The 2026 model year marks a new, sixth generation for the top-selling Toyota RAV4 sport utility. Most of the known problems for this new vehicle are growing pains issues and some carryovers from the previous generation model.
A few sticking points, such as its hybrid-only powertrain and $3,500 higher price tag due to that are common consumer complaints for this new-gen RAV4. It is, however, a continuation of what’s made this SUV very popular throughout the years.
Backup Camera Freezing
A very large recall campaign by Toyota includes some 2026 RAV4 models. Software glitches can cause the backup camera image to freeze or go blank when the driver shifts into reverse. A software update usually remedies this issue, though some vehicles are requiring head unit replacement.
This problem is covered under warranty and/or recall.
Dead Gauge Clusters and Disconnecting Apps
Early-production 2026 RAV4 models equipped with digital instrument clusters experienced intermittent software failures, resulting in blank or frozen screens upon startup.
Another persistent issue that continues over from the previous-generation RAV4 is Android Auto and Apple CarPlay disconnects. This happens frequently and is an issue with most Toyota models using this latest-generation infotainment interface.
Higher Maintenance Costs
Because the new 2026 RAV4 now requires much more expensive 0W-8 motor oil in its maintenance, oil change intervals and costs have risen considerably. Toyota is eating some of this by including two years of maintenance (via ToyotaCare) with new 2026 RAV4 purchases, but this still increases oil change costs by 30-50 percent.
Even with high mileage driving, the return on investment for the added up-front purchase price plus more costly oil changes over time will not likely be made up for with the higher fuel economy of the 2026 model versus the 2025.
Known Issues That Used To Plague the RAV4
The previous-generation RAV4 had its own share of known issues. The following do not appear to be problems in this new-gen model:
- Parasitic battery drain
- Leaking cooling system
- Transmission hesitation at low speeds
- Safety system false positives
How To Check For Recalls On Your Toyota
The easiest way to check for current recalls that may affect your RAV4 is to visit the National Highway Transportation Safety Administration (NHTSA) Recalls page and enter your license plate or 17-digit vehicle identification number (VIN) to run a search. You can also do this at the Toyota Recalls Lookup page.
