How to Keep Your Pickup Running Like New: The Ultimate Guide
First Drive: New 2017 Ford Super Duty Trucks
Your pickup truck is more than just a vehicle. Whether you use it for work, off-roading, towing, or daily commuting, keeping it running like new is key to its longevity and performance. Unfortunately, many truck owners don’t take care of it. It’s going to start acting up, and before you know it, you’ll be staring at a massive repair bill or, worse, a dead truck.
So, what causes problems in pickup trucks, and how can you prevent them? In this guide, we’ll break down the common issues, their solutions, and how to avoid them altogether. It just takes some common sense, a bit of routine maintenance, and knowing what to look out for. In this guide, I’ll break down the most common things that mess up your truck, how to fix them, and how to make sure they never happen again. If you’re thinking about getting a used truck in UAE, then Arabwheels will be your only possible and easy option.
Common Problems That Cause Your Pickup to Age Prematurely
1. Neglecting Regular Oil Changes
Why It’s a Problem:
Oil is your truck’s lifeblood, lubricating the engine and preventing friction-related wear. Skipping oil changes can lead to sludge buildup, overheating, and engine failure.
The Fix:
  • Change the oil and oil filter every 5,000 to 7,500 miles (or as per manufacturer recommendations).
  • Use high-quality synthetic oil if your truck requires it.
  • If you tow heavy loads or drive in extreme temperatures, consider shorter oil change intervals.
How to Avoid This Issue:
  • Set reminders on your phone for oil changes.
  • Check the oil level once a month and before long trips.
  • Always use the correct oil viscosity recommended in your owner’s manual. If sticking to a maintenance schedule is challenging, scheduling regular oil changes with MAXI Mobile can make it easier to keep your truck in top condition without disrupting your routine.
2. Worn-Out Tires And Improper Tire Maintenance
Why It’s a Problem:
Your truck’s tires are its only contact with the road. Improperly inflated or worn-out tires reduce fuel efficiency, affect handling, and increase the risk of blowouts.
The Fix:
  • Keep tires properly inflated to the manufacturer’s recommended PSI.
  • Rotate your tires every 5,000 to 7,500 miles to ensure even wear.
  • Check the tread depth regularly—replace tires when the tread wears below 2/32 of an inch.
  • Get wheel alignments if you notice uneven wear or your truck pulls to one side.
  • Check tire pressure once a month.
  • Avoid driving on rough terrain without appropriate off-road tires.
  • If you frequently carry heavy loads, ensure you have tires with the correct load rating.
3. Ignoring Fluid Levels
Why It’s a Problem:
Your truck relies on coolant, transmission fluid, brake fluid, and power steering fluid in addition to engine oil. Low or contaminated fluids can lead to overheating, transmission failure, and brake issues.
The Fix:
  • Check coolant levels and replace coolant every 30,000 to 50,000 miles.
  • Inspect transmission fluid regularly; replace it as recommended (usually 30,000 to 60,000 miles).
  • Keep an eye on brake fluid—replace it every two years or if it looks dark.
  • Top up power steering fluid if your steering feels stiff.
  • Check all fluids every month.
  • If you notice leaks under your truck, get them checked immediately.
  • Use only manufacturer-recommended fluids.
4. Weak or Failing Battery
Why It’s a Problem:
A weak battery can leave you stranded. Corrosion on terminals, extreme temperatures, and frequent short trips reduce battery life.
The Fix:
  • Clean battery terminals regularly to prevent corrosion.
  • Test battery voltage with a multimeter; replace it if it reads below 12.4 volts when the engine is off.
  • If your battery is over 3-5 years old, consider replacing it.
  • Drive your truck regularly to keep the battery charged.
  • If you don’t drive often, invest in a trickle charger.
  • Avoid using accessories (lights, radio) when the engine is off.
5. Overlooking Brake Maintenance
Why It’s a Problem:
Faulty brakes are a significant safety hazard. Worn-out brake pads can damage rotors and lead to expensive repairs.
The Fix:
  • Inspect brake pads every 15,000 to 20,000 miles.
  • Replace brake fluid if it looks dark or dirty.
  • Listen for squealing or grinding sounds—these indicate worn pads.
  • Don’t ride the brakes—this causes premature wear.
  • If you tow or haul heavy loads, upgrade to high-performance brake pads.
  • Get your brakes checked annually.
6. Suspension and Steering Problems
Why It’s a Problem:
A bad suspension can make your truck ride rough and reduce control. Worn shocks, struts, or ball joints can also cause uneven tire wear and poor handling.
The Fix:
  • Check for bouncing or nose-diving when braking—these are signs of worn shocks.
  • Replace suspension components as needed (typically every 50,000 miles).
  • Ensure the power steering system has enough fluid.
  • Avoid overloading your truck.
  • Drive cautiously on rough roads.
  • Get your suspension inspected every year.
Now that you know what causes problems, here are the best practices to maintain your truck’s longevity:
1. Follow the Manufacturer’s Maintenance Schedule
Your owner’s manual has the best maintenance schedule tailored for your truck. Follow it religiously.
2. Drive Smoothly
Aggressive driving (hard acceleration and braking) wears out your truck faster. Take it easy on the throttle.
3. Keep It Clean
Washing your truck regularly prevents rust and paint damage. Waxing protects the paint and keeps it looking new.
4. Check for Recalls
Manufacturers issue recalls for safety or reliability issues. Check if your truck has any outstanding recalls and get them fixed for free.
5. Store It Properly
If you’re not using your truck for a while, store it in a garage and disconnect the battery to prevent drain.
Frequently Asked Questions About Pickup Truck Maintenance
1. How often should I change my truck’s oil?
Every 5,000 to 7,500 miles, depending on the type of oil and driving conditions.
2. How do I know if my tires need replacing?
If the tread depth is less than 2/32 of an inch, or if you notice cracks, bulges, or uneven wear.
3. Can I extend my battery life?
Yes! Keep the terminals clean, avoid short trips, and use a trickle charger if you don’t drive often.
4. What’s the best way to improve fuel efficiency?
Maintain proper tire pressure, drive smoothly, avoid excessive idling, and remove unnecessary weight.
5. Where can I find the best deals on used trucks or replacement parts?
If you’re looking to upgrade your truck or replace worn-out parts, you can find used cars in UAE, as well as 2nd-hand car deals at great prices on platforms like ArabWheels. Whether you’re in the market for a used pickup truck or need quality parts, you can get a great deal on used car prices in UAE without breaking the bank.
Keeping your pickup running like new isn’t rocket science—it just takes regular maintenance and smart driving habits. Avoid common mistakes, follow a routine, and don’t ignore warning signs. Your truck will reward you with better performance, longevity, and resale value.
If you’re considering upgrading to a new pickup truck, Arabwheels offers reliable options at unbeatable prices.
Stay on top of maintenance, and your truck will serve you well for years to come!
