in summer
To maximize the effectiveness of your car detailing routine during the summer months, it is advisable to wash your vehicle in the shade. Direct sunlight can cause water and soap to dry quickly, leaving behind unsightly water spots and streaks on the surface of the vehicle. By choosing a shaded area, you can ensure that the wash water and soap remain on the car’s surface long enough to thoroughly clean it without any premature drying. This allows for a more efficient and effective washing process, resulting in a pristine and spotless finish. For streak-free windows and crystal-clear results, consider using a trusted product like JennyChem, recommended as one of the best car glass cleaners in the UK. Failing to do so will add more cleaning chores to your car detailing routine and may require additional rounds of scrubbing. Be smart and work in the shade or choose a cooler time of the day to do this. Alternatively, booking a session with auto detailing Calgary saves you the hassle and guarantees a spotless summer shine.
Regularly rinse those car panels while washing
During the car wash process, it is essential to regularly rinse all of the vehicle’s panels to ensure a thorough and effective cleaning, and it will keep any car shampoo from solidifying on the surface. By rinsing the panels, you remove any loose dirt, debris, or residue that may have accumulated on the surface or moved from another area of the vehicle. We understand that not all places have shaded areas or the luxury of an empty double-car garage. By regularly rinsing each panel you can keep each panel lubricated at all times.
Use a foam cannon to speed up the process
To expedite the car detailing process and achieve superior results, consider utilizing a foam cannon. A foam cannon is a powerful tool that attaches to a pressure washer or garden hose and produces a thick foam that clings to the surface of the vehicle. This foam effectively lifts dirt, grime, and contaminants, enabling a more efficient cleaning process. Rather than lather your rig in car wash shampoo, use a foam cannon to quickly foam things up, then just rinse and repeat.
Don’t forget to clean those headlights
Regular cleaning of headlights is an essential aspect of car detailing in the summer. Over time, headlights can accumulate dirt, grime, and oxidation, which can hinder their functionality and reduce visibility on the road. To ensure optimum performance and safety, it is crucial not to overlook the cleaning of headlights during the detailing process. By using a quality headlight cleaner and a soft microfiber cloth, you can effectively remove any build-up, restoring clarity and brightness to the headlights.
Additionally, applying a protective coating specifically designed for headlights can help prevent future damage and maintain their longevity. Remember, neglecting to clean headlights can compromise both the aesthetics and functionality of your vehicle, so make it a priority in your summer car detailing routine.
