Best gear storage solutions for 2021-2023 Ford Bronco owners
Just when you thought the all-new Ford Bronco couldn’t get any more awesome, along comes a fresh set of aftermarket products to take the off-road-ready SUV up a notch.
Cortez, Colorado based automotive storage and safety solutions specialist, Tuffy Security Products, has long had its finger on the pulse of what 4×4 enthusiasts and SUV drivers want and need. And now it has released an entire line of secure storage options for the 2021-2023 Ford Bronco.
Everything from a Center Console Safe and a trunk lockbox for 2-door models, to a fold-down tailgate table and a cargo drawer are now available from Tuffy. There is also an entire range of locking steel deck enclosure units up for grabs, all of which offer awesome aesthetics and security measures.
Here are a few details on what makes these custom designed heavy-duty storage solutions ideal for the reinvented Bronco…
385 Ford Bronco Console Safe Side Open View
Let’s be up front, security matters
Starting things off is Tuffy’s iconic Console Safe for the Ford Bronco. Built to conceal valuables from prying eyes while keeping them protected, yet still easily accessible, this welded steel lockbox sports a double bitted cam lock, and is designed to slide straight into the center console storage for effortless installation.
Designed with stealthy OE styling in mind, this console safe is the ultimate quick storage solution, and comes complete with Tuffy’s patented “Pry-Guard II” locking system. A steel latch setup that allows the lid to be latched closed without the need for locking every time.
Get your Bronco gear in the rear
Moving toward the back of the Bronco, you will discover that Tuffy has devised a Tailgate Table that can be affixed to the inside of the Bronco tailgate. This fold-out table holds up to 40 pounds, and comes machined with a MOLLE grid for strapping gear in. Keeping with the OE lines, this table mounts directly to the bronco’s existing tailgate rail mounts, and can be easily installed with basic hand tools.
Ford Bronco four-door owners also get the added benefit of being offered a Cargo Drawer. This solid steel slider unit attaches to the OEM mounting points behind the rear seat, and comes standard with Tuffy’s signature locking technology for additional protection and peace of mind.
Tuffy Bronco Security Box
Then there is Tuffy’s Security Trunk Lockbox. This hardcore gear holder is built to be mounted to the cargo floor of the Bronco, providing more than 3.5 cubic feet of lockable storage space once installed. Supported by gas lifts, the lockbox lid of this trunk can also be latched closed without being locked, making access a cinch, regardless as to whether you are out running errands or back at the campsite.
“These useful accessory products for the Ford Bronco help vehicle owners meet a variety of secure storage needs. Their innovative design, superior construction and exclusive locking system make them valuable additions to Broncos used for work and play.” —Chip Olson, marketing manager for Tuffy Security Products
Tuffy Standard 4 door Bronco deck enclosure
Cargo coverage you can count on
Tuffy’s line of rear enclosures includes the Deluxe Deck Enclosure, a 4-door model Bronco Deck Enclosure and a Deck Enclosure for 2-door versions of the Ford SUV.
The company’s Deluxe Deck Enclosure utilizes a lid that secures shut. Relying upon the Bronco’s locking tailgate, Tuffy’s patented security system works in tandem with the rear door to create a whopping 24 cubic feet of lockable rear storage space. With a lid that hinges open, and then held safely in place by sturdy gas struts, both the locking lid and the removable vertical front and side panels are able to be quickly deleted when more cargo hold room is required. This can all be done without the need for tools too, making this setup one of the slicker new Bronco products on the market today.
As for Tuffy’s Deck Enclosure for 4-door Bronco models, that also works in conjunction with the vehicle’s locking tailgate system. Securing shut when the rear door is locked, this unit offers 22 cubic feet of lockable storage space and comes with a MOLLE grid layout for increased ventilation and an infinite number of gear attachment options. Four D-ring tie-downs come standard on top of the lid for securing extra cargo as needed.
Tuffy 2 door Bronco deck enclosure
Naturally, Tuffy’s 2-door Bronco Deck Enclosure is the smallest of the lot, but it still manages to pack in some impressive perks. With a full 12.5 cubic feet of lockable storage space, and both front and side panels sporting that signature MOLLE grid, securing stuff has never looked or performed better. Like Tuffy’s other deck enclosure units, the lid on this smaller cargo hold cage relies upon the vehicle’s locking tailgate to function. And as with all of Tuffy’s Deck Enclosures, zero drilling is required with this kit, with its included mounting hardware merely requiring the use of standard hand tools for installation.
The Tuffy advantage explained
Regardless of whether you are the proud new owner of a brand-new Ford Bronco, or drive a classic, pretty much every storage product bearing Tuffy Security Products badging has you and your goods protected. That is because Tuffy’s engineers and designers prioritize the blending of OE styling with superior-grade welded steel and a rugged powder coat finish over flashy marketing gimmicks.
Furthermore, Tuffy’s patented locking systems sport all-steel components and a 10-tumbler, double-bitted security lock with built-in weather seals. This not only provides unparalleled durability but a level of security that only Tuffy Security Products can provide.
Tuffy Hook and Loop Ford Bronco Straps
Oh, and let’s not forget Tuffy’s Ford Bronco branded hook and loop closures. Officially licensed by Ford, these Bronco-branded hook and loop closure straps help keep the small stuff tied down when the trail gets bumpy, or if a sudden stop on the interstate occurs. Each kit includes three 8-inch and three 12-inch Bronco branded straps, and is proof that sometimes it is the little things in life that matter most.
