Amazon Black Friday 2022 truck and SUV gear buying guide
Christmas background. Pickup with christmas tree and gifts. Merry Christmas and Happy New Year
Looking to get yourself a little something this Black Friday, but not interested in fearing for your life at a local shopping center? Amazon Early Black Friday Deals are already ramping up, and truck and SUV owners are in for some massive deals.
From camping and overlanding 4×4 gear to towing accessories and truck bed attachments, the following dozen Amazon picks are sure to impress — and we hope they’ll be a part of any Amazon Black Friday deals. Many of these we use routinely (if not daily) on our own vehicles, and have received the PUTT stamp of approval. So, let’s get shopping, shall we?
1. SEAAES 35-inch extendable ice scraper and snow brush
Is your ice scraper/snow brush entirely too wimpy? Does clearing winter’s wrath from your rig cause you to strain and swear in frustration? Then it might be time for an extendable snow brush, and after years of testing, we’ve discovered the SEAAES 35-inch extendable ice scraper and snow brush is easily the best of the bunch. Here are a few reasons why you’ll want to get your own on Amazon as well…
  • Massive Brush Head — At 11.8-inches, this enormous brush head removes more snow in fewer sweeps.
  • Paint Safe — Specially designed, ultra-dense bristles with soft tips prevent scratching and swirling.
  • Ice Removal Expert — High-strength ABS scraper side removes thick ice easily and resists cracking and chipping.
  • Aviation-Grade Aluminum Alloy Construction — Telescoping from 22.8 inches to 35 inches, this strong yet light shaft makes clearing the roof of a lifted rig a snap.
  • Reinforced 270-degree Pivoting Head — The reinforced brush head can rotate a full 270° to remove snow from a slew of different angles.
2. Geiserailie portable camping coffee pot and kettle
Regardless of whether you are overlanding, camping or just tailgating, having a kettle nearby is never a bad idea. This clever, fully collapsible Geiserailie kettle is one of the best purchases you will ever make on Amazon, as it makes hot beverage prep a snap.
  • 1.5 L extra-large capacity
  • Easy to carry 6.3 x 8.27 x 6.7-inches when spread out, and 6.3 x 8.27 x 2.56-inches when folded
  • No power needed. Just fill the kettle and heat it directly on the cooker.
  • Made of silicone and stainless steel, with temperature tolerances of -40 degrees to 230 degrees C.
3. Prestone bug wash windshield washer fluid
Here at PUTT, we’ve seen more windshield time than most people see in their adult lifespan. Dirty, bug, mud and debris-riddled windshields happen. This is precisely why we have found this “advanced” formula of Prestone bug wash windshield washer fluid works best, especially if it is on sale over at Amazon.
  • Rocks at removing bug residue, road grime, bird droppings, and tree sap from windshields.
  • Specialized “Power Cleaner” solution penetrates the toughest residues, breaking down and removing up to 99.99% of all bug guts. Eeeewwwwww…
  • “Bug Stopper” compounds form a barrier to help stop bugs, road grime, and other residues from sticking to your windshield.
  • “Water Repellent Advanced Beading” technology repels rain and snow for streak-free driving visibility.
  • Creates a streak-free shine with a refreshingly citrusy scent.
4. Bully CR-600 universal hitch step 2-inch receiver
When it comes to kick-ass external bolt-ons, few items come close to this Bully CR-600 universal hitch step. Practical, powerfully constructed, and packaged proportionately, this multi-purpose hitch bolt-on is a must for when towing is not in full effect.
  • 18-inch wide, with a tube diameter of 3-inches, this Bump Step provides easy access to the truck bed, as well as to luggage racks, or the rear cargo area of an SUV.
  • Doubles as a bumper guard/Mansfield Bar during low-impact rear-end collisions.
  • Durable construction means being manufactured from 16-gauge steel, with a non-slip, high-impact rubber step pad for added strength and safety.
  • Universal fit for all standard 2-inch hitch mounts, making it a plug-and-play part.
  • Specifications: the access step measures, with a heavy-duty construction, makes the hitch step perfect for sports trucks and SUVs
5. Exped Megamat 10 insulated self-inflating sleeping pad
Whether you may be into rooftop camping, sleeping in the bed of your pickup truck or snoozing on the cold, hard ground, a quality mattress is essential for a good night’s sleep. PUTT’s very own Jill Ciminillo found the Exped Megamat 10 insulated self-inflating sleeping pad to be well worth its asking price during Rebelle Rally 2022. So if it goes on sale during Amazon Black Friday this year be sure to snag it up!
  • 3.9 inches of loft delivers superior rest for the next day’s effort
  • Save your breath after a long day on the trail. The Megamat 10 self-inflates in minutes, with easy firmness adjustment coming via a compact mini pump.
  • Designed for 4 season comfort, the Megamat Duo 10 features Bluesign-certified insulation that keeps you toasty in temperatures down to -54 degrees F.
  • Packing up is a cinch thanks to a height-adjustable roll-top bag and carrying strap. Easily fitting the Megamat, Mini Pump, repair kit, and manuals.
  • Packed size is 22 x 11 diameter.
  • Weighs just 7.5-pounds, and once inflated measures 72 x 41-inches.
6. Nilight light bar & LED pod bracket mounting kit
If you plan on running external lighting on your rig, chances are you’ll need to find someplace to mount everything. If you are not into the idea of drilling into your truck or SUV, then a light mounting bracket kit should be in order. The Nilight light bar & LED pod bracket mounting kit is one of the best of the bunch, and for damn good reason.
  • Made of sturdy 304-grade stainless steel for superior corrosion and rust resistance, strength, and lifelong durability.
  • Freely adjusts 180 degrees up and down and 60 degrees left-to-right for pinpoint lighting and superior articulation.
  • No-drill design. Just clamp and tighten. Each clamp kit comes with anti-slip teeth and rubber padding for a snug, no-scratch installation.
  • Can be used to mount everything from work lights and fog lights to driving lights, LED pods, and much more…
7. Traxion 5-100 tailgate ladder
For as practical as they may be, getting in and out of the bed of a pickup truck can be a royal pain in the posterior sometimes. Get yourself a well-built tailgate ladder, like the Traxion 5-100 on Black Friday at Amazon, and save yourself some agony.
  • Pickup truck tailgate ladder features a total weight capacity of 300-pounds.
  • Easy to install and capable of being deployed in seconds.
  • Significantly reduces the body strain when getting in and out of the bed of the truck.
  • Secures neatly against the tailgate and tucks out of the way when not in use.
8. DEE ZEE truck tailgate assist
While we’re on the topic of the dangers of truck tailgates. Perhaps it might be time to talk a little bit about the dangers of them opening so suddenly. If your pickup doesn’t come with an assist damper don’t worry, the DEE ZEE truck tailgate assist will allow you to gently (and safely) open that tailgate.
  • Safely controls the drop rate of truck tailgates.
  • Custom-designed for each make and model.
  • Extensively tested for heavy-duty use and abuse.
  • Works in conjunction with factory cables.
  • Only one tailgate assist required per vehicle.
9. Bull Ring classic raised fit retractable tie-down anchors
Tie-down anchors. They’re incredibly useful to have… until they get in the way. Get yourself some Bull Ring tie-down anchors on Black Friday this year, and keep that gear under control, and your hooks out of the way.
  • Fully retractable snap-up, snap-down design.
  • Fits both S-Hooks and ratchet straps.
  • Perfect for camping, moving and hauling.
  • Quick, easy install does not require the use of special tools, drilling, or modifications of any kind.
  • Rated at 1,000-pound maximum capacity.
  • Stainless steel ring and chassis, means no rust, no rattle.
  • Matches color, texture, and UV rating of OEM rail caps.
  • Fitment Guide: ’98-14 Ford F150 | ’98-16 Ford Super Duty | ’88-13 Chevrolet Silverado and GMC Sierra | ’95-08 Dodge RAM
  • Comes with a “No Bull” Lifetime Warranty
10. JoyTutus portable truck bed tent
Remember that super comfy inflatable mattress we recommended earlier? Well, what if we told you that there’s a kick-ass tent option that goes with it. And that this tent option bolts to the bed of most pickup trucks. Oh, and that this particular JoyTutus tent is currently on sale during the Amazon pre-Black Friday Sale? Dare we say, this is so very serendipitous?
  • Made of 150D polyester oxford.
  • PU2000 water-proof coating. Fully rainproof and waterproof, even without the additional rain fly.
  • Bottom of the tent has an additional waterproof layer to avoid rainwater infiltration.
  • Fits most pickup trucks with a 5.5-6-foot bed.
  • Compatible with F150, Ram, Silverado, Tundra, Sierra, Titan, etc.
11. Nilight 4-in-1 charger socket panel outlet and LED voltmeter
In search of ways to toggle those overlanding lights, and useful electronic camp gear from the cab of your rig? This Nilight 4-in-1 toggle switch rocker panel is on sale right now ahead of Black Friday, and it comes packed with customizable options.
  • 4-in-1 DIY design allows you to create your own toggle switch panel, with dual USB sockets, a voltmeter, a 12V outlet, and an ON/OFF toggle switch all coming standard.
  • Easy installation and operation.
  • Fully detachable sockets allow you to pop in different charger sockets, rocker switches, and a slew of other standard-sized electronic units.
  • Real-time LED voltmeter shows accurate voltage levels at all times.
  • Built-in 10A fuse for overload protection and safe charging reduces the risk of overheating.
12. COWVIE universal car latch door step pedal
Tired of having to step on your truck or SUV seats, just to snag something off the roof carrier on your rig? The Cowvie clamp-on stair pedals are on sale right now, and offer the ability to safely and effectively access the roof of your vehicle. A must-have Amazon item here at PUTT that we use regularly!
  • Pedal is 4 to 6 inches higher than competing door pedals, making access to the rooftop much easier. Loading or strapping down large outdoor essentials or sporting equipment will never feel so easy!
  • The design of the hook offers two directional locking positions and three slope levels, offering a secure and flat surface for stability and reliability. The rotatable hexagon bumper fits perfectly in most car door frames and prevents scratching and wear on the vehicle.
  • The wide platform of the pedal offers plenty of stability, enough room for both feet, and can safely hold up to 400-pounds.
  • Simply select the right settings for your vehicle’s door latch via the use of one of three slope levels, and one of two locking positions. Then, simply hook the device onto the latch of your door, with the hexagonal bumper against the door frame.
  • Pedal can be easily folded flat and stowed away when not in use.
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites. Links in this post are part of the affiliate advertising program and we earn a commission on each sale.
